Page 1 of 2 12 LastLast
Results 1 to 30 of 40
Thread: JDM Subaru Legacy BG5 Digital Climate Control System
    New User MountainBayer's Avatar
    May 2010
    Seattle, Washington
    13
    3,642
    37
    Points: 3,642, Level: 37
    Level completed: 95%, Points required for next Level: 8
    I have a 1998 subaru legacy L sedan 2.2 L and recently bought a JDM digital climate control system, i have been researching on my own trying to find out how to swap out the stock (manual) one with the auto climate control but i havent had much luck. The package that i bought had the;
    Head Unit
    Complete dash Harness ( but its for a Right hand drive car so its not an exact swap, conectors are diff. ect.)
    Out Side Air Temp Sensor
    Sun load Sensor w/ vent cover
    High speed fan relay
    Inside air temp sensor with tube
    Air Mix Motors with linkage
    Blower Motor Resistor
    i was wondering if anyone has done this conversion before or if they have any info that could help? Like wiring diagrams or pin layouts for the JDM automatic digital climate control?
    Guest
    Re: JDM Subaru Legacy BG5 Digital Climate Control System
    i think there's issues with the manual heater manifold control that causes it to be incompatible with US cars
    May 2010
    Seattle, Washington
    13
    3,642
    37
    i figured i might have a few problem that ill run into and have to create my own modification, but right now all i really need is a wiring diagram and pin layout of the JDM head unit itself so i can find out what wire should be power, AC ect...any info helps though
    May 2010
    Seattle, Washington
    13
    3,642
    37
    JDM automatic climate control head unit
    May 2010
    Seattle, Washington
    13
    3,642
    37
    Climate control sensors and motors
    May 2010
    Seattle, Washington
    13
    3,642
    37
    as you can see i should have everything i need, all i need to know is a wiring diagram or pinout for the control unit. because i cant just plug and play with the wiring harness supplied, (its for a JDM right hand drive vehicleso the connectors and wires are different)
    SLi O.G. httrdd's Avatar
    NEPA
    2,700
    11,761
    Points: 11,761, Level: 71
    Doesn't the compressor run at different speeds according to demand?
    TJ
    99 LGT H6 Limited OBP
    May 2010
    Seattle, Washington
    13
    3,642
    37
    any info on the wiring diagram/pin layout would help?
    if you have any info on the JDM BD5/BG5 auto digital climate control please post it or let me know where i can find it, thanks
    MD, USA
    2,613
    17,786
    Points: 17,786, Level: 84
    Community Award
    Quote Originally Posted by MountainBayer
    I have the wiring diagram and pin layout at home. If you would PM me when I return in a couple weeks, I'd be more than happy to scan and upload it for you.
    May 2010
    Seattle, Washington
    13
    3,642
    37
    Awsome, ill make sure to do that cause that would be extremely helpfull
    thanks
    SLi nOOb chaksq's Avatar
    North NJ
    194
    6,151
    51
    Points: 6,151, Level: 51
    Level completed: 1%, Points required for next Level: 199
    Finally someone is doing this swap, I've wanted to see this get pulled off. Would it be a big bother for you to document this swap well and do a write up when you finish.
    1991 Toyota MR2 │ Black │ 2.2l 5S-FE
    2006 Acura RSX Type-S | Blaze Orange Metallic | 2.0l K20Z1
    Previous: 2007 Mazda 6, Bright Island Blue | 1998 Subaru Outback, Blue/Gold | 1991 Toyota MR2, Red | 2000 Ford ZX2 S/R, Zinc Yellow | 1996 Ford Escort LX, Cayman Green
    May 2010
    Seattle, Washington
    13
    3,642
    37
    not a problem at all, i already plan on doing a well documented write up and posting it. and ill keep you guys up to date on my progress
    so far iv already installed the outside air temp sensor and the in dash sun light sensor, and im just waiting on the wiring diagrams and then ill let you know how the rest goes from there.
    May 2010
    Seattle, Washington
    13
    3,642
    37
    thanks to YamazakiSubaru i was able to get the JDM wiring diagrams for my car, that has the auto climate controll, so now that i have a better idea of how it should work this project of mine should finally start going somewhere
    "Proby" aekOne's Avatar
    Sydney Australia
    221
    5,061
    45
    Points: 5,061, Level: 45
    Level completed: 56%, Points required for next Level: 89
    good luck with it!
    lucky for me these are standard in Australian delivered cars as well, not just the JDM variants
    97
    5,369
    Points: 5,369, Level: 47
    Level completed: 10%, Points required for next Level: 181
    Quote Originally Posted by aekOne
    good luck with it!
