Results 1 to 5 of 5
Thread: 97 Legacy GT Questions
    Philadelphia, PA
    63
    7,367
    57
    Points: 7,367, Level: 57
    Level completed: 9%, Points required for next Level: 183
    I am in the research stage of putting a new suspension in my car. I won't have the money till I start my new job (in October), so I feel this gives me a good time to research. Also I am debating doing this right now for two reasons: 1) winter is comming up and 2) I might wanna start auto-xing (Hyperfest got me hooked) and I want to run stock to make the competition easier.
    I been reading a lot, but half the stuff I hear different answers for. So here goes:
    I wanna change out the spring/shock/top hat. I heard I must do the top hat cause the shocks (plannin on AGX's) wont fit, and its generally a good idea to upgrade the hats anyways. Which top hats can I get? I know to get group N ones but I see some specifically for 02-03 WRX, some for GC, some for STI. Which ones can I use?
    Two: When I change everything over, what are all the little things I need that I do not currently have? (such as the spring seats, rings, whatever it is)
    Three: Because I have an audio system in the car presently, and ION performance (Thinking of getting their sport spec springs) says I will get more sag in the rear cause the perches in the GC are different, is there something I can do to offset the extra sag?
    Thanks
    (Wow I am long winded sometimes)
    "FNG" Jonathan's Avatar
    Natick, Massachusetts
    75
    7,339
    56
    Points: 7,339, Level: 56
    Level completed: 95%, Points required for next Level: 11
    While iON does make springs for the 3rd generartion Legacys, I did not know that they did springs specifically for the 2nd generation Legacys.
    Using springs designed for the pre-2002 RS, 3rd gen legacys, or the WRXs may work out okay, however they weren't designed for our vehicles so I would be leary of using them.
    I was told (on the nabisco board) that eibach progressive springs are the best for our 2nd generation Legacys.
    H&R springs (sold by the tyre rack) are relatively innexpensive although they are perhaps a little on the firm side.
    Whiteline springs are a little pricey but I am told work really well.
    KYB AGX adjustable struts are suppost to be really good, and yes getting the correct tophats is essential.
    PS. I am no expert on Legacy suspensions. I am still attempting to figure out whats best for my 1996 Legacy "L". I am only 'parroting' what I have read from others, and I am not speaking form personal experiance. Please feel free to correct me on any points, make alternative suggestions, etc...
    t3h ub3r m3mber Perdue's Avatar
    Barboursville, WV
    1,084
    13,062
    Points: 13,062, Level: 74
    Level completed: 53%, Points required for next Level: 188
    Activity Award
    I wasn't aware that there were BD/BG Specific AGX Struts. If you're going to use these, You're going to need top hats and springs that are specific to the strut you're using. There are a lot of Legacys running around with WRX suspensions, which lower the car a little more. The spring rates in rear are rated at 300lbs less I believe, but sagging shouldn't be much of a problem in a sedan.
    Currently, I'm running H&R Sport Springs and KYB GR2 Struts on my 98 sedan, both legacy specific. They're backed with a Whiteline Adjustable Rear Swaybar, Cusco Type OS Front Strut Tower Bar (Pretty much bling if you ask me), and Yokohama ES100s. The next route is an anti-lift kit, and I'll be pretty much done with the acception of some group-n tophats when I go to change out struts. I'm pretty satisfied with my handling, but as Johnathan stated, the ride from the H&R springs is pretty stiff.
    As far as the audio system, I'm guessing it depends on how much of a system you have. I have a single 12 that really doesn't weight too much with amp and box. I used to run a dual 12/dual amp setup and it did sag a tad on the stock suspension, but it wasn't a lot to be noticeable.
    John Perdue
    1998 Subaru Legacy GT
    2004 Subaru Outback
    2013 Ford F-150
    SLi Resident
    Jun 2005
    San Jose, "The Capital of Silicon Valley"
    609
    9,043
    63
    Points: 9,043, Level: 63
    Level completed: 98%, Points required for next Level: 7
    the agx has the same part number as the gc, iirc. Same goes for the gr2.
    1990 subaru legacy- i miss you!
    1999 outback 30th deluxe deluxe megafantastic orgasmmobile
    subaru has more R&D money than the aftermarket.
    "FNG" jlk2.5gt's Avatar
    Oct 2005
    mid west
    7,153
    56
    Points: 7,153, Level: 56
    Level completed: 2%, Points required for next Level: 197
    suspension
    i am pleased with my kybg2 struts and h&r springs it has a nice ride to it. i have also been pleased with whitelines sway bars, strut brace, rear contol arms, and the rest of their line, everything fit properly, and the car handles awesome now
    1997 legacy gt - something new done every week or so
