Results 1 to 4 of 4
Thread: Lowering the sedan. Will this work??? *link included*
    Drama Queen 2.0
    Not here! :-)
    611
    9,856
    Points: 9,856, Level: 66
    Level completed: 52%, Points required for next Level: 194
    I am looking to lower the 93 sedan and I need to know if these will work:
    http://cgi.ebay.com/ebaymotors/SUBARU-9 ... dZViewItem
    http://cgi.ebay.com/ebaymotors/GROUND-C ... dZViewItem
    Any and all help will greatly be appreciated.
    SLi Supporter galek_98gt's Avatar
    Austin, TX
    224
    7,884
    59
    Points: 7,884, Level: 59
    Level completed: 67%, Points required for next Level: 66
    IN for answer cause i'd like to know too.
    Needs to update their Email!
    SALE SALE SALE!!!
    465
    8,826
    63
    Points: 8,826, Level: 63
    2DL, First off, I'd go for the Ground Control brand name if you can.
    2nd, I'd go with suspension meant for the GC Impreza. Cause, if I remember correctly, BC Legacys have been known to run around with Ver5 suspension. I've also seen them with JDM GC Impreza carbon fiber strut tower braces and aluminum control arms....sick stuff.
    Anyway, I wouldn't trust your suspension with a no-namer.
    I'm none too sure about WRX suspension fitment on a BC. Your BC doesn't weigh close to the portly numbers of the GD.
    So I'd say keep searching for barely used or never used Ground Control sleeve kit.
    Add-on? Koni inserts in your OEM strut housings. I've seen that combo on some boards. Koni inserts in OEM strut housings and Ground Control coil-over sleeve kit.
    Anyone else??
    GGT
    2007 Subaru Legacy 2.5GT spec.B DGM 6MT w/ 4 exhaust tips, 3 LSDs, 225's, stage2!
    Wanna see it?
    - traded - 2000 Coma 4x4 AT reg cab - black
    - stillborn - 1995 Legacy wagon w/ JDM Ver8 (VF37) & JDM 6MT - 3 LSDs @ +350hp
    - no more - 98 BD 2.5GT 5MT BGP -115,000 miles
    SLi Resident
    Jun 2005
    San Jose, "The Capital of Silicon Valley"
    609
    9,043
    63
    Points: 9,043, Level: 63
    Level completed: 98%, Points required for next Level: 7
    Yes, they will work. You will have to get the appropriate front spring perches.
    i encourage you not to skimp on suspension. Duct tape holding your cone air
    filter is one thing, but having a suspension component fail is pure badness.
    Who knows what was involved in designing those things.
    No preload is a dangerous possibility when you lower with those. Ground
    Control stuff is just meant for corner weighting and giving more spring
    rate options.
    People have reported good things about wrx suspension on a bc, although
    assuming front/rear preload ratio is the same (wow, that sounds super
    techy) the wrx is less sprung in the rear.
    I have gc 2.5rs front springs at all 4 corners, and it's an excellent match.
    Slightly lowered. I have pics running around all over the net.
    1990 subaru legacy- i miss you!
    1999 outback 30th deluxe deluxe megafantastic orgasmmobile
    subaru has more R&D money than the aftermarket.
