It should. They're the same, started from the 1990 as long as long as its not 5x114.3Originally Posted by kimokalihi
http://forums.nasioc.com/forums/showthr ... ?t=1265631
You don't need backing plates, you will need to trim it since the rears are bigger. Should be a direct bolt on. Make sure you have the complete caliper/bracket, rotor and pads for the 05 lgt
