Results 1 to 3 of 3
Thread: Ej20tt no boost
    Joepeace
    Guest
    Ej20tt no boost
    Hey guys. I'm sure this has happened already but I got a bd5 legacy TT and it won't boost anymore. At low speeds there is no boost at all and the vacuum is high high speed the boost will kickin about .6 bar but only for a sec. Checked for boost and vacuum leaks but found nothing. Noticed secondary turbo has oil leaking inside of air outlet. Would the secondary turbo being faulty cause no boost at all? Thanks for any help or advice!!
    SLi Resident Cervantes's Avatar
    Apr 2010
    Okinawa, Japan
    631
    6,695
    53
    Points: 6,695, Level: 53
    Level completed: 73%, Points required for next Level: 55
    Re: Ej20tt no boost
    Turbo is probably bad
    2000 Subaru Legacy Blitzen SOLD
    2001 Subaru Forester STI
    2000 Subaru Impreza S203 Swap
    Jan 2015
    Russia
    20
    1,071
    17
    Points: 1,071, Level: 17
    Level completed: 72%, Points required for next Level: 29
    Hello. I think secondary turbo cannot be a reason of no boost at primary.
    Did you have primary turbo boost earlier?
    After what you've lost primary boost?
