Results 1 to 29 of 29
Thread: How-To- Cheap Front Endlink Upgrade for 1st/2nd Gen Legacies
    Jul 2011
    Kelowna BC, Canada
    43
    2,789
    32
    Points: 2,789, Level: 32
    Level completed: 26%, Points required for next Level: 111
    Veteran1000 Experience Points
    So I tried to install new fron endlinks on my 93 Turbo Wagon. I am cheap and bought cheap oem replacements. One broke in half on install.
    Wanting something better, but not wanting to blow $200 on aftermarket ones I looked at some 4th gen Legacy and other newer subaru endlinks and compared to the stock ones.
    They are a couple bucks cheaper, all metal with ball and socket ends vs the plastic with rubber bushings that are stock on older cars. This means they should result in more responsive sway bar function and stronger design.
    Heres a pic of one installed on my 1st gen with the car sitting on the ground.
    As you can seen the lower control arm mount was modded with a hammer to bend the inside tab out of the way and the hole was drilled out larger to fit the larger stud on the endlink. Other then those 2 minor changes, it was a direct bolt on using the stock contol arm and stock sway bar.
    Potential future concern is the strength of the control arm mounting tab, may need to be re-inforced especially with upgraded bars, but I'm going to keep an eye on it.
    Edit- Adding some control arm comparisons to this original post
    The old endlink style contol arm. Alot more then a tack weld on there.
    Heres a contol arm of an 05 ish wrx that uses the type of endlink I'm using. Theres not a whole lot of difference if we are looking at how beefy the mount is.
    And if it cracks or breaks, I will just weld a new mount on, no big deal and no bigger expense then a failed endlink.
    And of course aluminum uses this type of endlink anyways
    93 Legacy Turbo Wagon winestone, 5mt swap, rear lsd, v1 wrx seats- Winter
    04 E46 325i ZSP- Summer
    89 Volvo 244 LSX swap full build.
    SLi Supporter
    4,530
    23,515
    Points: 23,515, Level: 94
    Level completed: 17%, Points required for next Level: 835
    10000 Experience PointsO.G.Recommendation Second ClassSocial
    Frequent Poster
    Re: How-To- Cheap Front Endlink Upgrade for 1st/2nd Gen Lega
    Lets see you try that on a Aluminum Control Arm . heheeh..
    Way to be thrifty.. i am not a big fan of these types of mods but whatevz
    Dec 2009
    Kaysville UTAH
    1,824
    9,426
    Points: 9,426, Level: 65
    Jul 2011
    Kelowna BC, Canada
    43
    2,789
    32
    Quote Originally Posted by lord flashheart
    I'm still at half that price, and it took me 5 mins per side to do and they are in stock locally at most parts stores.
    3,542
    I saw this and was like "I can't pass that up." I now have a pair ordered.
    Dec 2009
    Kaysville UTAH
    1,824
    9,426
    Nice mod if your on a tight budget.
    Administrator Huffer's Avatar
    Eastlake, OH / Wellington, NZ
    13,377
    44,297
    Points: 44,297, Level: 100
    Interesting mod... and yep, I'd be really concerned about the durability of the mount now that you're only using 1 tab to transmit/spread the torsional load. I am wondering if you simply upgraded one part to have a more expensive one fail later because of it.
    This is why I like to use stock endlinks with upgraded swaybars. If a link breaks, cheap fix. If a control arm or swaybar mount goes...
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Points: 16,569, Level: 82
    Level completed: 44%, Points required for next Level: 281
    You're basically doubling the force that the tack weld on one side of the bracket has to hold. Still, clever.
    Dec 2009
    Kaysville UTAH
    1,824
    9,426
    be nice flashheart.
    I ment it in a nice way. But reworded it.
    Thank you.
    OMFGAWD phi11's Avatar
    Jul 2005
    Apple Valley, MN
    866
    10,878
    69
    Points: 10,878, Level: 69
    Level completed: 7%, Points required for next Level: 372
    Re: How-To- Cheap REAR Endlink Upgrade for 1st/2nd Gen Legac
    I'm going to put this in here.
    How-To- Cheap REAR Endlink Upgrade for 1st/2nd Gen Legacies
    I bought FRONT ENDLINKS for a 2005 AUDI A4 QUATTRO 2.0L L4 Turbocharged
    ADM614 (AD-M614)
    ADM612 (AD-M612
    these are solid aluminum and cost $34.11 NEW w/new hardware.
    the only thing is the holes are off by 1/2"
    I saw a guy running these on a RS and I had to try it.
    Jul 2011
    Kelowna BC, Canada
    43
    2,789
    32
    Jul 2011
    Kelowna BC, Canada
    43
    2,789
    32
    Thanks Phi11, I ordered some of those audi endlinks to try out too.
    Jul 2005
    Apple Valley, MN
    866
    10,878
    69
    Quote Originally Posted by DevC
    yeah, it has to be one of the best mod i've done in awhile, no more body roll!
