Page 6 of 6 FirstFirst ... 456
Results 151 to 171 of 171
Thread: The Official Coilover/Strut swap fitment guide!
  1. #151
    Mar 2014
    914
    16
    Points: 914, Level: 16
    Level completed: 14%, Points required for next Level: 86
    Re: The Official Coilover/Strut swap fitment guide!
    Quote Originally Posted by 86bratman
    Order the 02-07, you can bolt them in without modification. However, if you want the front camber plates to be adjustable you will need to swap sides on the front hats.
    You mean just simply unbolt them at the top and switch them from one side to the other?
  2. #152
    Mar 2014
    914
    16
    How exactly does this swap work without having the camber plates out of spec>
    No matter the orientation from left to right you still need to rotate the hat 180 degrees which will still cause the plate to be out of spec camber/caster instead of just camber.
    The correct method is to buy coilovers for a GD and swap the front plates with GC fitment .
    If I am mistaken please let me know
    -Chuck
    So you are saying that I would need to buy the 02-07 wrx coilovers and then swap the upper mounts for an older wrx on to the coils?
  3. #153
    SLi Resident 86bratman's Avatar
    Jul 2013
    Tazewell VA
    739
    4,313
    41
    Points: 4,313, Level: 41
    1000 Experience PointsOverdriveVeteran
    Excuse my shitty crude drawing, it's all I have to work with where I'm at right now.
    by removing one side and putting it directly onto the other side you are rotating it 180, I've never ran coilovers personally, I'm repeating I read a while back on another site. Guy had pictures of gd coils on a bd with proper camber adjustments.
    My 1997 Legacy L
    Fuelly
  4. #154
    Mar 2014
    914
    16
    So I am looking at buying either the Rokkor or Raceland coils. Neither have camber adjustment on the rears. So that means I just have to unbolt the front mounts and swap them L to R correct?
  5. #155
    SLi Supporter
    Usa
    4,530
    23,515
    Points: 23,515, Level: 94
    Level completed: 17%, Points required for next Level: 835
    10000 Experience PointsO.G.Recommendation Second ClassSocial
    Frequent Poster
    Posting info that you have never attempted and "read" from another write up is so dangerous these days.. People will take what you post to heart..
    I ask again how would this work
    Considering that 100000's of Legacy owners have asked this question with the same answer "swap to GC plate"
  6. #156
    Mar 2014
    914
    16
    This is getting me nowhere. Too many different answers. It's not like I can order some coilovers for a gd and tell them to put gc upper mounts on them. I think I am more confused than when I started.
  7. #157
    SLi Supporter
    Usa
    4,530
    23,515
    Frequent Poster
    There is no confusion. You have the right info. Find your local BC Racing Supplier and they should be able to mix n match for you. Other wise bite the bullet like everyone else and buy GD coils and get GC front top hats if you want correct camber specs
    Quote Originally Posted by fogls
  8. #158
    Mar 2014
    914
    16
    Don't get me wrong I am greatly appreciative for the info. Truthfully I have learned a lot from this site in the short term I have been a member and got my car. I just want to be sure before I let go of the money. This is just my daily driver so I don't want to drop the cash for the BC coils. I am just looking for something to make the car my fun and enjoyable to drive, not track it. Are the strut bars the same between the WRX and the Legacy?
  9. #159
    SLi Supporter
    Usa
    4,530
    23,515
    Frequent Poster
    Please keep your questions related to this thread. The info you seek has been answered over and over again. Browse SLi and enjoy the knowledge you will gain. With regards to Cheap Fun.. this will require locating used items.. good luck .
    -Chuck
  10. #160
    Apr 2014
    15
    663
    13
    Points: 663, Level: 13
    Level completed: 26%, Points required for next Level: 37
    Ok been searching and believe this to fit but need to know before I waste money.
    My car. 1995 BK WRX 205/55/16
    2006 wrx SEDAN STRUT ASSEMBLY w/ mach v springs.
    What camber issues will I need to address?
    Thank you.
  11. #161
    SLi Supporter
    Usa
    4,530
    23,515
    Frequent Poster
    It will work. U need camber bolts front amd rear.
  12. #162
    Apr 2014
    15
    663
    13
    I just read that the stock springs on the BK wagon are 190lbs
    Stock wrx sedan is 116 isthat right?
    and the mach 5 is 116-156...
    That seems like a problem no?
    Edit:
    I did see a member here used wrx full swap front but legacy coils and tops on wrx struts in the rear. This was on an BG outback and I'm assuming it had body lift still because it looks higher than my car now. However I'd like to see if anyone has tried this on their bk. The mach V lowering springs are out of the question.
    Is there benefit to the wrx struts over the legacy struts?
  13. #163
    May 2014
    11
    588
    11
    Points: 588, Level: 11
    Level completed: 76%, Points required for next Level: 12
    I keep confusing myself the more pages I decide to go through. Not looking to do too many conversions, looking for a temp set up until I can get what I'd prefer for long term, does anyone know if any of these Raceland's would fit on a BL (2007) 2.5i? http://www.racelandus.com/coilovers/sub ... -kits.html any info is much appreciated!
  14. #164
    SLi Supporter
    Usa
    4,530
    23,515
    Frequent Poster
    Sorry no racelands at the time will work . You have multi link in the rear .
  15. #165
    May 2014
    11
    588
    11
    Thanks man!
