Results 1 to 6 of 6
Thread: 2003 L suspention
    Jul 2005
    Al-bany
    29
    7,244
    56
    Points: 7,244, Level: 56
    Level completed: 47%, Points required for next Level: 106
    2003 L suspention
    Can somebody tell me what EXACTLY is so bad about lowering a 2003 Legacy sedan that no manufacturers will make springs that fit it...except whiteline...anyways, does the AWD shit the bed because of the changes in the center of gravity?
    ps. im new by the way. hi everybody.[/img]
    oh god...the aftermath...
    http://www.ogodtheaftermath.com/splash.html
    100% canadian specimen.
    SLi nOOb fibuz's Avatar
    USA
    102
    7,938
    59
    Points: 7,938, Level: 59
    Level completed: 94%, Points required for next Level: 12
    Actually, several companies make springs for your car...ION, H&R, Whiteline...and probably a few others. I would reccomend upgrading struts at the same time, as well, as they will most likely be killed by aftermarket springs.
    There are also several aftermarket coilover options available at hefty prices.
    The bottom line is that there is not a whole lot of aftermarket support for the BE/BH, but there is stuff out there if you look hard enough.
    fibuz
    BE -> GD -> GR -> SG + BL
    "Proby"
    Federal Way, WA
    243
    7,963
    60
    Points: 7,963, Level: 60
    Level completed: 7%, Points required for next Level: 187
    Hey guys, is that chassis compatible with WRX stuff, like ours?
    Norma,
    Subaru suspension has this tendancy to be akin to legos; most parts fit, and with little tweaks here and there, can fit and perform better than stock. Your model, however, seems to be the Camry of Subaru models; there's not really a mod market.
    Would B4 Legacy stuff fit? If that does, then so might many stock and aftermarket WRX parts. . .
    Good looking car, and nice to have another female here!
    Quote Originally Posted by Wiscon_Mark
    I'd challenge you but you have a lot more knowhow than I do...it would be like racing a Justy stock against an STi
    '92 BC676 NA AT AWD
    Borla 2.5RS Headers
    2.25" catback exhaust
    Custom Interior
    USA
    102
    7,938
    59
    For the most part, BE/BH Legacy suspension stuff is not interchangable with WRX stuff....or older Legacy stuff.
    B4 Legacy stuff is interchangeable, and probably widely available down in Aussie land. The only B4 Legacy stuff you need to be careful with is body parts, as there were several revisions.
    fibuz
    SLi Lurker Pwise2326's Avatar
    Naugatuck, CT, USA
    376
    9,358
    Points: 9,358, Level: 65
    Level completed: 3%, Points required for next Level: 292
    Exactly, WRX stuff won't work out because the rear suspension utilizes shocks, not struts per say, but you could find a set of B4 Bilstein strut/shock takeoffs from a JDM importer ( www.jdmplace.com , www.jdmpartstx.com , etc) or contact a bilstein dealer and I'm sure they could get you a set of them. For springs, you can use anything made for the BE -- H&R's will probably give you the most drop, whiteline, prodrive (they do make prodrive springs for the BE, check out www.racecompengineering.com for prodrive stuff, they are an authorized dealer and can find you anything you need at a great price (they found a BD prodrive spring set for me, but I opted to do the WRX swap with STI pinks instead). Check those places out, I'm sure you'd be able to find upgraded tophats as well.
    Ryan
    "Retired" Site Admin
    2007 Ford F-150 FX4
    2007 Yamaha R1
    MY98 Legacy GT 5MT BD QSM **Sold/R.I.P**
    02 WRX suspension conversion w/STI Pink springs
    "Ridin' on Pinks"
    http://www.cardomain.com/id/pwise2326
    7
    6,907
    54
    Points: 6,907, Level: 54
    Level completed: 79%, Points required for next Level: 43
    I'm looking to put on the ION springs to the OEM struts, anyone has experience on this? Will the springs overkill the stocker?
    Is ION any better than H&R?
    I have a "BH"
    thanks
