Results 1 to 12 of 12
Thread: WRX Springs on Forester Shocks? (BD5 Sedan)
    New User ItSuperPanda's Avatar
    May 2013
    3,095
    34
    Points: 3,095, Level: 34
    Level completed: 30%, Points required for next Level: 105
    1000 Experience PointsTagger Second ClassVeteran
    Ok so here is the deal:
    I Have a 1996 Legacy Sedan
    It came with Forester shocks and springs.
    I have 02 WRX Sedan Springs
    Here is the question:
    Will the WRX SPRINGS fit with the FORESTER SHOCKS?
    OR
    Do I have to get WRX SHOCKS?
    Can someone let me know? I'm building this car on a very limited budget.
    Most of the parts installed were either donated for this build, or were pulled from a Pick-N-Pull.
    Any and all POSITIVE help will be accepted.
    I just need to know what can and can't work with my current setup and current on-hand parts.
    Attached Picture is my actual car and how it currently sits.
    SLi Lurker meepers's Avatar
    Sep 2010
    Phoenix, AZ
    423
    5,843
    Points: 5,843, Level: 49
    King of Publishing
    I guess the best question to you is: What do you want to achieve, ride height, driving style. you honestly would be better off if you are trying to lower the car back down, seeing about swapping a local impreza guy who wants a lift. Putting shorter springs on the Forester rear struts may give you odd results.
    May 2013
    3,095
    34
    Well there aren't much Impreza let alone Subaru enthusiasts out here with older Imprezas let alone Legacys that would do that. So I just need to know if it is possible to use the WRX springs I have with the Forester struts that I have installed already.
    SLi Lurker foohfooh's Avatar
    Jan 2013
    Seattle/San Diego
    431
    5,362
    Points: 5,362, Level: 47
    Springs are 02 wrx sedan oem? What year forester struts are they?
    IF they fit they will wear the shocks prematurely because foresters have a taller strut.
    May 2013
    3,095
    34
    It's SF5 Forester suspension, so 98-02 Foz. And if I have to use the Forester shocks till I get WRX shocks I am ok with that. I am looking for the proper shocks daily.
    9,857
    You'll need the correct spring perches on the front & tophats on the rear (match the springs, not the struts), but I don't see why they wouldn't.
    That being said, SG Forester suspension is more similar to GD Impreza and they may be better matched. I'd be most worried about the rear spring rates & "saggy butt" on a Legacy with those sedan springs.
    ITSuperPanda - the struts are longer, however, the springs are similar enough in length that I wouldn't be too worried about that unless he was using lowering springs. It's worth noting that the strut length does not affect wear, but spring rate & length will.
    Sep 2009
    209 NorCal
    1,684
    13,292
    75
    Points: 13,292, Level: 75
    The fronts might work but the rears won't. The 02-03 wrx rear have a tapered springs while the forester is not. Maybe the 04-07 wrx lowering springs MIGHT work since they are not tapered.
    Where in CA are you located?
    May 2013
    3,095
    34
    Im just going to go with WRX Shocks since I still want to go lower than this raised forester height. Just need to find some cheap WRX shocks now. Haha
    9,857
    Quote Originally Posted by r3v_v3ng3 View Post
    I was under the impression the taper was at the top, which would affect the strut top (which is the spring perch) but not the bottom. Wasn't it 04 that they switched to a taper, or am I not remembering correctly?
    May 2013
    3,095
    34
    Ok, so I've finally gotten some decent money put aside for some decent suspension. NOW the questions is:
    Will THESE fit?
    http://www.ebay.com/itm/2002-2003-20...8d47b3&vxp=mtr
    I want to make sure before I just go and buy them and then they don't fit. Because IF they DO, then I will buy them. IF NOT, then my search continues.
    Also, I have heard that WRX springs on stock legacy shocks will work too. Is this correct or no?
    9,857
    They should on a BD/BG/BK - the rear tops will need to be rotated (I'm not a coilover expert, so I don't know if this is possible or not).
    WRX (02-07) springs will fit on Legacy shocks so long as the tops are intended to match the springs. Reusing your Legacy tops will likely not work on the rear (may on the front as long as the spring perch, which sits under the top, matches the Impreza springs).
    May 2013
    3,095
    34
    Ok. So some financial mishaps came up. So no Coilovers. But, am I to be under the impression that 1st gen Impreza shocks would work in place of legacy shocks, and will my 02 WRX springs work with the stock 1st gen Impreza shocks?
