Results 1 to 2 of 2
Thread: Lower piping of radiator has oil
    "FNG" vanislebh5's Avatar
    Jan 2023
    Vancouver Island
    67
    Angry Lower piping of radiator has oil
    I did my timing belt , when I removed the 2 lower smaller pipes , oil was dripping instead of coolant , I believe that is going to the Turbo ,
    To make thing worst now the radiator leaks , it did not before the timing belt , I did change the water pump and thermostat , I believe the thermostat was stuck open before the change
    does the lower part of the radiator has a separate cooling system just for the turbo ?
    Thanks !
    Jan 2023
    Vancouver Island
    67
    Quote Originally Posted by vanislebh5 View Post
    Thanks !
    So just figured out the lower portion of the radiator is a transmission oil cooler , so everything is perfectly normal
