Results 1 to 4 of 4
Thread: Anything I've got from LCO...
    "Proby"
    Federal Way, WA
    243
    7,963
    60
    Points: 7,963, Level: 60
    Level completed: 7%, Points required for next Level: 187
    I'll try to organize this as best I can, but I'mma slap it all up now, and edit this post later, okay?
    EDIT: 1.35pm, thursday afternoon: For those of you who don't know, the weather here in Western Washington is indescribably wonderful. I'm off work as of 35mins ago, and I'm headed home to bask in sun, and play with myself. Hot weather makes me hot, too.
    Okay, here we go:
    http://www.surrealmirage.com/subaru/ is a good start, and so is
    http://www.surrealmirage.com/subaru/fil ... Sheets.pdf
    SOURCES: http://www.graphics.cornell.edu/~v/partnumbers.html ,
    http://bbs.legacycentral.org
    Various part #s, may be duplicates, as I'm Copy/Pasting:
    Coolant Temp sensor: 22630AA041
    Updated Knock sensor: 22060AA031
    MT, Diamond Coil Pack: 22433AA370
    AT(black), MAF sensor: 22680AA160
    AT, Idle air control valve: 22650AA034
    Oxygen sensor: 22690AA150
    Throttle Body gasket: 16175AA150
    AT pan gasket: 31397AA040
    ATF add-on filter kit: 31099AA091
    Oxygen (NA) 22690aa150 91.40
    ball joint left 21067ga050 25.36
    Timing belt 13028AA102 $63.43
    Turbo/NA water pump 21111AA026/21111AA007, both $88.82
    Thermostat 21200AA072 $14.03
    Front crank seal 806733030 $8.83
    Exhaust manifold gasket 44022AA020 $9.53
    "16 VALVE" sticker 91531AA630 $30.80
    PCV valve 11810AA000 $12.38
    4WD nonturbo throw-out bearing 30502AA051 $34.95
    4WD nonturbo throw-out bearing clip 30539AA000 $2.28
    4WD nonturbo Clutch fork dust boot 30542AA000 $23.90
    4WD nonturbo Clutch fork 30531AA110 $25.12
    Bellhousing rubber cover 11413AA033 $5.38
    90-91 nonturbo front bumper cover 57720AA010 $239.97
    Nonturbo exhaust flange gasket 44022AA062 $7.98
    Axle-back gasket 44022AA211 $8.63
    Axle-back bolt 901660014 $1.19
    Axle-back nut 902350001 $1.74
    STi exhaust hanger ST440314S000 $9.95
    Turbo rear swaybar bushings 20401FA021 $4.82
    3-nipple PCV tree on block below PCV valve 11821AA221 $12.22
    7011AA131 turbo rear LSD
    114130151 brake line copper washer
    25232AA020 ignition relay
    16175AA150 throttle body gasket
    22659AA060 IAC valve gasket
    36015GA111 clutch pedal pad
    623006021 acorn lug nut
    28055AA002 lug bolt
    22060AA031 knock sensor
    22680AA170 aluminum housing hot-wire MAF
    G3110AS100 90-91 Calsonic R-134a retrofit kit
    G3110AS120 92-93 Calsonic R-134a retrofit kit
    G3110AS000 90-91 Zexel R-134a retrofit kit
    G3110AS010 92 Zexel R-134a retrofit kit
    G3110AS020 93 Zexel R-134a retrofit kit
    22690AA161 turbo oxygen sensor
    22690AA150 non-turbo oxygen sensor
    13028AA102 timing belt
    26310AA092 turbo front brake rotor
    26310AA112 turbo rear brake rotor
    14035aa290 intake manifold gasket
    22611AA694 turbo ECU
    498307500 select monitor
    498347502 90 select monitor cartridge
    498348400 91 select monitor cartridge
    498347601 90-91 select monitor cartridge
    498348800 92 select monitor cartridge
    498349200 93-94 select monitor cartridge
    498347700 90-94 select monitor cartridge
    11126AA000 oil drain plug crush washer
    23700AA090 alternator
    22012AA020 turbo pressure sensor
    21200AA072 thermostat
