Results 1 to 3 of 3
Thread: High Beams on with Low Beams
    "Proby" legacyB4RSK's Avatar
    Aug 2007
    Ottawa, Ontario, Canada
    234
    6,774
    54
    Points: 6,774, Level: 54
    Level completed: 12%, Points required for next Level: 176
    Hi
    A few years ago I got instructions on how to wire my headlights so that I can have my low beams stay on when I turn on my high beams. Would anyone have this information as I need to put it back to stock. I need to have the low beams shutoff when the highbeams come on, for some reason the high beams in this configuration are very dim and the car will not pass a safety check.
    2001 Legacy GT with factory JDM HID headlights.
    Thanks
    SLi Lurker meepers's Avatar
    Sep 2010
    Phoenix, AZ
    423
    5,843
    Points: 5,843, Level: 49
    King of Publishing
    Sounds like a grounding issue. Basically just remove the wire you added to the relay! But I honestly have no idea what if any wiring differences are between my 2nd gen and your car.
    9,857
    I can't be sure with your JDM headlights, but Subaru typically uses a switched ground system with a common hot. Keep that in mind as you re-wire and check everything (preferably with a multi-meter).
