WHP: 507 (daily tune)
Weight: 2,800lbs
Sponsors:
PowerflexUSA - http://powerflexusa.com/
Whiteline - http://www.whiteline.com.au/
Moore Performance - https://mooreperformanceparts.com
SuperPro - http://www.superpro.com.au
Mod list:
Aesthetics:
Interior:
04 STi Front Seats
04 STi Steering Wheel
Custom Blue Suede STi Door Cards
Custom Blue Suede Shifter Skirt
Custom Black Carpet
Custom Gauge Cluster
Custom Boost Gauge Mount
Custom Control Panel
Sparco Lowering Shift Knob
STi Carpet Floor Mats
Sony Xpl? XS-GT1627A Speakers
Sound Ordnance B-8Ps 8"
Pioneer Stereo
Rear Interior Stripped
Exterior:
RA Mud Flaps
96 LGT Front Bumper
BG5 JDM Zecter Grill Painted Java Black
Windshield Washer Nozzles Painted Java Black
Windshield Wipers Painted Java Black
Hella Supertone Horns
Pulled Fenders
20% Rear Tint
Rear 07 STi Defuser
JDM BG5 Tail Lights
Smoked Headlights
H1 Mini Projectors
6000k HID Bulbs
LED White Halos
JDM Projector Fog Lights
2004 STi Hood Scoop
Painted WRB
Color Matched Trim
Color Matched Center Tail Lights
Color Matched Rear License Plate
Custom LEGASTi Emblem
Engine Bay:
Shaved Engine Bay Painted WRB
Wire Tucked
Battery Relocated To Rear
Windshield Washer Tank Relocated To Rear
Performance:
Engine:
STi EJ257 Block
CP Forged Pistons and Rings
EJ251 SOHC Ported Heads
Techworks Engineering Stg. 2.5 Cams
Supertech Dual Valve Springs
Supertech Titanium Retainers
Garrett GTX30R External Wastegate Turbo Wrinkle Red Heat Coated
Tial MV-R 44mm External Wastegate
Hallman Pro Boost Controller
Custom WRX Fuel Rails
ID 1000cc Top Feed Injectors
Full Race 416lph E86 Fuel Pump
Tomei Timing Belt Guide
WRX Flipped Intake Manifold Wrinkle Red Heat Coated
GroupN STi Motor Mounts
GroupN STi Pitch Stop Mount
AEM Air Cleaner
Custom 4" Intake Wrinkle Red Heat Coated
Custom V-Mount intercooler
Custom Intercooler Pie Cut Piping Wrinkle Red Heat Coated
04 Forester XT Radiator
Crawford Heated Air/oil Separator
Mishimoto 19 Row Oil Cooler WRB
Mishimoto Oil Cooler Thermostat Sandwich Plate
Custom Top Mount Oil Cooler Brackets
Flipped Alternator
Custom Alternator Belt/Tensioner
02 Legacy Power Steering Pump
Blue Silicone Hoses
SMC2 Meth Injection Kit
Link Plus G2 Standalone
Exhaust:
3” Custom Fitted Cat Back Catless Exhaust
3" Perrin Rotated Catless Downpipe
Grimmspeed Ceramic Coated Crossover Pipe
Ceramic Coated Headers
Perrin 2" Rotated Up Pipe
Powertrain:
05 LGT 4:11 5Speed Transmission Polished
04 STi Axle Stubs
05 LGT Limited Slip Rear Diff
02 WRX Rear Axles
ACT Extreme Duty Pressure Plate
ACT 6Puck Clutch Disc
ACT Street Lite Flywheel
ACT Throwout Bearing
Whiteline Transmission Crossmember Bushings
Kartboy Short Shifter
Kartboy Front and Rear Shifter Bushings
Subaru Shifter Joint
Moore Performance Blast Plates
Suspension and Handling:
Megan Racing Track Coilovers
STi Pink Trailing Arms
Whiteline Adjustable Lateral Links
Whiteline 27mm Adjustable Front Sway Bar
Whiteline 24mm Adjustable Rear Sway Bar
Whiteline Rear Endlinks
Whiteline HD Rear Sway Bar Mount
Kartboy Rear Subframe Lockdown Bolts
02 WRX Rear Crossmember Powder Coated WRB
02 WRX Rear Diff Support Powder Coated WRB
02 WRX Engine Cradle Powder Coated WRB
Super Pro Front Lower Control Arms
Super Pro Front Endlink
Super Pro Anti Lift Kit
PowerflexUSA Race Rear Diff Bushing
PowerflexUSA Race Diff Support Outrigger Bushing
PowerflexUSA Race Front Trailing Arm Bushing
PowerflexUSA Race Rear Trailing Arm Bushing
PowerflexUSA Race Steering Rack Bushing
Group N Rear Crossmember Bushings
Whiteline Front Roll Center Adjustment Kit
WRX Rack and Pinion Assembly
L&E Quick Steering Column
L&E Steering Linkage
Kakumei STi Rear Strut Bar
Bolt-in Roll Cage
Brakes:
Front Stoptech 2-Piece 13" Cross-Drilled Vented Zinc Coated Full Floating Rotors.
Front Brembo GT2 Calipers (Powder Coated Cherry Blossom Red)
02 WRX Rear Calipers
H6 Caliper Brackets
H6 Cross-Drilled Zinc Coated Rotors
Goodridge Stainless Steel Braided Brake Lines
HPS Hawk Brake Pads
Lots of mods coming soon.
Granny's first detailing. I wish I had a before picture but I don't.
Granny gets her engine cleaned for probably the first time in her life.
Granny gets custom made (by me) blue suede STi door cars.
Before:
After:
