Results 1 to 6 of 6
Thread: STU Classifications
    t3h ub3r m3mber deadlydave's Avatar
    Albany, NY
    1,879
    13,439
    75
    Points: 13,439, Level: 75
    Level completed: 48%, Points required for next Level: 211
    STU Classifications
    With the brake upgrade and such, The Baja-Turbo is no longer fit for Autocross duty in stock class.
    So, my target is STU. Is there anything I should watch out for? I don't want to get forced into SM...
    Is the 245 width tire restriction for all AWD vehicles still in effect for 2008. (I only have the 2007 Rulebook). Is the 7.5" Wheel/Rim width restriction still in effect? Would an exhaust bypass throw me out of STU?
    1996 Impreza WRX STI V2 wagon
    SLi nOOb
    Jul 2006
    Woodstock, NY
    147
    6,655
    53
    Points: 6,655, Level: 53
    Level completed: 53%, Points required for next Level: 95
    what group puts on the autocross events you attend? You're up near Troy right? I'd like to take the wagon for a spin in an autocross. I haven't autocrossed in years.
    - Juinior
    www.trdsupra.com
    1995 Legacy L Wagon - WRX suspension, STi exhaust, lowered, whiteline rear sway, greddy emanage, DIS-2 and a crazy turbo motor that's been sitting on an engine stand for a year waiting to go in
    1998 Jaguar XJR
    1996 Audi A4 Quattro with a long list of very custom mods
    1989 Toyota Supra Turbo - Twin Turbo 7M (the long haul project)
    Albany, NY
    1,879
    13,439
    75
    Quote Originally Posted by SammyDaFish
    It's the Mohawk-Hudson Valley SCCA chapter. They have recently switched to running in a large parking lot in Albany/Bethlehem. Sometimes the events are as far north as Adirondack Community college. Come on up.
    SLi Supporter Mr. Sociable's Avatar
    Sep 2007
    Lakewood, CO and Bozeman, MT
    479
    6,612
    53
    Points: 6,612, Level: 53
    Level completed: 31%, Points required for next Level: 138
    Ok. I may never have raced before, but I've been (trying) to do my research. From my Autocrossing Performance Handbook for STU it says:
    SCCA Allowed Modifications
    Suspension
    Aftermarket Shocks w/ more than 2 external adj. - Yes
    Any shock absorber bushing (not offset) - Yes
    Aftermarket shocks w/ external resivors - Yes
    Springs - Yes
    Front Sway Bar - Yes
    Rear Sway Bar - Yes
    Strut Tower Bars - Yes
    Tie Bars - Yes
    Aftermarket suspension bushings - Yes
    Crash Bolts - Yes
    Camber Plates - Yes
    Traction Bars, torque arms - Yes
    Panhard Bar - Yes
    Camber Kits - Yes
    Subframe connectors - No
    Wheels and Tires
    Street Tires (treadwear rating 140 or higher) - Yes (up to 245 width for AWD)
    DOT-approved R-compound tires - No
    Racing Slicks - No
    Wheels, stock diameter, width, and offset +/-0.25" - Yes
    Wheels, any diameter - Yes
    Engine
    Alternate Air Filter - Yes
    Alternate Air intake - Yes
    Alternate throttle body - No
    Intake Manifold - No
    Header(s) - Yes
    Catalytic Converter - Yes
    Exhaust (cat back) - Yes
    ECU - Yes (no boost changes)
    VTEC controller - Yes
    Short Throw Shifter - Yes
    Accessory Pulleys - Yes
    Cams - No
    Cam gears - No
    Pistons - No
    Valvetrain - No
    Connexting Rods - No
    Crankshaft - No
    Headwork - No
    Motor Mounts - Yes
    Spark plugs and wires - Yes
    Replace intercooler - No
    Add Intercooler - No
    Replace/add turbo - No
    Accusump-type system - No
    Alternate Fuel Pump - No
    Replace Engine - No
    Brakes
    Aftermarket brake pads/shoes - Yes
    Stock size/type rotors or drums - Yes
    Cross Drilled/slotted rotors - Yes
    Replace drums with rotors/calipers - NO ANSWER
    Replace stock rotors and/or calipers with larger units - Yes
    DOT-Approved replacement brake lines - Yes
    Addition of cooling ducts - NO ANSWER
    Speedbleeders or alternate bleeder fittings - Yes
    Body Work
    Do I really have to type this out? It's super long.
    Transmission
    Add/replace LSD - Yes
    Replace transmission - No
    Gears - No
    Differential - No
    Driveshaft - No
    Clutch - No
    Flywheel - No
    Other
    Keep your stock size/shape/voltage battery and leave your ABS and power steering.
    Now its a copyright 2007 book so I don't know if those are the 2008 rules or not. I don't even know if that helps you in any way, but thats what info I can provide. Sorry if you didn't need all that. [/list]
    2005 Saab 9-2x
    Xbox Live gamertag: MrSociable - Forza 2, Halo 3, CoD4, and CoD5
    Albany, NY
    1,879
    13,439
    75
    Thanks for the help! That looks correct--i checked in the scca 2008 rulebook.
    However, due to the addition of a new hood in the spring, I will be bumped to Street Mod. Whereupon, I will be spanked.
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Points: 18,003, Level: 85
    Level completed: 31%, Points required for next Level: 347
    Discussion Ender
    Yeah, the only thing you have to watch out for is the new catalytic converter rules in STU/STX.
    I think you can't run an "aftermarket cat" now or something to that effect. A few guys had to ditch their catted DP's because of it (I scored a Helix catted DP for $120 from an autox friend of mine because of it )
    2005 Outback XT
    2003 Legacy L "Special" Edition...RIP CLICK HERE
    GO > Show. Every time.
    STI is the new medically accepted term for STD.
