Page 1 of 7 123 ... LastLast
Results 1 to 30 of 189
Thread: chuckthefuk - 97 BDGT/Track | Sept 13' - Rollcage is DONE !!
    Toronto, ON, Canada
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    I am trying my flickr account so look for the album links after each update.
    So I finally took delivery of my soon to be track car. Heres the story...
    1997 BD9 Legacy GT Limited
    5MT / Sunroof
    Originally from Quebec, Canada (No SALT)
    Purchased from a local member in Ontario
    Price $2000 CAN
    Flickr Album -> http://www.flickr.com/photos/43663513@N ... 481034969/
    Anyways I'll start my list of items:
    **Complete 04' STi Swap no Merging"
    Engine: 04' STi EJ257 (NO IMMOBILIZER)
    1. - Royal Purple 10w30 oil
      - 04' STi EJ257 long block
      - 04' STi ECU tuned @ 19 PSI w/ Cobb AP
      - Turbo - none
      - Turbo Manifold - none
      - Up-pipe - none
      - 04' STi 3" down pipe w/o cat (hangers modified for BD chassis)
      - 3" straight through v-band axle back
      - A/C Delete
      - Cruise Delete
    [list=2:3e949qrv]Maintenance items:
    - Blown head gasket, needs a rebuild.
    - Wastegate was cracked on the turbo
    - stock manifold/up-pipe to be upgraded[/list:3e949qrv]
    Fuel System:
    [list=17:3e949qrv]
    - BD gas tank removed
    - BD rubber/metal fuel lines removed
    - BD rubber/metal brake lines removed
    - BD gas tank filler neck remobed
    - BD gas door removed/welded
    - SS brake lines (body -> caliper)
    - SS brake lines (body -> ABS unit) [unsure about ABS delete][/list:3e949qrv]
    Drivetrain: 6MT 3.90FD
    - 04' STi 6MT
    - 04' STi f/r axles
    - 04' STi R180
    - 04' STi DCCD
    - 04' STi stock bushings at the moment.
    - 04' STi f/r yokes + legacy driveshaft (custom welded, balanced) Chassis has be modified to clear flange
    - Group N 6MT Transmission mount (going to order eventually)
    Chassis/Suspension: BD9
    - Group N engine mounts (in a box with the Noltec stuff)
    - 04' STi lateral links
    - GC/GD Noltec adjustable lateral links
    - 04' STi f/r Subframes
    - 04' STi front aluminium control arms w/o ALK
    - 04' STi quick ratio steering rack
    - 04' STi + 97' BD intermediate shaft (custom linkage)
    - 97' BD steering column w/ 04' STi control stalk custom welded
    - Noltec f/r adjustable camber plates (track version) [Adjustable in any direction providing proper camber)
    - Noltec f/r camber bolts
    - Noltec front endlinks (dogbone)
    - Group A subframe locking bolts
    - Whiteline 25mm swaybar locking collars
    Interior:
    1. - 1x Zero/Sport Carbon Kevlar fixed seat w/ aluminum rails/sliders. (not certified) [driver]
      - 04' STi Cluster CDM in KM->MPH
      - 04' STi complete body harness w/ legacy accessory connectors (soldered & shrink wrap)
      - 97' BD Legacy ignition cylinder
      - 04' STi airbag ECU removed
      - 97' BD climate control delete (going with aftermarket heater box)
      - GC' Cusco 12-point Bolt-On Roll Cage
      - 04' STi pedal assembly w/ sti pedals
      - 04' STi shift knob
      - BD column cover modified for aftermarket wheel hub.
      - 04' STi ebrake w/ chrome button
      - 04' STi DCCD + C.DIFF buttons mounted to ebrake cover plate [/list:3e949qrv]
      Exterior:
      - GD RS/WRX front fender flares
      - Rolled + flared quarter panels
      - GD ARP W-I-D-E--B-O-D-Y rear quarters (replica fiberglass)
      - Carbon FX GT style hood
      - BD L' Trunk w/o spoiler
      - 04' STi bumper w/ fogs + spats (merged to BD GT bumper Half&Half)
      - JDM BD tail lights
      - 97' GT trunk lens
      - JDM Projectors w/ right lens removed for air duct
    Wheels:
    - ?????????????? 17+ x 8+ @ 45+ offset
    - Tires?
