Page 5 of 5 FirstFirst ... 345
Results 121 to 135 of 135
Thread: DIY: Interior Lighting Part 1 (Gauge Cluster)
  1. #121
    Jun 2011
    Elizabethtown, PA
    3
    3,274
    35
    Points: 3,274, Level: 35
    Level completed: 50%, Points required for next Level: 76
    Re: Interior Lighting Part 1 (56k, go fly a kite)
    csweston, do you happen to have the part numbers handy?
    Mike Boerger
    Elizabethtown PA
  2. #122
    "FNG" Quest's Avatar
    May 2011
    Reston Virginia
    53
    3,421
    36
    Points: 3,421, Level: 36
    Level completed: 48%, Points required for next Level: 79
    The part# for the "idiot" bulb & socket is 85066GA110. I had to replace 1 when I was back there. Stealership wanted $12 something for it. The bulb itself is replaceable but they're tough to pull from the little socket. I noticed after replacing the individual gauges into the cluster that I had a little gap between the gauge face and the black plastic trim. The trim I'm referring to is within the clear housing that has cutouts for the actual gauges. The reason this happened is when reassembling the gauges to the cluster they weren't perfectly lined up. Turns out the gauges have tiny holes and the trim that goes over them has corresponding nubs that line up. If not perfect, there will be a gap. Loosen all the screws on the back of the gauges and reposition so they mate perfectly. The screws must be good and tight because that's how they get all of the electrical connections. I did mine in "cool white" for the cluster and HVAC. http://www.superbrightleds.com/cgi-b...sp=%2F1157.htm
    Parts list:
    qty.(2)SMALL CLUSTER BULBS@74-xHP: Wedge Base LED Bulb
    Options: 74-WHP: Cool White
    qty.(3)HVAC BULBS@NEOx-xHP: NEOx High Power LED Instrument bulb
    Options: NEO3-WHP: 3mm NEO3-xHP Cool White
    qty.(4)LARGE CLUSTER BULBS@WLED-x5: 5 LED T10 Wide Angle Wedge Base Bulb
    Options: WLED-CW5: Cool White
    Do not get high power for the 4 large cluster bulbs, too bright, they will overwhelm the blend.
    1 of the 3 HVAC bulbs will require modification. I had to take a razor and carefully remove the LED head along with the resistor and diode and mount it in the long housing of the old bulb.
    96 Legacy L 2.2 4eat Debadged
    The Fuji FA-200 Aero Subaru is a single-engine piston-powered airplane built by Fuji Heavy Industries, Ltd. of Japan
  3. #123
    Jun 2011
    Elizabethtown, PA
    3
    3,274
    35
    Thank you so much!
    Mike Boerger
    Elizabethtown PA
  4. #124
    SLi O.G. httrdd's Avatar
    NEPA
    2,700
    11,761
    Points: 11,761, Level: 71
    Thanks for the info. I got white overlays and I am going to sand theold gauges to show the light through.
    TJ
    99 LGT H6 Limited OBP
  5. #125
    9,857
    bump for updated info in the original post and I added a link to another DIY that uses a different take on this mod that's worth a look! (see original post)
  6. #126
    "FNG" legacy360.'s Avatar
    Mar 2012
    63
    2,416
    29
    Points: 2,416, Level: 29
    Level completed: 78%, Points required for next Level: 34
    just did this mod. love it so much better then the stock green.
  7. #127
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,526
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    I just did this yesterday using red LEDS from super bright LEDS. I also added more reflective tape to the area shown here:
    What that did was reflect more light down in front of the gauges. This also helped to eliminate the hot spots from the LEDS.
  8. #128
    SLi Lurker Zangado1's Avatar
    Jun 2012
    K.O.P.,Pennsylvania
    426
    5,869
    Points: 5,869, Level: 49
    Level completed: 60%, Points required for next Level: 81
    Tagger Second ClassVeteranCreated Album pictures5000 Experience Points
    Great step by step "How To" Thank's for your effort in doing this,another cool project to tackle.
