Results 1 to 12 of 12
Thread: Hub interchangability
    3,542
    So my 98 L wagon 4eat needs a left rear wheel bearing. I am considering getting a lower miles hub with wheel bearing from a pick and pull. What I need to know is will a hub from another 2nd work even its a different final drive? I am trying to figure out if the spline count on the cv axle would be different for different final drive ratios. Thanks.
    SLi nOOb
    Feb 2012
    199
    4,028
    Points: 4,028, Level: 40
    Level completed: 39%, Points required for next Level: 122
    Veteran1000 Experience Points
    You know autozone advanced pepboys and sny aftermarket wheel bearing supplier has all that information right?
    3,542
    Yeah, but getting an entire hub/knuckle from the junkyard would save me a good bit of money. I have emailed a friend who owns a shop to see what he would charge me to replace the bearing.
    9,857
    I think the only difference in knuckles is between drum & disk brakes.
    The only problem with your idea is you have no idea what you're getting with a junkyard - it could have bad bearings, too, given how common the issue was.
    3,542
    Quote Originally Posted by Wiscon_Mark View Post
    Thanks for the info. I have considered it and know its a gamble. I am hoping my friend will cut me a deal on changing the wheel bearing.
    3,542
    Well my friend says about $400 including the parts. Looks like I will be taking my chances at the pick and pulls. Another question, I should be able to use a knuckle/hub from a 1st/2nd gen Impreza or Forester with disck brakes too right?
    SLi Lurker nepbug's Avatar
    Sep 2014
    Denver, CO
    412
    4,977
    Points: 4,977, Level: 45
    If you're up for it you can do the bearing yourself. About $100 for the bearing/seals and about $100 for the tool from Harbor Freight.
    http://www.harborfreight.com/fwd-fro...ers-66829.html
    Don't forget a 20% off coupon
    http://www.hfqpdb.com/
    Walk-through using the HF kit:
    http://forums.nasioc.com/forums/show....php?t=1925081
    3,542
    But the entire knuckle is about $20 from the pick and pull. I need to know if I am able to use a knuckle/hub from a 1st/2nd gen Impreza or Forester with disc brakes.
    Sep 2014
    Denver, CO
    412
    4,977
    Quote Originally Posted by 98legwag View Post
    First gen Impreza and Forester for sure
    http://opposedforces.com/parts/info/28411AA000/
    Second gen, I think is also compatible, I'm just not entirely sure if there were any changes to the caliper mounting points.
    $20 is pretty cheap and probably worth the gamble. Just keep in mind that there is a high likelihood that you will be fighting the removal of the lateral link bolt and might also have to fight the axle removal.
    I've had to remove entire lateral links because of bolts seized in bushings. And I also had to replace an axle before because I couldn't get it out of an old knuckle, bent my 12 ton hydraulic press trying to get it out!
    So, I recommend putting a hand sledge in with your tools when you go to pull them, just in case you're having to beat on some stuff.
    3,542
    Yeah, I am going with a few friends on Sunday. I just have to remember to take a 32mm socket for the axle nut. Two 99 Legacys went into the yard yesterday.
    SLi nOOb Alphius's Avatar
    Aug 2009
    Rochester, WA
    149
    6,489
    52
    Points: 6,489, Level: 52
    Level completed: 70%, Points required for next Level: 61
    Second gens don't eat wheel bearings as bad as later cars. In fact, my 230k mile Legacy has all original hubs and they are dead silent with no play. I've had plenty of good luck finding the cleanest, nicest looking hub in the junkyard and taking the whole spindle. In my mind, it's a no-brainer to spend the $20-30 instead of $400 and the likelihood of the replacement hub lasting another few years is really good. If it breaks within 30 days, I go get another one for free.
    You can use the rear hubs from any disc brake equipped 90-99 Legacy, 93-07 Impreza or 98-08 Forester I am pretty sure.
    99 Legacy GT WRX - Now for sale!
    05 Legacy GT Limited 5MT Wagon - Stock-ish.
    02 Outback Limited 5MT - Lifted, Dual Range
    84 Camaro Z28 - LS1/6-speed
    85 Silverado - Low and slow tow rig
    3,542
    Thats exactly what I am thinking. My car has 175k miles and this is the first bad wheel bearing.