    Brakes:
    - 04' STi Front Brembo 4-pot w/ EBC Green Stuff
    - 04' STi Rear Brembo 2-pot w/ EBC Green Stuff
    - 04' STi f/r hubs / spindle
    - SS brake lines f/r
    Audio:
    - Boxer rumble
    Carbon FX Hood
    Flickr Album -> http://www.flickr.com/photos/43663513@N ... 622002056/
    Zero/Sport C/F Kevlar Fixed Seat
    Goal is to fit into a 36/38 before I can track.. Current 40/42
    [GUT N' STRIP]
    --> Quick blurb.. removed most of the interior.. found an ebay short shifter and a 10 disc cd changer. as well as 2 mis-matched speakers..The previous owner was to cheap to buy an aftermarket wiring harness and decided to hard wire it directly.. Fucking nightmare!!
    Flickr Album -> http://www.flickr.com/photos/43663513@N ... 619314100/
    [GD 04-05 Fender flares]
    --> Quick blurb.. test fit with self tappers... still need to trim, rivet, weld, fiberglass, bondo, prime
    Flickr Album -> http://www.flickr.com/photos/43663513@N ... 743847414/
    -Need to hammer in the arch lip.
    -Need to trim a bit more
    -Need to bring out the bumper mounting point by 1" so it can flow with the flare.
    ----------------Mar/13th/2010------------------------------------------------------
    Picked up a set of fiberglass 02-07 GD Impreza ARP (replica) rear quarter panels. Bought these from a local member for $250 and found out that they were made by Vince from VKinnovation.
    Here are a few pics of the fenders + the body shop process (for an Impreza not Legacy!) + Finished look
    Above are the fiberglass replicas. My Flickr link below had the photos of the the under layers. There basically a 1" x 2mm outline of all the panels that get "glued" down to the quarter panel and then the fiberglass panel can get screwed into place which gives a "flush" look. But since this is a legacy and nothing from a GD actually fits I am going to toss them and go with a full fiberglass molded quarter panel.
    Flickr Album -> http://www.flickr.com/photos/43663513@N ... 612496460/
    This widebody kit is out of this world but IMHO its just to wide and boxy for my taste.
    So.... The plans...
    0) Fiberglass both sections together and cut the new door line.
    1) The combined length of both door skin and quarter panel is almost 5 foot. So I plan on shorting it by 1-2 feet at the same time .
    2) This should shorten the depth of the arch by 1-2" The original ARP arches are almost 4" and that's a tad big for me.
    3) I might delete the gas door and go with a fill-in-trunk fuel cell OR use the gas door and go with a standard filler-neck fuel cell.
    4) Not sure if I am going screw/rivet/sheet metal brace the underside.. there are so many options..
    Expect photos of the the "mock-up" stage by April-May..
    I couldn't help myself... Rough mock up. Fits pretty good. Thanks 3M :-D
    87/ [/b]
    ----------------May/3rd/2010------------------------------------------------------
    Cusco Safety 21 Around-dash 8-point Roll Cage *GC8*
    So... I scored a GC8 Cusco 8-point roll cage thats missing one chromoly bar for the low price of $200 CAN. I don't know what I am going to do with this...
    Options:
    a) Get the chromoly bar, test fit and bolt together
    b) Get the chromoly bar, test fit and weld it together
    c) Use the cusco design and weld a custom cage then sell the cusco to my buddy with that white gc8.
    http://farm5.static.flickr.com/4066/457 ... fed9_b.jpg
    http://farm5.static.flickr.com/4028/457 ... e84a_b.jpg
    http://farm5.static.flickr.com/4053/457 ... 9dd0_o.jpg
    Flickr Album -> http://www.flickr.com/photos/43663513@N ... 853762127/
    ----------------June/6th/2010------------------------------------------------------
    Rolling Adjustable Body Dolly
    ... So space in my garage is a little tight so I decided to go "ALL-OUT" and build a Rolling Adjustable Body Dolly.
    NOTE: I am going to remove EVERYTHING from the car. Wire wheel, sand blast, paint strip the entire car! This will take many days if not months. So expect slow updates.
