Well a lot has changed here.
I'll try to the OP with up to the minute news.
Hey fellas its been a while. I suppose its due for an update.
After i wrecked it i took a break from it. Now, i am taking this time to repair the car and get all the weird glitches and whatnot figured out. I guess a few Pics can hurt. People who followed this build know i have attempted to paint it like 3 times and had epic failures every time. So we are trying again. I bought some nice, quality paint, and am paying a guy to spray it.
Ive been sorting all the stupid little issues with the wiring in it. The only one i cant seem to solve is my tachometer. I also did a new headliner in it, and a few other things.
I like that headliner!
Nice to see things happening with it!
Thanks i appreciate it.
Im about 15-20 hours in sanding so far and not even 20%. The rust and dents are very time consuming. Pictures of said dents and rust:
http://www.amazon.com/3M-Stikit-Sand...sanding+blocks
Get one of these.. It will make your body work so much better then just using a DA. It will show you your low and high spots when you block the car down.
Cool ill look into it!
I'm so glade I live here in the NW... So little rust to be found.
Yea utah loves to use salt on the streets of salt lake to melt ice, speaking of salt, rub some of it in this wound why dont cha?
@Dead91silvia doesn't want to know what the roads look like in MD right now.
My cars:
2019 Impreza Sport
2008 Miata
1998 Legacy L wagon- Sold
2000 Outback- Sold
Probably about the same shade of paper-white that the roads in CT have right now with all of the salt...
2010 SH9 Forester X Limited
2004 BEE Outback Sedan - Legacy B4 RS30 Project - Scrapped
I just picked up the paint.
Its this metallic silver. Its supposed to be this metallic grey in the dark, and when the sun hits it its super bright silver.
A tip for anyone who is looking to paint their car, go to a body shop and ask to buy some left over paint. Thats how i got this for so cheap. Its enough high quality paint to do a car, but it was less than $75! Down side is i didnt like the plain silver so i had them add some grey on the spot to darken it up.. so this is a one off color. If i need to repaint a fender and i dont have enough left over..im F'd.
That looks like a really nice color though.
My cars:
2019 Impreza Sport
2008 Miata
2000 Outback- Sold
Thankies
Got a package in the mail today.
Rather than buy bigger brakes i decided to purchase some flashy (pun intended) discs and some high quality pads, fluid, and lines.
That color looks fantastic, I look forward to seeing the entire car sprayed in it.
Thanks! im excited. I want to take my time and do it right. Which might require waiting till summer to paint it.
I am glad to see this car is still alive! Looking good man!
Sent from my iPhone using Tapatalk
Chevyman
1993 Legacy FWD 4EAT "Daily"
2006 Legacy Spec B "Project"
You might need to remove the windshield to get all the rust out. I've seen several subaru's with a rust on top like that. All probably cause by a blade thru the seal and over time the water gets underneath and rust it out.
I think you were asking about paint on rs25. That silver is nice. You might want to do a test panel first to see how your metallic arrange itself before doing something big. I would suggest painting the car panel by panel for better results but it may not match when you put them back together (different air pressure/the angle the mettalic sprayed/more or less coat on some areas). Is it single stage or base/clear? Is the color reduced already? Also what gun are you using?
Yeah alot of body/paint shop have excess premix paint (old inventory/mixed wrong or the customer never picked it up). I have alot of different base paint and I put them all together. Now I'm just looking for someone to see if they like it so I can spray it for them lol
99 BK postal wagon
http://sl-i.net/FORUM/showthread.php?19010
98 BD GT
http://sl-i.net/FORUM/showthread.php?13830
97 BG outback
http://sl-i.net/FORUM/showthread.php?16329
97 BK GT wagon
http://sl-i.net/FORUM/showthread.php?17636
95 BK Wagon SOLD
http://sl-i.net/FORUM/showthread.php?17179
Hey Flash, A thought on your tach issue. I know your running an AEM Ecu and remember you saying that you don't use the crank sensor. That could be your problem there possibly. Your tach should run off that signal iirc. Idk if you have that all unhooked or not.
Chevyman
Yea I have a buddy who is a good painter and we are going to use his stuff and he will be doing the spraying. I might rent a booth.. Might. It still needs to be reduced and its base coat clear coat.
As far as the tach is concerned, I Dont use the cam. The computer uses the crank to trigger and monitor the revolutions. The cam is just used as a sync. To help the computer know which revolution its on since the computer sees it as 720 degrees instead of 360. However I use wasted spark so I it doesn't matter on my engine if I Dont have the can to sync up.
Oh okay got ya my mistake. I don't remember much nowadays.
Chevyman
I would like try the 2.3 liter destroker eventually. Is that what you are still running? I am trading up to a 3rd Gen Sedan and will be setting aside a swap budget this time around. Run it with a td-05 twin scroll JDM setup
Chevyman
Hey I was on YouTube and saw your video on the tach. I would try a potentiometer. I gonna make a suggestion from my music experience haha but the 50k pot you are using is a very narrow sweep and would make adjustments difficult because it's not precise enough. I would try a 250k or 500k pot and see if that makes a difference. They have a wide sweep so you can adjust more precisely and thats what they use on guitars.
Chevyman
Got some aluminum lug nuts.
They are over the top and I Dont care. I like them.