    11044AA282 turbo head gasket
    11033AA114 non-turbo head gasket
    Thermostat Gasket 21236AA010
    Right Rear ABS Sensor 26740AA021
    Left Rear ABS sensor is 26740AA031
    Pressure Exchange Solenoid 14774AA340
    Turbo MAP 22012AA020
    22680AA170 aluminum housing MAF
    22680AA160 plastic housing MAF
    22060AA031 updated knock sensor
    22633AA060 throttle position sensor
    22630AA041 water temperature sensor
    21203AA030 temperature gauge sender
    22012AA020 pressure sensor
    14774AA341 pressure exchange solenoid
    16102AA013 wastegate control solenoid
    82501GA240 fuel pump relay
    32005AA052 5MT reverse switch
    14774AA351 purge control solenoid
    42084GA460 turbo auxiliary purge valve
    42036AA040 turbo charcoal canister
    42036AA000 non-turbo charcoal canister
    22611AA564 90-91 5MT non-turbo ECU
    22611AA383 90-91 4EAT non-turbo ECU
    22611AA933 92 non-turbo ECU
    22611AB060 93 5MT non-turbo ECU
    22611AB052 93 4EAT non-turbo ECU
    22611AB770 94 5MT non-turbo ECU
    22611AB760 94 4EAT non-turbo ECU
    28055AA002 lug bolt
    694005092 lug wrench
    26402FA071 single stage brake booster
    725042000 brake booster seal
    26151AA163 brake booster vacuum hose
    26536AA001 brake line banjo bolt
    114130151 copper brake line washer
    901130011 front caliper bracket bolt
    901120036 rear caliper bracket bolt
    736016020 brake booster/pedal pin
    051108001 brake booster/pedal pin clip
    26310AC040 WRX front brake rotor
    26471AA032 ABS master cylinder rebuild kit
    26471AA010 non-ABS master cylinder rebuild kit
    26401AC040 turbo brake master cylinder
    26451AA000 brake master cylinder reservoir
    26453AA002 brake master cylinder cap
    725736010 brake master cylinder reservoir seal
    26771AA000 Bosch ABS hydraulic unit
    26730AA001 Nippon ABS hydraulic unit
    26731AA200 Nippon 2E ABS hydraulic unit
    26740AA040 ABS G-sensor
    87022AA051 90 5MT cruise control unit
    87022AA200 91-94 5MT non-turbo cruise control unit
    87022AA320 91-94 5MT turbo cruise control unit
    87022AA310 4EAT turbo cruise control unit
    87022AA190 4EAT non-turbo cruise control unit
    30100AA630 turbo clutch disc
    30210AA261 turbo pressure plate
    30502AA100 turbo throwout bearing
    30620AA021 turbo clutch slave cylinder
    30622AA001 turbo clutch slave cylinder kit
    30542AA021 turbo clutch lever boot
    30546AA030 turbo clutch lever release spring
    30620AA100 WRX clutch slave cylinder
    ST2031055000 STi front strut top mount
    E4010FA000 strut tower bar
    927760000 strut mount socket
    14035AA290 intake manifold gasket
    44022AA170 manifold-to-uppipe gasket
    44022AA150 uppipe-to-turbo gasket
    44022AA180 turbo-to-downpipe gasket
    44022AA160 crosspipe gasket
    14038AA000 turbo exhaust manifold gasket
    44022AA020 non-turbo exhaust manifold gasket
    44022AA122 turbo donut exhaust gasket
    44022AA062 non-turbo donut exhaust gasket
    44059AA010 midpipe bolt
    44044AA010 midpipe spring
    802008270 midpipe nut
    902370010 exhaust nut, mild
    902370029 exhaust nut, stainless
    44059AA030 pre-downpipe exhaust bolt
    800910340 turbo and uppipe stud
    800910390 exhaust manifold stud
    012510250 lower downpipe mounting bolt
    010110250 upper downpipe mounting bolt
    73008AA710 90-91 Calsonic A/C compressor
