Cutting and pasting from an ooooollllldddd thread over in the Proven Power Bragging forum...
Originally Posted by
Patrick Olsen
Engine weights, part I. '98 DOHC EJ25, all stock. PS pump and alternator removed (since I don't have either for the EZ30 yet). Belts removed. Fluids drained. Engine mounts removed. Clutch removed. Flywheel still in place (22-23# from what everyone says here). Everything else is intact - A/C compressor is still there, intake and TB, sensors, hoses, wiring, etc etc.
262#, so that puts the weight of the EJ25 at 240# (with no flywheel).
Today I weighed the EZ30R. Similar conditions as above - no clutch or flywheel, fluids drained, intake & TB resting on top, no PS pump, no alternator, AC compressor lying on top. The AC compressor isn't the right one, but it should weigh within a couple/few pounds I think.
EZ30R weight - 312#
I used the same game scale that I used to weigh the EJ25D 4 years ago. It's been dropped and manhandled since then, so I'm not sure it's in the best of shape, but I weighed myself hanging from it and it was within ~4# of my bathroom scale.
I think when I weighed the EJ25D I lifted it with a ratchet strap, which only weighs ~3#. I don't remember if I accounted for that in the weight above. Today I lifted the EZ30R with a 4-point chain hoist, which weighs ~14#, so that's accounted for in the 312# total.
Since the scale isn't perfectly accurate, I'd say that weight is +/-10#. Most of the guesses I've seen for the EZ30R put its weight at 50-55# more than an EJ25. Based on my admittedly rough results, looks like the difference is a bit more than that.
