Page 5 of 6 FirstFirst ... 3456 LastLast
Results 121 to 150 of 171
Thread: The Official Coilover/Strut swap fitment guide!
  1. #121
    Toronto, ON, Canada
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    Re: The Official Coilover/Strut swap fitment guide!
    Quote Originally Posted by FirstGenLegacy
    http://www.ebay.com/itm/1993-2001-SUBARU-Impreza-GC8-JSK-Shock-Spring-Coilovers-/350606689643?pt=Motors_Car_Truck_Parts_Accessories&hash=item51a1c9856b&vxp=mtr
    Will these fit my '92 Legacy L Wagon?
    yes.
  2. #122
  3. #123
    Apr 2010
    Clearwater, FL
    10
    3,615
    37
    Points: 3,615, Level: 37
    Level completed: 77%, Points required for next Level: 35
    Just to make sure I interpreted everything correctly. I have a 99LGT (BD?) and I'm buying RaceLand coilovers.
    I'd get the GC's, and rotate the front tophats??
  4. #124
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    No you would get the GD and rotate the front top hat. BUT! The camber adjustments will not line up.
    You can use the GC but the rear top hats are useless so unless you source GD rears the GC coils are out of the question.
  5. #125
    Apr 2010
    Clearwater, FL
    10
    3,615
    37
    Hmm...so if I could get RL to sell me a set with GC Fronts, and GD rears, that would do the trick, correct? And the camber adj. will still be right?
  6. #126
  7. #127
    Apr 2010
    Clearwater, FL
    10
    3,615
    37
    Ummmm.... yes.. but spring rates maybe off..
    Forgive my stupidity, suspension is not my forte.
    If the spring rates were off, would it make a huge difference? This car won't see a track, and isn't really even driven hard.
    Thanks.
  8. #128
  9. #129
    Apr 2010
    Clearwater, FL
    10
    3,615
    37
    Its fine .
    Sounds good, thanks a lot for the speedy replies!
  10. #130
  11. #131
    "Proby"
    Jan 2013
    212
    2,081
    27
    Points: 2,081, Level: 27
    Level completed: 54%, Points required for next Level: 69
    Not sure if its mentioned somewhere in this thread.. but op is wrong about the 3rd gen usdm coil fitment, Specifically the 4th gen fitment on the 3rd.
    The fronts: the upper top hat will need to be changed, no denying that.. the lower mount holes are also a larger diameter than the eccentric bolt used for camber adjustment. So, you adjust camber by moving the knuckle where you want and tightening the bolt (has been working fine for me for years).
    The rears: they are listed as not fitting. They are shorter than stock BE/BH lengths, but any 05-09 rear coilover is a direct bolt in. No swapping top hats no any of that.
  12. #132
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    do you have any proof to support those claims?
    I listed the front BL/BP needed different top hats.
    2000-04 (Includes BE = Sedan (Includes Outback) | BH = Wagon (includes Outback) | BT = Baja (Truck / UTE)
    NOTE: -Rear Suspension is Multi-Link not MacPherson struts
    ////////Front///////Rear
    GC 93-01 yes///////no <-- front = direct bolt in
    GD 02-07 yes////////no <-- Rotate front top hat
    BL 05-09 yes////////no <-- Requires BD/K/G/E/H or GD front rotated top hat.
    however I did not know about the eccentric bolt and the rear fitment. Not trying to call you out. Just looking for real facts.
  13. #133
    "Proby"
    Jan 2013
    212
    2,081
    27
    Daily driven proof and experience. Lowered 4.5" front and rear on 05-09 megan street xt coilovers with BE front top hats and megan solid upper rear mounts that came with the coilovers.
  14. #134
  15. #135
    Dec 2011
    califonia
    2,476
    30
    Points: 2,476, Level: 30
    Level completed: 18%, Points required for next Level: 124
    How exactly do u have to rotate the top hats? Just until they fall into place?
  16. #136
  17. #137
    Feb 2013
    11
    1,480
    21
    Points: 1,480, Level: 21
    Ok, I haven't done much on my '03 BE, but I have been reading a ton. I am still not quite clear on which parts I can pick up that would work as far as suspension wise. A strait forward answer would be sincerely appreciated as I have been reading these boards for the past few days and paging through each post is just plain tiring. (That sounds bad, sorry) Any help would be appreciated. Not really looking to go coilovers or insane autox setup, just something that'll give the sedan a little more aggressive look. Also, with the stock 16'' silverstone rims, should i get wheel spacers to achieve that flush look? Thanks again guys.
    2003 Legacy BE
    Weapon R intake
    STI axleback exhaust
    Whiteline rear sway bar
    H&R lowering springs
    25mm spacers on rear tires
    Upper rear window spoiler
    STI front seats
    Tinted rear taillights
    HIDs (8000k)
    Red hella horns
  18. #138
    "Proby"
    Jan 2013
    212
    2,081
    27
    There are no springs that will really lower your car that much. Most you will find specific for a BE is 1.5" drop. You can probably find some 4th gen springs that would drop it much more, but you would need fourth gen struts, with third gen front top hats and 3rd or 4th gen rears. IIRC, the struts are a wee bit shorter and you can snag 2" springs.
