I've got some moderate experience removing some pretty stubborn bolts, but I have to admit I need some help here. I know the rear half of the bolt is free, because when I impact it I can see from the back side of the knuckle that the shaft rotating relative to the knuckle ever so slightly. It's the front half (the threaded side) that won't budge after all my effort.
I HAVE TRIED THE FOLLOWING ALREADY:
- PB'laster a few times over the course of several weeks, and ~15min before starting[/*:m:43lh6bkr]
- Good impact gun on an okay air supply (nut removed with little effort)[/*:m:43lh6bkr]
- Screwing a strut bolt to the front end of the bolt using a nut, and hitting it with a 4 lbs hand sledge (somewhat clever, see pic)[/*:m:43lh6bkr]
- Number 3 while impacting the back end at the same time (no fooling around, moderately well coordinated hits)[/*:m:43lh6bkr]
- Propane torch on the back part of the knuckle seizing the bolt, shortly followed by impacting (this broke the back half of the bolt free of the knuckle)[/*:m:43lh6bkr]
- Number 5 heating the front part (no luck from here on)[/*:m:43lh6bkr]
- Additionally I tried pulling hard on a wrench on the strut bolt I attached on the front side, while impacting the back (pretty clever)[/*:m:43lh6bkr]
- Number 7 but switching ends, with the wrench on the back pushing it up with a jack, and the impact gun on the front (pictured; brilliant, but still no dice)[/*:m:43lh6bkr]
- Number 8 but using cold (compressed air can upside-down) on the bolt instead of heat on the knuckle[/*:m:43lh6bkr]
And that's it, I'm out of ideas. Well, I have one more idea, number 8 but with a friend additionally hitting the knuckle with a hammer (this kind of perpendicular impact shock can help, it works wonders getting balljoints out). I could also get some MAP gas.
There is potentially an additional issue. Even though the back half of the bolt is free from the knuckle, it might still be seized in the bushing. The flex of the bushing might allow me to see the bolt is free from the knuckle but may be stopping it shortly after that. This gives me one more strange idea, to use that to my advantage -- I could also jack up the knuckle (compressing the suspension) because the angle of the control arms will have the bushings' twisting in a favorable direction.
EDIT: I'll add additional ideas and good suggestions here:
- I could also try applying heat to the threaded end of the bolt itself, using a large washer to protect the bushing[/*:m:43lh6bkr]
(Full Size Image)