    The Parts.
    8x2" Swivel Steel caster with Rubber liner (helps to reduce noise and resistance)
    8x2" Swivel Steel caster with Rubber liner with Foot Brake (helps to prevent the body dolly from rolling around when working)
    3-ton Jack stands (I could of used 2 but these were on sale)
    The Mockup
    The Example
    Example of the car on the dolly (not exactly to scale. Since I'm 6'3" and much taller then the final height measurements of the dolly.
    The Cost
    Everything has been purchased from http://www.princessauto.ca (local supplier for Canada)
    2x 8x2" Swivel Casters @ $43 CAD
    2x 8x2" Swivel Casters w/ brake @ 45 CAD
    2x 3-ton Jack Kit @ $35
    Raw metal @ $100
    4x Ratchet Straps @ $36
    $382 + 13% Tax
    Total $431.
    The Process
    1) Raise car body from rear and front subframes to appropriate height with pump jack and stands.
    2) Roll body dolly under car body
    3) Adjust cross bars to proper length/width and tighten locking bolts
    4) Adjust Jack height and affix locking pin
    5) Lower car body on to Jacks
    6) Remove subframe pump jack and stands and roll the dolly around in the direction needed.
    Not bad for a custom made dolly.
    and to celebrate the sturdy acomplishment we decided to pull the rear end.
    All pics uploaded to flickr.. check below
    [b]Flickr Album -> http://www.flickr.com/photos/43663513@N ... 6236054317
    ----------------Oct/11th/2010------------------------------------------------------
    Quick summary..
    - Bought a complete Turn-Key Legacy wired 04' STi swap from member DIP @ $7500
    - Zak bought the chassis from DIP @ $450
    - Remove STi component and replaced with stock Legacy component from my track shell.
    - Labelled all connectors from harness to component
    - Complete 04' STi swap put into storage until chassis is ready next year.
    [b]Flickr Album -> http://www.flickr.com/photos/43663513@N ... 5020884603
    ---------------May/9th/2011--------------------------------------------------------
    So it been some time and I have been busy with life and helping other subaru friends with their projects.
    I finally got around and pulled the entire STi harness!! YAY!
    more pics in the flickr album from my last post.
    Also UPDATE!!
    The cusco bolt-in rollcage is gone.. SOLD .. c'ya!!
    Time for a proper weld-in cage from Ronie O'brian Motorsports.
    ------------------------ April/2nd/2012-----------------------------------------
    So things are starting to roll..
    Dropped $2000 on a deposit for my rollcage.
    specs:
    - Builder = Ronnie O'Brien Motorsports / Brampton, Toronto
    --- He makes cages for CamJam Canada and most ORC/CRC rally cars.
    - TiG Welded
    - un-painted
    - cage will be tied into rear subframe
    - cage will pass through the firewall and tie into the shock towers.
    - 10-point = $3300
    - chromoly = $500
    - gussets on pillars = $150
    - air jack tubes = $200
    - undertray/pan mounts = $200-400
    - jack points = $200
    Ronnie let me take some photos of his current setups.. he didn't let me take pics of certain things like his shop / door bar design / and other custom trade secrets. Here is a E46 M3 he was about to finish and paint. Sorry for the sloppy shots.. it was iffy with my smartphone acting up and constantly talking to Ronnie.
