First time I detailed it.
Co-workers/GTI Gang
Base numbers
R8 Coils
Nothing fancy
Putting the boy to work
"Mod" list
■Cobb Accessport
■Stratified tune
Maintenance + updates
■ Fuel filter 6.6 bar w/regulator
■ Timing chain tensioner update kit
■ Updated PCV
■ Belt tensioner
■ K&N Panel filter
■ ECS turbo inlet hose elbow
■ ECS throttle pipe
■ Go Fast Bits DV+
■ Updated Diverter valve (Revision D)
■ ARP Ignition coil packs
■ NGK Iridium plugs 1 step colder .025 gap
■ Fluidamper Crank pulley
■ Gruven Alt pulley
■ Gruven Tensioner pulley
■ HPA K04 Turbo
■ IE 3" Down pipe
Drivetrain
■Clutch Masters Stage 2 clutch kit
■ECS SS braided clutch hose
■ECS Aluminum clutch bleeder block
If you need any genuine Vdub parts-let me know-I work part time at a dealership for the past two 1/2 years-and driving a '23 wrx for the past year