    73011AA091 92-93 Calsonic A/C compressor
    73011AA040 90-91 Zexel A/C compressor
    73011AA080 92-93 Zexel A/C compressor
    73011AA120 94 R-134a A/C compressor
    73061AA031 Calsonic evaporator core
    73061AA010 Zexel evaporator core
    72024AA000 blower motor resistor pack
    498307500 Select Monitor
    498347502 90 ECU/TCU Select Monitor cartridge
    498348400 91 ECU/TCU Select Monitor cartridge
    498347601 90-91 cruise/climate Select Monitor cartridge
    498348800 92 ECU/TCU/cruise/climate Select Monitor cartridge
    498349200 93-94 ECU/TCU/cruise Select Monitor cartridge
    498347700 air suspension Select Monitor cartridge
    86661FE020 WRX STi intercooler spray bottle/pump
    86636FA120 WRX STi intercooler spray nozzle
    83001FE020 WRX STi intercooler spray switch
    ST165464S000 STi air filter
    ST440314S000 STi exhaust hanger
    ST4511355000 STi radiator cap
    10103AA310 EJ22T short block
    ST1231055010 STi flywheel
    ST3010055100 STi clutch
    15010AA108 turbo oil pump
    27011AA131 rear 3.90 LSD
    21132AA010 turbo coolant filler tank
    45113GA022 radiator cap
    807611172 tank-to-turbo coolant hose
    21132AA075 WRX coolant filler tank
    10100BK600 EJ25T engine assembly
    14471AA001 turbo recirculating blowoff valve
    46023AA110 turbo compressor inlet rubber elbow
    14412AA070 Stock turbo
    14412AA080 RHB52 VF12 turbo
    14412AA092 TD05-16G turbo
    SOA4786010 non-turbo head
    SOA4786020 turbo head, right
    SOA4786030 turbo head, left
    11095AA090 head bolt
    10103AA280 non-turbo short block
    10103AA310 turbo short block
    16611AA150 turbo injector
    42021AC024 turbo fuel pump
    44033AA002 turbo chimney
    047406120 chimney bolt
    23300AA220 5MT starter
    23300AA230 4EAT starter
    44102AA030 turbo downpipe
    20100AA120 turbo crossmember
    20100AA101 non-turbo crossmember
    ST4100055110 STi motor mount, right
    ST4100055120 STi motor mount, left
    16611AA231 STi injector
    22650AA034 90-91 AT and 92-94 non-turbo IAC valve
    22650AA050 90-91 MT non-turbo IAC valve
    22650AA111 turbo IAC valve
    11140AA046 oil dipstick
    31100AA521 turbo torque converter
    31100AA552 non-turbo torque converter
    22670AA050 fuel pressure regulator
    SOA925H500 FWD CV axle
    SOA925H600 4WD front CV axle
    28044AA000 axle nut
    051906452 axle spring pin
    28015AA070 outer front hub seal
    28015AA021 inner front hub seal
    22433AA400 later Diamond coil pack
    22433AA360 4EAT and/or turbo coil pack
    22433AA370 5MT non-turbo coil pack
    809218140 alternator and power steering belt
    73013AA000 air conditioning belt
    42072PA010 fuel filter
    42031AA040 fuel filter rubber padding
    42053AA000 fuel filter mounting band
    42050AA020 fuel filter bracket
    16546AA020 air filter
    901120059 air filter housing bolt
    15208AA060 oil filter
    803926040 manual transmission drain plug gasket, aluminum
    803926070 manual transmission drain plug gasket, copper
    22401AA310 spark plug
    11810AA000 PCV valve
    90815AA380 92-94 turbo hood blanket
    90814AA000 hood blanket clip
    21111AA007 non-turbo water pump
    21111AA026 91 turbo water pump
    21111AA065 92-94 turbo water pump
    21114AA050 water pump gasket
    11060AA060 turbo thermostat cover
    11060AA070 non-turbo thermostat cover
    21236AA010 thermostat cover gasket
    SOA635002 factory coolant, 1 quart
    SOA868V9210 factory coolant, 1 gallon
    13294AA012 valve cover gasket
    13271AA051 valve cover bolt grommet
    64620AA020ML manual seatbelt, right
    64620AA030ML manual seatbelt, left
    64610AA220ML lap belt, right
    64610AA230ML lap belt, left
    62180AA000ML right front inside door handle plastic cover
    62180AA010ML left front inside door handle plastic cover
    62180AA020ML right rear inside door handle plastic cover
    62180AA030ML left rear inside door handle plastic cover
    84931AA130 92-94 sidemarker bulb socket
    84934AA050 92-94 sidemarker plastic mounting ear
    E3610AS940 hitch-mounted bike rack
    SOA447D466 power antenna mast
    66130AA050 1.5 din pocket
    66128AE000 single din pocket
    E1017AA100 metal step plates
    93073FE580 STi trunk emblem
    57497FE000 STi key
    SOA307T320 STi stainless mug
    SOA307T310 STi black plastic mug
    MSA6P8930 Small envelope
    Valve cover gaskets - 13294AA012
    Valve cover bolt washers - 13271AA051 (3 per side)
    Oil filler tube o-ring - 806923060 (its a 23.7x3.5 o-ring if you're looking for an even cheaper replacement)
    USDM BOV/BPV: 14471aa001
    JDM Turbo inlet rubber boot: 46023fa000
    Clutch pedal spring kit: x3601aa000
    Two bushings: 36013ga050
    spring: 3603711032
    Grille - outer clips: 91017AA010
    inner clips: 91059FC090
    Spark Plug Stuff:
    Platinum plugs don't perform better; they just last longer. The problem is that Platinum is actually not as conductive as copper (around 100,000 mho/cm versus 600,000 for copper), so some of the spark voltage is dropped inside the electrodes.
    The big selling point with platinum plugs is that they only need to be changed every 100,000 miles or so. To me that's not so great, because the idea of having to remove a plug from an engine after it's been there for 100,000 miles scares me. You also really should be reading your plugs more often than that just to check up on the state of your engine.
    It is true, though, that because the platinum electrode won't wear away as easily, you can make then smaller, exposing more of the spark to the air/fuel mixture. But the V-groove does a pretty good job of exposing the spark with copper.
    Another issue some tuners may have with platinum electrodes is that you can't adjust their gap. That means you can't experiment with different gaps with platinum plugs unless you buy lots of different platinum plugs, which is expensive. It's not necessarily the case that the optimal gap with a platinum plug will be the same as the optimal gap with a copper plug.
    I don't know as much about iridium plugs, but I think that they're basically a step up from platinum. Iridium is even more sturdy and resistant to wear so they last long and have smaller electrodes. Iridium is actually more conductive than platinum, though still nowhere near copper (around 200,000 mho/cm). I think you can gap Iridium plugs too.
    Copper with the V-groove is just a good proven cost-effective design... It's been common experience that platinum doesn't perform as well though it does deliver on longevity. I don't know, but it's possible that iridium would perform better due to the smaller electrode. I'll just stick to my $1.30 coppers though.
    OVERVIEW:
    GET NGK V-POWERS ONLY. RUN COLDER PLUGS ONLY FOR HIGH-ER BOOST APPLICATIONS!!