    --------------> Pics below :-D no img tags since they are huge and so many :-D <--------------------------------------
    http://img171.imageshack.us/img171/5005 ... 174038.jpg
    http://img20.imageshack.us/img20/662/20120401174100.jpg
    http://img820.imageshack.us/img820/1365 ... 174118.jpg
    http://img848.imageshack.us/img848/4517 ... 174128.jpg
    http://img718.imageshack.us/img718/200/ ... 174133.jpg
    http://img3.imageshack.us/img3/7725/20120401174140.jpg
    http://img215.imageshack.us/img215/9756 ... 174159.jpg
    http://img195.imageshack.us/img195/4631 ... 174206.jpg
    http://img35.imageshack.us/img35/5763/2 ... 174211.jpg
    http://img59.imageshack.us/img59/4883/2 ... 174237.jpg
    http://img833.imageshack.us/img833/8113 ... 174243.jpg
    http://img713.imageshack.us/img713/6930 ... 174253.jpg
    http://img600.imageshack.us/img600/3290 ... 174259.jpg
    http://img194.imageshack.us/img194/7730 ... 174307.jpg
    http://img710.imageshack.us/img710/9855 ... 174318.jpg
    http://img4.imageshack.us/img4/7493/20120401174325.jpg
    http://img542.imageshack.us/img542/7808 ... 174336.jpg
    http://img221.imageshack.us/img221/237/ ... 5xbjcr.jpg
    http://img543.imageshack.us/img543/7664 ... 174349.jpg
    http://img535.imageshack.us/img535/509/ ... 174403.jpg
    http://img688.imageshack.us/img688/8105 ... 174411.jpg
    http://img51.imageshack.us/img51/944/20120401174419.jpg
    http://img254.imageshack.us/img254/3563 ... 174428.jpg
    http://img594.imageshack.us/img594/3545 ... 174437.jpg
    http://img607.imageshack.us/img607/3387 ... 174443.jpg
    http://img100.imageshack.us/img100/9011 ... 174453.jpg
    http://img220.imageshack.us/img220/34/2 ... 174507.jpg
    http://img407.imageshack.us/img407/277/ ... 174519.jpg
    http://img213.imageshack.us/img213/4105 ... 174523.jpg
    http://img18.imageshack.us/img18/9114/2 ... 174530.jpg
    http://img441.imageshack.us/img441/392/ ... 174539.jpg
    http://img811.imageshack.us/img811/5290 ... 174544.jpg
    http://img813.imageshack.us/img813/46/2 ... 174606.jpg
    http://img816.imageshack.us/img816/1186 ... 174618.jpg
    http://img38.imageshack.us/img38/2741/2 ... 174638.jpg
    http://img194.imageshack.us/img194/8220 ... 174751.jpg
    http://img152.imageshack.us/img152/7758 ... 174818.jpg
    http://img268.imageshack.us/img268/2346 ... 174828.jpg
    http://img840.imageshack.us/img840/6971 ... 174907.jpg
    http://img856.imageshack.us/img856/9436 ... 174917.jpg
    http://img10.imageshack.us/img10/9329/2 ... 174930.jpg
    http://img163.imageshack.us/img163/2503 ... 175003.jpg
    http://img856.imageshack.us/img856/7366 ... 175037.jpg
    http://img853.imageshack.us/img853/9663 ... 175041.jpg
    http://img3.imageshack.us/img3/4365/20120401175055.jpg
    http://img28.imageshack.us/img28/9290/2 ... 175106.jpg
    http://img163.imageshack.us/img163/3504 ... 175116.jpg
    http://img696.imageshack.us/img696/5305 ... 175122.jpg
    http://img710.imageshack.us/img710/1645 ... 175132.jpg
    http://img846.imageshack.us/img846/47/2 ... 175136.jpg
    http://img407.imageshack.us/img407/7893 ... 175147.jpg
    http://img16.imageshack.us/img16/9678/2 ... 175152.jpg
    http://img853.imageshack.us/img853/220/ ... 175200.jpg
    http://img525.imageshack.us/img525/6347 ... 175207.jpg
    http://img696.imageshack.us/img696/9199 ... 175217.jpg
    http://img32.imageshack.us/img32/4215/2 ... 175223.jpg
    http://img820.imageshack.us/img820/2659 ... 175229.jpg
    http://img818.imageshack.us/img818/9862 ... 175245.jpg
    http://img526.imageshack.us/img526/1889 ... 175519.jpg
    aftermath of the final strip and moved the 6MT/EJ257 back home for now.
    Rolling her out.
    Removed
    -windows/sound deading/dash/heatercore/blower
    -unroof/doors/engine/trans/diff/suspension/fuel tank
    -brake lines/fuel lines/seatbelts/interior/door sensors/
    - EVERYTHING except the brake booster/master & slave clutch/wiring harness
    Backing her up
    Slowly rolling her up the ramps.
    Shes loaded and ready to go!
    Watching her while we drive
    View out the back of the truck
    Unloading @ O'Brien Motorsports
    Her new home for the next few months.
    Till next time.
    t3h ub3r m3mber 2.5GT's Avatar
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    Points: 12,834, Level: 73
    Level completed: 96%, Points required for next Level: 16
    Re: chuckthefuk - Satin Black 97' BD6 GT (Track Car)
    A little bit of elbow grease and you're good to go!
    t3h ub3r m3mber 02_Legacy's Avatar
    UP of Michigan
    1,142
    9,186
    64
    Points: 9,186, Level: 64
    Level completed: 46%, Points required for next Level: 164
    Just wondering if its got a 2.50" exhaust why are you going to a 2.25? I'm thinking of doing exhaust on my car and was going to go with 2.50 is there something wrong with that?
    04 RSTI
    98 Legacy Outback
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    Quote Originally Posted by 02_Legacy
    2.5" produced less back pressure and causes lag during low rpm acceleration. I found that 2.25" is the sweet spot at least in my configuration.
    SLi Resident evolegacy's Avatar
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    Points: 6,755, Level: 54
    Level completed: 3%, Points required for next Level: 195
    i can agree with you on that, do you plan on doing anything to get the torque back in the low end of the powerband? I find that it would be more effective to go with a supercharger if you plan to do forced induction or go hybrid with the CAI and keep the snorkle so you don't lose the torque
    02 WRX wagon 5spd MT Daily Driver
    98 2.5 GT 4AT RIP
    99 2.5 GT 5spd MT RIP
    00 2.5 GT LTD 5spd MT RIP
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    Quote Originally Posted by evolegacy
    no plans really since all the engine stuff is temporary, I never did feel the difference between snorkle/snorkless. I plan on doing a few events with the EJ25D then swap a JDM Ej205 head w/ a JDM EJ208 bottom end. And the transmission I plan on using is undetermined at the moment.
    13,377
    Looking forward to it chuck!
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    I never tried the snorkle idea I only heard the possibilities from doing it, so figured i'd ask. what would the benefits be from using the 205 heads on a 208?
    98 2.5 GT 4AT RIP
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    204/205 blocks are known for breaking. 204/205 heads are better flowing the 206/207/208 heads. The 208 bottom end is much stronger then the previous generations. I am only choosing this combination since this is a known fact on the inter-webs and my buddy with a GC8 just went through this nightmare.
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    Re: chuckthefuk - 97' BD6 GT (Track) *update* GD flares....
    There's a old member(s) here that did the same impreza flare. It does look good if done right. Hardest part is getting everything line up. I would like to see the final results
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    Ya I'v seen that thread. He actually lived 20 minutes away from me. I am still debating going with a 1 - 1/2" gap between the original fender and the gd fender, this would create a fender vent from behind similar to widebody fenders.. OR just mount them flush by using just the flare and not the GD wheel arch.
    Hmmmm.. I'll decide this weekend when i mock up the other side and restock some cutting discs.
    My biggest concern is wheel fitment after this fender upgrade.. I am running 205/55/R16's now... I know I can fit 225's no problem with some rolling of the fender lip and the right alignment..
    Any suggestions?
    SLi Supporter MoclovFlop's Avatar
    Aug 2006
    Arvada, CO
    339
    7,475
    57
    Points: 7,475, Level: 57
    Level completed: 63%, Points required for next Level: 75
    Just don't get sidetracked with other projects/Miatas/Cameros/STIs....and everybody will love you.
    You can only get so far with a warm spoon
    Dial 5 for teH Niteclub!
    SLi Lurker )2edline's Avatar
    Jan 2008
    Boston, MA / Bridgeport. CT
    419
    8,117
    60
    Points: 8,117, Level: 60
    Level completed: 84%, Points required for next Level: 33
    Quote Originally Posted by MoclovFlop
    oh no he didn'tttttttttttttttt - yes, yes he did =]
    2004 FXT - Tuned by Kinetic MW
    2002 Nissan Sentra SpecV Turbo
    1997 Legacy GT BD6 - RIP
    "It shows your devotion to one unique automobile and I'd bet money that your car has a personality that rivals most living...Your Legacy is an excellent showing of (I'm going to say it) what makes a Subaru a Subaru." -1996Battlewagon
    Aug 2006
    Arvada, CO
    339
    7,475
    57
    Re: chuckthefuk - 97' BD6 GT (Track) *update* Nov/6/09
    I like you better already.