    Upgrading the rear sway bar is the single best thing you can do to the BE. The 13mm coat hanger strapped in the rear is JUNK.
    You can either go 3rd gen legacy specific or try and find a GD wrx sedan rear swaybar. I will be doing a DIY on how to fit the rear swaybar on a BE shortly. It takes a little work but Is fantastic and cheap.
  19. #139
    "Proby"
    Jan 2013
    212
    2,081
    27
    And I'm not familiar with the silverstone wheel you mentioned.. snow flake maybe?
    Here is my car (on coilovers) with the snowflakes. Lowered about 3" at this point. Lowering your car will statically induce camber, so whatever you're thinking spacer wise, you have to factor in that camber when you drop. 3" added about -1.2* front and -2.0* rear as kind of visible in this picture.
    Also to keep in mind, you will need extended lug nuts for anything more than 3-4mm of spacer. I would recommend saving yourself the headache of spacers and getting lower offset wheels.
    Here is my same car, lowered 4" with a 17x7.5 +42 wheel.
    Not sure if any of this helps but I'm trying
  20. #140
    Feb 2013
    11
    1,480
    21
    idk why I thought they were called silverstones, anyhow, yes; the snowflakes are what I have. I figure I will grab the basics, strut tower bar (rear and front). Once i get it dropped on the springs I will get an alignment so tire wear is even. Just to summarize what you've said; 1.5'' is achieved by dropping it on springs(where to buy other then eBay?) and (stock) struts? I might have been misleading when I referenced "flush", I had just meant that I dont want the wheels tucked deep in the well. Definitely not going for a stanced look, just more aggressive. Thanks again for the help.
    2003 Legacy BE
    Weapon R intake
    STI front seats
    HIDs (8000k)
    Red hella horns
  21. #141
  22. #142
    Feb 2013
    11
    1,480
    21
    I thought the post said coilover and strut swap fitment guide. I'm asking about which struts I can buy from other models that will fit in my 2003 sedan. I read most of the previous replies and didn't really understand the lingo since I'm not familiar with model codes all the B's. Do I still need to create a different topic?
    2003 Legacy BE
    Weapon R intake
    STI front seats
    HIDs (8000k)
    Red hella horns
  23. #143
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    The first post explains what the B chassis codes are and which struts swap in for you. Talking about springs and quality of ride you want needs to be moved to another topic.
    Plain and simple currently the only documented alternative to 2000-2004 BE/BH suspension is the 2005-2009 BL/BP suspension with the BE/BH top hats as "1055" posted above.
  24. #144
    Feb 2013
    11
    1,480
    21
    Thank you for the clarification. Will make sure I post in the appropriate thread from now on. Thanks again.
    Daniel
    2003 Legacy BE
    Weapon R intake
    STI front seats
    HIDs (8000k)
    Red hella horns
  25. #145
    Jul 2013
    2
    1,179
    18
    Points: 1,179, Level: 18
    Level completed: 79%, Points required for next Level: 21
    So I know I am probably beating a dead horse asking this but will BL/BP springs fit on my BH struts? I have looked at both style struts and they are both similar.........
  26. #146
    "FNG" Jacobpockros's Avatar
    Apr 2013
    San Diego, CA
    3,298
    35
    Points: 3,298, Level: 35
    Level completed: 66%, Points required for next Level: 52
    Does anyone know if Rear Suspension on a BG is interchangeable with Rear Suspension on a BE if Top Hats are changed out?
    2001 Subaru Legacy Limited Sedan 5spd
    Delta 1500 Cams/ DNA Motoring UEL Headers/ Magnaflow 14829 Catback/ Ganzflow and K&N Drop-in/ Perrin Crank Pulley/ Tein S-Tech Springs/ KYB Struts/ Paranoid Fabrications Rear Tophat Spacers/ Whiteline Front & Rear Sway Bars/ eBay Front Strut Bar/ Drag DR-31 Wheels/ Outback LL Bean Steering Wheel/ Yakima Roof Rack/ Putco Yellow Fog Bulbs/ 170,000+ Miles
  27. #147
  28. #148
    Mar 2014
    914
    16
    Points: 914, Level: 16
    Level completed: 14%, Points required for next Level: 86
    So this thread confused the shit out of me. I am about to order some coilovers for my 98 gt sedan. If I order the 02-07 WRX coils will they bolt in or do I need to swap top hats?
  29. #149
    Jul 2013
    Tazewell VA
    739
    4,313
    Points: 4,313, Level: 41
    Order the 02-07, you can bolt them in without modification. However, if you want the front camber plates to be adjustable you will need to swap sides on the front hats.
    My 1997 Legacy L
    Fuelly
  30. #150
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    Quote Originally Posted by 86bratman
    How exactly does this swap work without having the camber plates out of spec>
    No matter the orientation from left to right you still need to rotate the hat 180 degrees which will still cause the plate to be out of spec camber/caster instead of just camber.
    The correct method is to buy coilovers for a GD and swap the front plates with GC fitment .
    If I am mistaken please let me know