    Now I'm getting lazy, here's links,
    Service Manuals, etc.
    http://bbs.legacycentral.org/viewtopic.php?t=14485
    http://www.1stsubaruparts.com
    http://www.allsubaru.com
    LCO Suspension Compendium, only 90-94 stuff, as the 95 rear suspension changed. Good basic starting point for matching stuff up, though.
    http://bbs.legacycentral.org/viewtopic.php?t=2153
    AWD & 5sp Swap writeup:
    http://www.surrealmirage.com/subaru/swap/swap.html
    NuwanD's Brake upgrade, including ABS removal, and addition of electronically controlled brake-bias. SCHWING!
    http://spda-online.ca/modules/newbb/vie ... 0&forum=10
    EJ22 engine calculations:
    http://wac.addr.com/auto/obs/turbo/ejcalcs.html
    Basic Tire Size Calculator:
    http://www.miata.net/garage/tirecalc.html
    4 wire 02 sensors:
    http://bbs.legacycentral.org/viewtopic.php?t=14247
    STi Legacy Parts List, BC-BF
    http://www.main.experiencetherave.com:8 ... slist.html
    Lighting tech article: --A MUST READ!
    http://www.danielsternlighting.com/tech/tech.html
    Early Legacy Locks: (if yours stick, whatever)
    http://www.geocities.com/hobiegary/locks.html
    Oh, and in case some of you would like to leave a stain on the driver's seat:
    http://www.tcsracing.org/scandinavianflick.htm
    These guys are friggin' awesome:
    http://rhdjapan.com
    Just in case you wanted it, here's the thread all about the de-yellowing..
    http://bbs.legacycentral.org/viewtopic.php?t=739
    I've found that not nearly so many steps are required. Just get yourself some #0000 Steel Wool and go at it with some kind of cleaner, or even water. Later, move to wax, and keep scrubbing 'til you get the results you want. You'll start to see the difference, and eventually, the lenses will *sparkle* again, and you'll know you're about done. Try using a combination of rounded and straight across strokes. I only spent about 10-20mins per light, and then shot 'em with a good douse of clear-coat, so the yellow won't come back. You'll see fine again...
    Timing FAQ:
    http://bbs.legacycentral.org/viewtopic.php?t=19896
    Engine pull and rebuild tips:
    http://bbs.legacycentral.org/viewtopic.php?t=18218
    Hesistation Issues:
    http://bbs.legacycentral.org/viewtopic.php?t=514
    and
    http://bbs.legacycentral.org/viewtopic.php?t=583
    Engine Code pulling, OBD1; various AT tips, (Phase1 4EATs);
    http://www.surrealmirage.com/subaru/subaru.html
    Quote Originally Posted by Wiscon_Mark
    I'd challenge you but you have a lot more knowhow than I do...it would be like racing a Justy stock against an STi
    '92 BC676 NA AT AWD
    Borla 2.5RS Headers
    2.25" catback exhaust
    Custom Interior
    rocket
    Guest
    Hi there,
    By any chance would anyone have a list of sti parts for bc legacy. I came across this site while looking for a parts list and found the following link
    http://www.main.experiencetherave.com:8 ... tslist.htm
    which no longer seems to be working. I recently bought a 1992 BC5 RS Type RA and would appreciate any help. There is a list on the Japanese STI site but unfortunately not in English.
    Many thanks for your help.
    SLi Supporter DLC's Avatar
    Dec 2007
    Utah
    506
    8,426
    61
    Points: 8,426, Level: 61
    Level completed: 92%, Points required for next Level: 24
    Legacy777, who hosts that site, is in Houston. Probably has no power right now, so just be patient.
    March 2008 ROTM
    Legacy Central
    2001 (BH9) Legacy Outback - DD
    1997 (BG6) Legacy Outback Limited | 1998 (BK4) Legacy L | 2000 (BE6) Legacy GT Limited | 1993 (BJ) Legacy Touring Wagon | 1990 (BC) Legacy L+
    SLi Supporter jey's Avatar
    Texas
    1,663
    10,971
    69
    Points: 10,971, Level: 69
    Level completed: 31%, Points required for next Level: 279
    Just to clarify, does all this information apply to first gen Legacies? There is some good information here.
    - Jey
    1995 Legacy Wagon EJ257 turbo
    2011 Tribeca Limited EZ36
