Results 1 to 4 of 4
Thread: 9006 Bulb Upgrade
    3,542
    9006 Bulb Upgrade
    So I have been looking around at what bulbs could be used as upgrades for the fog lights on my 09. I came across using a HIR2/9012 bulb. It uses the same connector as a 9006 bulb but the tab at the top of the bulb is slightly larger. It just needs to be trimmed down.
    http://ep.yimg.com/ca/I/yhst-91565365470012_2267_311973
    The HIR2/9012 bulb uses the same 55 watts and should last as long. It puts out about 2400 lumens vs the 9006 bulbs put out somewhere around 1000-1500 lumens, based on what I have read. This would be a good upgrade on 2nd gen one piece headlights or Outback fog lights.
    If you are interested in buying them:
    http://www.amazon.com/Philips-9012-Stan ... B00480N18G
    http://www.homedepot.com/p/Philips-HIR2 ... /203654603
    Sep 2012
    Rochester, NY
    32
    3,343
    35
    Points: 3,343, Level: 35
    Level completed: 96%, Points required for next Level: 7
    Hey 98legwag, how did these work out in your foglights? Are they really that much brighter? How would you rate em?
    -Matt
    • 12 Cruze
    • 98 Legacy Outback Limited
    • 91 MR2 Turbo - sold
    SLi Lurker nepbug's Avatar
    Sep 2014
    Denver, CO
    412
    4,977
    Points: 4,977, Level: 45
    Yeah, I've been waiting to find a good deal on those myself. My 01 also uses the 9012 for upgrading the fogs, I can also go to the 9011 to upgrade the high beams. the bulbs are all about $30 each, so I'm holding off on that. If they were the low beams I could more easily justify it.
    Sep 2012
    Rochester, NY
    32
    3,343
    35
    What would be a great upgrade would be to get clearer fog light lenses. I cleaned up my headlights, made a big difference. The fog lights seem cloudy, which has to cut down on output/visibility.
    -Matt
    • 12 Cruze