    Jul 2011
    Kelowna BC, Canada
    43
    2,789
    32
    I installed those audi endlinks, they bolted right in for me with the stock bar. Friend with an sti bar tried them and seemed to have an issue, perhaps the sti rear bar is slightly different.
    SLi Resident Baddog's Avatar
    Dec 2009
    Portland, Oregon USA
    935
    9,465
    Points: 9,465, Level: 65
    Level completed: 39%, Points required for next Level: 185
    Quote Originally Posted by phi11
    ADM614 (AD-M614)
    ADM612 (AD-M612
    So are those part numbers for the front or rear?
    Front links are a dogbone I thought o.O
    1996 Subaru Legacy L
    Jul 2005
    Apple Valley, MN
    866
    10,878
    69
    Dec 2009
    935
    9,465
    Ohhh. For the rear. Got it. Already have solids. Looking for fronts.
    Jul 2005
    Apple Valley, MN
    866
    10,878
    69
    I picked up these:
    my fronts were shot. I was going to make a set, but decided to buy the hardrace once.
    "FNG" legacy360.'s Avatar
    Mar 2012
    63
    2,416
    29
    Points: 2,416, Level: 29
    Level completed: 78%, Points required for next Level: 34
    what did you mean that they were off by 1/2? im really interested in these
    Jul 2005
    Apple Valley, MN
    866
    10,878
    69
    you can see in the photo that the holes are different distances.
    the audi endlink is smaller.
    Mar 2012
    63
    2,416
    29
    would this cause problems ? or could it work out?
    SLi nOOb
    Feb 2012
    199
    4,028
    Points: 4,028, Level: 40
    Level completed: 39%, Points required for next Level: 122
    Quote Originally Posted by legacy360.
    it's fine, look up why people run adjustable endlinks.
    SLi nOOb
    Feb 2012
    199
    4,028
    Finally picked up a pair of the Audi/VW front endlinks for the rears, such a big improvement over stock endlinks.
    "Proby"
    Mar 2012
    San Jose, CA
    235
    4,606
    43
    Points: 4,606, Level: 43
    Level completed: 28%, Points required for next Level: 144
    1000 Experience PointsO.G.
    Or make these Fatboy for all my Subies, big, fat, and chubby. Next is rear C link.
    03 350Z - 120K DD
    99 RS - Currently swapping JDM V9 207
    98 RS - 145K JDM 20K V4 WRX
    02 WRX - 150K DD
    95 Legacy Wagon - 200K Winter Tahoe tank
    3,542
    ADM614 (AD-M614)
    ADM612 (AD-M612
    It anyone is looking for cheap metal rear endlinks, Rock Auto has off brand Audi ones for $13 each plus shipping.
    http://www.rockauto.com/dbphp/x,carcode ... _Link.html
    "Proby" KNaph's Avatar
    Oct 2013
    Tacoma, Washington
    229
    6,116
    Points: 6,116, Level: 50
    Level completed: 83%, Points required for next Level: 34
    5000 Experience PointsVeteran
    Just FYI, if anyone wants to buy the ÜRO Parts Audi endlinks, they're threaded on one end.
    I bought them and had to drill/dremel out the threads so I could get the OEM hardware through.
    Also, there is a nut cast into one of the bushings, you could probably cut it off but I didn't bother with it since there seemed to be enough threads showing through.
    Example of what I mean:
    The top bushing is the threaded one that I had to grind out, and there is still that cast nut that the bolt is butted up against.
    1999 Outback On BC Racing coilovers and Desmond Regamasters
    "You ruined your car" - Dad
    "Your car looks good!" - Mom <--- Always the supportive one.
    SLi Lurker camroncamera's Avatar
    Feb 2012
    Vancouver, WA USA 98661
    343
    5,651
    48
    Points: 5,651, Level: 48
    Level completed: 51%, Points required for next Level: 99
    I was asked to update this thread with my experience. I purchased a pair of VAG front endlinks for my rear GT wagon swaybar upgrade (upgraded to an Outback bar from the Pick-n-Pull). Cost for the endlinks was around US$35 from my FLAPS down the street. My endlinks were unthreaded and no drilling, cutting, or modifications were needed. I did use a couple stainless washers as spacers. Setup has held up great for several months. The VW part numbers I used are:
    8D0 411 318 D - Passenger Side
    8D0 411 317 D - Driver's Side
  28. #28
    SLi Supporter Hinyo's Avatar
    Nov 2011
    Maryland
    483
    7,907
    59
    Points: 7,907, Level: 59
    Level completed: 79%, Points required for next Level: 43
    Tagger Second ClassSocial5000 Experience PointsO.G.
    pictures for the curious can be found here
    http://legacygt.com/forums/showthrea...01#post4797801
    1998 Subaru Legacy 2.5GT Sedan - Lucy
  29. #29
    9,857
    Quote Originally Posted by KNaph
    I just bought a grade 8 bolt that worked (much easier). I think it was M8x1.25, but I'd have to double check that to be sure.
