So if you don't know yet my 97' BD GT got totaled
I replaced it with this sweet scooby.
1996 Subaru Outback BG7 EJ22E @ 350,000km running like a champ w/ cracked windshield and seized brakes. First owner happened to be a police department up north. They maintained everything on this car its so mint. Second owner a very friendly dyke who used the car for 3 years. All in all a very well kept high mileage subaru!
Price = $460 CAN
Needed:
-Windshield = $150
-Both left calipers (all brake stuff $420 :-D)
-Rotors and pads
-Ebrake shoes w/ springs and adjusters.
-Rust repair = Free
Total cost = $1030 CAN
The old ---> viewtopic.php?f=6&t=10911
The new :-D
getting ready
Windshield removed and rust repair begun
The uglyness, most rust removed just need to patch the holes and prep for paint.
Most common spot for a scooby to rust out. Not so bad though just surface rust thankfully.
UPDATE: finished..
bondo sanded
bondo sanded cont'd
Notice anything missing :-D
turns out the rust on the quarter panel was much worse then I expected. After some old school brazing the quarter was mint.
diff angle
fiberglassed over the welds and bondo over the fiberglass
primed the roof
primed the roof cont'd
primed the quarter / duragaurd the inside of the wheel well / under the bumper / inside the quarter from the trunk
roof rack removed. time to sand
headliner removed (oem roof rails consist of 10x 12mm or 10mm bolts that on the inside of the roof skin.
shoots some green
quarter end result without clear coat (not sure if i am going to clear it or paint the car flat black)
roof sanded (yeah yeah... i didn't take off the rubber strips.. who gives a shit its a beater.)
sanded..
3-tone :-D Flat Black/Green/Outback Grey vinyl
2nd coat done.
Repairs finished waiting for windshield and an emissions test.
STi fancy isn't it![]()
At home parked next to my roommate's GD Outback.
@ Neetronics w/ Seven's GC8 and randoms.
Winter mode.
Engine: EJ22E @ 405,000km !
- STi / SPT air filter
- 2.5" catback w/ HKS burnt tip canister style
- A/C delete (condenser, drier, compressor, etc.) left the evap for lazy reasons
- Optima red top battery
- Group N engine mounts
- Hill-holder spring (replaced with heavy duty spring.. mmm Stage 1 hheeh)
Replaced @ 415,000km
- valve cover seals, spark plug o-rings, oil filler neck o-rings
- cam seals
- crank seal
- rear main seal (RMS)
- Revised metal Oil Separator Plate (Plate of DOOM) + new screws!
- idler pulleys
- Timing belt
- Tensioner
- Water pump
- Thermostat (OEM!)
- Oil pressure switch
- single port exhaust manifold gaskets
- repaired flex pipe between pre & post cat
- NGK plugs & Wires
Transmission: 5MT 4.44 FD
- B&M short shifter w/ stay bushings
- Group N 5MT mount
Suspension:
- Subtle Solutions 1" lift kit with extended studs
- New top hats (strut mounts)
Fuel System:
Replaced @ 395,000km
- Fuel filler neck
- Fuel tank :-/
Interior:
- Stainless Steel Gauge Cluster Bezel
- JDM GT center console w/ raised arm rest
- Sti titanium shift knob
- Custom 3" shifter extension
- JDM Nardi wheel w/o airbag
-- No click spring
-- modified steering column cover
- Cruise control delete
- 04' WRX 6-disc (double-din)
Exterior: BG7 Outback
-Antenna delete
-Tint [fronts = 30 / rears = 10)
-JDM taillights (corners)
-DIY center tail light lense blacked out
-Stainless Steel Cluster Bezel (SS Bezel)
-hvac and radio dash panels sticker bombed.. random stuff..
-stickers.. stickers.. stickers.. stickers.. stickers.. stickers.. stickers..
-SLi decals.
Tires:
-Summer = 03' WRX 16" twin 5-spokes w/ Toyo Proxy (205/5/R16)
-Winter = 96' OB 15" 6-spoke w/ Dunlop Graspic DS-3 (205/70/R15)
What broke:
-Real Main Seal (RMS)
-Rear brake lines (BOTH)... replaced to the rear proportioning valve...
-ebrake release button.. :smt012 replaced with 04' STi ebrake (modified)
-Fog lights.. several... oh the dumb things I do when I see dirt and hills.
-Exhaust system.. several times .. all with pieced together oem items from random years..
-Clock spring.... Caused all functions to not respond.. No horn.. No airbag.. No Cruise Control... (replaced with nardi wheel)
-Shifter retaining spring
Waiting list:
- Forester Suspension
- Mud tires
- Hella supertones
- Debadged
The outback got extensions put in :-p well just one actually.
I removed the threaded insert and cut it half way to allow the bottom portion to thread into the shifter and the top portion to thread into the extension.
Overall I am really happy :-D My right hand is level with my left when I drive and the distance from 1/2/3/4 is 5 inches to the right of the steering wheel. Much easier to drive around town :-D
Oh and don't mind the mess.. its my work vehicle.. my other legacy has no interior :-p
7/27/2012 - lifted & overhaul
Decided she needed some serious TLC!
The list:
- cam seals
- crank seal
- idler pulleys
- Timing belt
- Tensioner
- Water pump
- Thermostat (OEM!)
- NGK plugs & Wires
- F/L caliper
- rotors & pads all around
- drive side e-brake cable
- gas tank (used from the track car)
- ball joints
- R/L top hat
- Subtle Solution 1" body lift kit (1" spacers w/ extended studs)
- Group N 5MT mount
- fluids fluids fluids!