    Thats good, that means the documents are in english. Anyway you can get an aussie FSM?
    May 2010
    Seattle, Washington
    13
    3,642
    37
    Quote Originally Posted by kirbyy
    good luck with it!
    i knew they were also standard like that in Canadian cars. However i havent found anyone from Canada or from Australia yet who has a Factory Service Manual. So if anyone knows someone who does have one, or knows where to get one please PM me
    its for a 98 Legacy sedan (95-99 years should be the same) I need one for the Automatic digital climate controll
    SLi Resident elislider's Avatar
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    Points: 7,322, Level: 56
    Level completed: 86%, Points required for next Level: 28
    any update on this? just curious
    SLi Resident eekay's Avatar
    Apr 2009
    Denver, CO
    789
    7,548
    57
    Points: 7,548, Level: 57
    Level completed: 99%, Points required for next Level: 2
    Looking to do the exact same thing! I already have the climate control unit but I don't have the sensors or motors yet. Not sure where I'm going to acquire those, actually. Anyhow, I was super curious as to how this stuff would be wired up as the connectors are WAY different. Thanks for posting the wiring diagram though! That'll help for sure.
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    good luck with it!
    BTW this is what I was really curious about. English FSMs
    SLi Lurker WESTcoast's Avatar
    Jan 2009
    Bay Area, Ca
    462
    7,064
    55
    Points: 7,064, Level: 55
    Level completed: 57%, Points required for next Level: 86
    Bump for this as I would like to to see the outcome!
    1999 Legacy GT Limited
    JDM Front End
    Momo wood Grain wheel
    HKS Hypermax Coilovers
    "FNG" Patrick Olsen's Avatar
    Aug 2009
    Where the Navy sends me...
    51
    5,822
    Points: 5,822, Level: 49
    Level completed: 36%, Points required for next Level: 128
    Bumping an ancient thread. I occasionally see the automatic climate "head units" on Ebay and they always intrigue me. All the picture links in this thread are dead. Has anyone successfully done the swap in a USDM BD/BG/BK?
    This certainly isn't high on my list of things I need to do, I just think it would be cool.
    Pat Olsen
    '97 Legacy 2.5GT sedan - RCE Tarmac2 coilovers, 4-pots front, H6 rears, '06 STI 6-speed, Quaife rear diff, mAd N/A powah!
    209 NorCal
    1,684
    13,292
    75
    Points: 13,292, Level: 75
    Quote Originally Posted by Patrick Olsen
    Don't buy this unless you can at least get all the parts for it just like the OP. I bought the headunit not thinking about what else it needed. Luckily only payed $40 with center vent. Check out how the 240 guys do it (google) and it pretty much shows you everything needed to do it on a 240
    Aug 2009
    51
    5,822
    Yeah, most of the time the ebay listings are just the head unit. Only once or twice (in the years that I've had a "Legacy parts" saved search) have I seen all of the bits and pieces.
    Pat Olsen
    May 2013
    3
    1,269
    19
    Points: 1,269, Level: 19
    Level completed: 69%, Points required for next Level: 31
    95 legacy BG non turbo 2.2l
    2,792
    A LHD BG with a 3rd gen BFM (which we have seen before) and digital HVAC.. Is this your car azazawra? Any more information on it?
    May 2013
    3
    1,269
    19
    not mine(
    this car from Kazakhstan.
    but I am also trying to do the same
    2,792
    Do you have any additional information on it? a link to some forum or more pictures?
    May 2013
    3
    1,269
    19
    3rd gen BFM on BG it's not a problem .... but digital HVAC (((((
    "FNG" TyrWagon's Avatar
    Nov 2012
    89
    6,428
    52
    Points: 6,428, Level: 52
    Level completed: 39%, Points required for next Level: 122
    Created Album picturesVeteran5000 Experience Points
    So... can you swap your HVAC?? I want to do the same... Here in Chile, we have BG5 Twin Turbo with LHD conversion, with HVAC and TWO functionally Turbos...But only EJ20H version engine... These car is only on one region (a region without custom taxes)... but these local people have many junkyards and the rest of the country can buy engine and car parts..
    Oct 2013
    Tilton, NH
    3,179
    34
    Points: 3,179, Level: 34
    Level completed: 86%, Points required for next Level: 21
    I'd be interested in any information on where one can acquire the sensors and or the wiring diagrams for this.
    if these were indeed available on Canadian cars then there shouldn't be any problems sourcing the sensors new from Subaru here in North America.