    Looks good.
    "Proby" aurelius's Avatar
    Sep 2008
    Melbourne, Australia
    213
    6,274
    51
    Points: 6,274, Level: 51
    Level completed: 62%, Points required for next Level: 76
    brb, wiping the drool off my keyboard when I saw this.
    Project Domo
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    That's pretty cool
    Any plans for the rear?
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    not sure yet... my options are:
    1) GD STi rear quarter cut outs and door cut outs
    2) GD STi widebody fiberglass add-ons
    3) GC 22b rear quarter replica (similar to xXGTBspecXx wagon)
    4) SF Forester rear quarter cut outs and door cut outs
    SLi Lurker slaytalera's Avatar
    Sep 2008
    Sparta, NJ
    477
    8,338
    61
    Points: 8,338, Level: 61
    Level completed: 63%, Points required for next Level: 112
    oh he went there
    looks great so far, cant wait to see what you do with the rears
    SLi nOOb chaksq's Avatar
    North NJ
    194
    6,151
    51
    Points: 6,151, Level: 51
    Level completed: 1%, Points required for next Level: 199
    Those GD flares look HOT. If I ever find a WRX in the yard...
    1991 Toyota MR2 │ Black │ 2.2l 5S-FE
    2006 Acura RSX Type-S | Blaze Orange Metallic | 2.0l K20Z1
    Previous: 2007 Mazda 6, Bright Island Blue | 1998 Subaru Outback, Blue/Gold | 1991 Toyota MR2, Red | 2000 Ford ZX2 S/R, Zinc Yellow | 1996 Ford Escort LX, Cayman Green
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    Re: chuckthefuk - 97' BD9 GT (Track) *update* Dec/28/09.. :-
    Where to start... Good new... or bad news.......... Good news it is!
    Good news:
    -Sold my EJ25D for $400-ish.
    -Sourcing out a chargespeed (replica or original) rear quarters and doors
    -removed most of the insulation and interior paint.
    -prepping for seam welding and bracing with gussets.
    -debating going with a weld in cage from http://www.customcages.co.uk (local dealer can offer there product line up) http://www.customcages.co.uk/Rollcage/M ... rer=Subaru
    or going with a custom cage made by a local shop. I have no real purpose for this car so certified cages are not my concern.
    -Priced out carbon/kevlar single racing seat, harness, fire suppression system, and fuel cell.
    Bad news:
    -My father passed away in his sleep on Nov 21st 2009 @ age 58 from cardiac arrest.
    -I am forced to sell my fathers body shop, since I can not become a full time body tech currently.
    -I have lost the ability to work on my car in the winter.
    -I have lost most of my ambition/motivation to complete the chassis prep this year/winter.
    Please do not send your condolences.. I've had a month + of people reminding me.... I appreciate the thought, but lets just keep it strictly legacy in this thread.
    From the bitter north.
    Toronto, ON, Canada
    4,530
    23,515
    Frequent Poster
    Re: chuckthefuk - 97' BD9 GT (Track) *update* Mar/13/10.. :-
    Check 1st post ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    SLi O.G. httrdd's Avatar
    NEPA
    2,700
    11,761
    Points: 11,761, Level: 71
    That should look really good!
    TJ
    99 LGT H6 Limited OBP
    SLi O.G.
    Nov 2007
    Ma.
    2,109
    17,645
    Points: 17,645, Level: 84
    Level completed: 59%, Points required for next Level: 205
    trim the fat and get to the good stuff.. all while keeping it simple. I like. You're definitely off on the right foot and running.
    BD GT
    SLi nOOb B's Legacy Wagon's Avatar
    Feb 2010
    Beaverton,Or
    192
    4,066
    Points: 4,066, Level: 40
    Level completed: 58%, Points required for next Level: 84
    Re: chuckthefuk - 97' BD9 GT (Track) *update* Mar/29/10.. Oh
    Looking great nice that you update the first post alot with all the new stuff. Cant wait to see more.
    Keep up the good job chuck..
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Points: 16,569, Level: 82
    Now this is a member's ride thread!