  16. #166
    "Proby" teeceRS's Avatar
    Dec 2013
    North Carolina
    222
    1,739
    24
    Points: 1,739, Level: 24
    Level completed: 39%, Points required for next Level: 61
    has anyone figured out if the multi-link set up for the 08+ wrx fit the bh's yet?
    Don’t tell me the sky is the limit. If there are footprints on the moon!
    '00 Impreza 2.5RS (Sold)
    Black Sheep | Legacy BH9 with a twist
  17. #167
    Nov 2014
    61
    1,012
    17
    Points: 1,012, Level: 17
    Level completed: 12%, Points required for next Level: 88
    So what I get out of this thread is I want wrx wagon rear struts & springs to avoid the saggy butt issue? Only real question I have .. this is for a bg as well
  18. #168
    "Proby" Sambo's Avatar
    Nov 2009
    Breckenridge, Co
    227
    5,652
    48
    Points: 5,652, Level: 48
    Level completed: 51%, Points required for next Level: 98
    Anyone know about forester struts on an outback? trying to go up alittle bit... been low now gotta get high.
    i cant seem to find anything on here about forester to leggy swaps
    97 BG Legacy Outback
    No Friends on a Powder Day
  19. #169
    SLi Lurker 95USsubaru's Avatar
    Jul 2009
    trenton, NJ
    313
    5,908
    Points: 5,908, Level: 49
    Level completed: 79%, Points required for next Level: 42
    O.G.5000 Experience PointsTagger Second Class
    okay ive been wondering this for a while and idk if its on the boards, not to sure.
    I have an 05 Leggo sedan. trying to raise it. really want to put it on forrester springs to give it a little bit of a lift. not looking for anything crazy. what I really want to have is pretty much the same set up as the old SUS suspension system they had for the legacys. but really im CLUELESS as to what is the best, most cost effective way to get this done. I read before that if I just get the forrester springs, id be good for a 2" lift but I cant remember if that was for my old BD or this one. so please... HALP!!!!!!!!!!!!!
    Mine....
    JADE 205,+++ RIP. green/white/black 95 L
    BASIA 178,xxx. iiiimmmmm baaaaaaaaaack........... 95L
    __________ 05 Blue Leggo. started with 64K now at 135k
    Hers...
    Gunther 147,*** 99 Black GTI
  20. #170
    Jul 2009
    trenton, NJ
    313
    5,908
    Quote Originally Posted by 95USsubaru View Post
    wow, im a lazy piece of crap lol. literally just found about 10 threads that gave all the info.
    Mine....
    Hers...
  21. #171
    Feb 2022
    Reviving this old thread. It may be more relevant soon as some of these cars are able to be imported into the US now. For example, I now own a RHD JDM 1996 Subaru Legacy GT-B wagon in mint condition. The main problem I had with it was that the right-rear strut was seized. The struts are still available to buy new but they're almost $600 ea. before shipping from Japan. I wanted to maintain as close to factory comfort as possible so here's what worked for me.
    Struts: KYB EXCEL-G/GR-2 2004-2007 **WAGON ONLY**
    Springs: King Springs 2004-2007 Impreza Standard Height
    This maintained the correct height of the rear with no sag and no spacers needed. I went from yellow struts with black springs to black struts with yellow springs.
    Aside from the struts and springs I used OEM parts for the rest.
    20320AA113 STRUT MOUNT F
    20321AA201 HELPER F PAI22
    20322AE01A DUST COVER F
    20323FA000 SPRING SEAT UP
    20325FA000 RUBBER SEAT UP
    20326AA000 SPACER STRUT F
    20326AA120 DUST SEAL STRU
    20327AC000 CAP
    20371AA041 HELPER R PAI22
    20372FE010 DUST COVER R S
    20375FC001 RUBBER SEAT R
    20390FE010 MOUNT STRUT R
    So basically an entirely fresh, new setup for each corner. Did an alignment afterwards. Maxed out the front camber adjustment so some more adjustable bolts may be necessary. It's not too far out though. Since we don't have any of these cars in the US I used the specs for a 98-99 USDM Legacy GT Wagon.
    Target specs (left side listed only, just swap it for the right side)
    Front
    Camber: 0.4 to -0.6
    Caster: 4.1 to 2.1
    Toe: -0.17 to 0.17
    Total Toe: -0.33 to 0.33
    Steer Ahead: -0.05 to 0.05
    Rear
    Camber: -0.2 to -1.7
    Toe: -0.17 to 0.17
    Thrust Angle: -0.33 to 0.33
    Measurements before alignment
    Front Left
    Camber: -1.3
    Caster: 2.6
    Toe: -0.23
    Front Right
    Camber: -1.4
    Caster: 2.8
    Toe: -0.38
    Total Toe: -0.61
    Steer Ahead: 0.07
    Rear Left
    Camber: -0.4
    Toe: 0.23
    Rear Right
    Camber: -0.3
    Toe: -0.18
    Total Toe: 0.05
    Thrust Angle: 0.21
    Measurements after alignment
    Front Left
    Camber: -1.0
    Caster: 2.6
    Toe: 0.03
    Front Right
    Camber: -0.8
    Caster: 2.8
    Toe: -0.02
    Total Toe: 0.01
    Steer Ahead: 0.03
    Rear Left
    Camber: -0.4
    Toe: -0.03
    Rear Right
    Camber: -0.4
    Toe: -0.01
    Total Toe: -0.02
    Thrust Angle: -0.02
