Results 1 to 2 of 2
Thread: Clutch pedal getting stickey and wont return back
    Hi All,
    I have a 2000 Gen 3 B4, When driving, I can get the clutch to the floor but it sometimes doesn't return back, I have to pull it back with my foot. Can anyone tell me if it is a simple fix? I've been able to take the top off the reservoir bottle in the engine bay and pump the clutch a few times. It does bring the force back into the clutch, It it seems I have to do this more often now.
    Do you think it would be a cheap enough fix?
    SLi nOOb AssYriaNrocKer's Avatar
    May 2012
    165
    4,045
    Points: 4,045, Level: 40
    Level completed: 48%, Points required for next Level: 105
    Possible air in hydraulic system. leaking slave cylinder? leaking slave cylinder hose? failed clutch cylinder or slave?
    -RONI-