    1995 AWD Legacy L wagon 5MT (DD)
    2005 Subaru Legacy GT Limited 5MT
  9. #129
    Mar 2012
    63
    2,416
    29
    here is mine (better photo soon)
    Uploaded with ImageShack.us
  10. #130
    SLi Lurker Sub-Goon's Avatar
    Feb 2013
    Oakland, CA
    431
    2,599
    30
    Points: 2,599, Level: 30
    Quote Originally Posted by 1-3-2-4
    All done!
    High
    If I had air suspension
    The white looks really good! How is it on the eyes?
    I've been wondering how many unused sensor lights there are and what they are for! Especially hoping that there is one for the 4EAT Power Mode!
    In this pic, I am seeing 9 unused sensor/warning lights, unused! Can someone take some pics using a minimaglite to illuminate them? Also, I see 4 socket holes at the top center, wonder what these are for?? And it might look good to put the auto-shift selector in the middle, I know the Gen3Legacy/Gen2Outback uses this, maybe it could be added? Lots of ways to go with this!
  11. #131
    Moco, Maryland
    3,526
    16,957
    Quote Originally Posted by 98legwag
    One of my LEDs decided to only work half the time. Gotta take the cluster out to try to figure it out.
  12. #132
    "Proby"
    Mar 2012
    San Jose, CA
    235
    4,606
    43
    Points: 4,606, Level: 43
    Level completed: 28%, Points required for next Level: 144
    Blue LED on my RS
    03 350Z - 120K DD
    99 RS - Currently swapping JDM V9 207
    98 RS - 145K JDM 20K V4 WRX
    02 WRX - 150K DD
    95 Legacy Wagon - 200K Winter Tahoe tank
  13. #133
    t3h ub3r m3mber superu's Avatar
    Mar 2010
    Moab
    1,032
    7,787
    59
    Points: 7,787, Level: 59
    5000 Experience PointsSocialO.G.
    [quote=Sub-Goon]
    Quote Originally Posted by "1-3-2-4":28v13qor
    [/quote:28v13qor]
    95 BD:
  14. #134
    "FNG" Patrick Olsen's Avatar
    Aug 2009
    Where the Navy sends me...
    51
    5,822
    Points: 5,822, Level: 49
    Level completed: 36%, Points required for next Level: 128
    Bumping an old thread to show a '97 2.5GT cluster in comparison to the '95 cluster above. The gauges are the same, all the stuff along the bottom is the same, but the top center stuff is different.
    Some of the little baby bulbs are removed in that shot of the rear. What I thought was kind of strange was that some of the unused indications didn't even have bulbs (the two TCS ones), but some of them did (FWD, ATF hi temp).
    Speaking of little baby bulbs, anyone know what the little ones are? I don't think any of mine are burned out, even after 17+ years and 230k+ miles, but it would be nice to know for the future. By my count there are 17 of them in my cluster - 11 go to red indications, 1 blue, 2 green, and 3 yellow/amber. (All the bulbs are clear, of course.)
    And in case anyone is curious, the trim rings around the gauges are actually aluminum. I found them on Ebay UK years ago. (Not sure how I found them, as I can't say I've ever made it a habit to spend any time browsing Ebay UK, but I stumbled across them one way or another!)
    Pat Olsen
    '97 Legacy 2.5GT sedan - RCE Tarmac2 coilovers, 4-pots front, H6 rears, '06 STI 6-speed, Quaife rear diff, mAd N/A powah!
  15. #135
    Aug 2009
    51
    5,822
    Quote Originally Posted by Patrick Olsen View Post
    I discovered that the bulb on the 5" Autometer tach in my Mustang is the same as the little bulbs in the instrument cluster. They're #86/74/T5. Plenty of options on Ebay in various colors.
