I'm waiting for the rest of my timing belt kit to arrive along with some gaskets but I have a question about the shims for the valves I have a inch micrometer that does 0.0001" From what I understand to find what replacement shim size I need I do this:
1.) check current clearance with a feeler gauge mark the number
2.) look at the current installed shim size
3.) find a shim that puts the valve back into spec?
My question is do I have to subtract anything as far as the clearance for the replacement shim?
This is my first time owning a vernier mic I'm just getting confused reading the ten thousandths part
