Page 2 of 3 FirstFirst 123 LastLast
Results 31 to 60 of 71
Thread: Grafton's 07 STi
  1. #31
    SLi Supporter Grafton's Avatar
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Points: 12,386, Level: 72
    Level completed: 84%, Points required for next Level: 64
    Quote Originally Posted by Yamazaki View Post
    With the overbore, what will your new displacement be?
    2.5L still,
    old bore was 99.5mm x 79mm stroke x 4 cylinders = 2458cc
    new bore 99.75 x 79mm stroke x 4 cylinders = 2470cc
    12cc displacement bump or .012 L
    I got heads today!, the valves were reground due to pitting, and the heads resurfaced by .003"
    While waiting on the copper gasket spray to dry I added some Piston Wisdom™
    Jeremy Clarkson inspired
    Copper coated head gasket in place:
    Heads installed:
    Cams installed to check clearances
    Thanks to the re-grind only one valve was in spec, going to mic the shims Thursday and find out how many I have to order and if I can just swap some around.
    2007 Impreza WRX STi
    2012 Impreza 2.0i Premium CVT
    Sold 1997 Legacy L Sedan, 2.5L 12:1 Compression Hybrid, The 'Lego'
    RIP - 2005 LL Bean Outback, The 'Bean' & 1999 Impreza Outback Sport
  2. #32
    SLi nOOb Alphius's Avatar
    Aug 2009
    Rochester, WA
    149
    6,489
    52
    Points: 6,489, Level: 52
    Level completed: 70%, Points required for next Level: 61
    Shouldn't have to mic the lifters, they're all labeled with their sizes on the underside.
    99 Legacy GT WRX - Now for sale!
    05 Legacy GT Limited 5MT Wagon - Stock-ish.
    02 Outback Limited 5MT - Lifted, Dual Range
    84 Camaro Z28 - LS1/6-speed
    85 Silverado - Low and slow tow rig
  3. #33
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Quote Originally Posted by Alphius View Post
    Doing the rebuild by the book, book calls for it. I'm hoping that they are right on the money with the labels.
  4. #34
    Aug 2009
    Rochester, WA
    149
    6,489
    52
    Got it, no harm in being thorough! For some reason a lot of people don't realize they're marked so I figured I'd chime in. Looks like you're doing a good job on the rebuild!
  5. #35
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    ^Thanks
    I mic'd them today, luckily only going to need to buy 11, but most of the lifters were .01-.03mm smaller than how they were marked so a 510 was really a 507 or a 500 was a 499
  6. #36
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Lifters ordered
    Threw in the block heater
    and started wrapping the factory manifold, I'm planning on putting the heat shield back on, and possibly wrapping the crossover pipe, depends on how much 2" wrap I have after the up pipe.
  7. #37
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Progress from today:
    Hit the manifold with sealant, the copper coated the gaskets
    Test Fit the valve covers
    Piping mess begins
    Also started cleaning the oil of of the TMIC, it was filthy.
  8. #38
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    The stock studs fought, after many broken bits I took it to an exhaust shop and they were able to get the damaged studs out
    Wrapped up and waiting to dry so I can give it a high temp silicone coating
    engine mounts on
    lots of blowby= oily turbo
    cleaned
    reassembled
    Secondary air injection and AC bracket
  9. #39
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    I discovered that I ordered a WRX clutch kit instead of a STi kit, ordered the STi kit and shipped the WRX one back. Also discovered that the gasket kit didn't have the manifold to up-pipe gasket in it, and I grabbed a new 3" gasket for the downpipe to the midpipe.
    TGV's pulled, to be deleted soon. I've already tweaked my tvg closed map and disabled the codes
    passenger side head has correct clearance on the lifters and is put back together
    Need to order 3 more lifters to get the drivers side sorted
  10. #40
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Beginning of the TGV delete, pulling sensor motor combo
    grind down the screws
    removed butterfly's and rod
    Used a hacksaw to cut the divider walls out
  11. #41
    "FNG" Merc6's Avatar
    Sep 2015
    Cleveland, Ohio East
    85
    1,454
    21
    Points: 1,454, Level: 21
    Level completed: 54%, Points required for next Level: 46
    Quote Originally Posted by Grafton View Post
    decided to clean the AVCS cam gears and ran into a problem, I stripped the torx out on the last bolt, made it into a slotted screw, and still had to fight it:
    the tear down
    there was very hard sludge buildup in the areas where the rotor didn't touch took a lot of carb cleaner but i got it out
    bottom of the cam rotor
    top of the cam rotor
    cleaned and read to re-assemble, not pictured the 6 spring seals that go into the rotor
    I replaced the 5 point torx with new hex bolts
    driver's side with the hex bolts
    got some of the next batch of parts in, set of new plugs and a clutch kit
    didn't expect the "pro-kit"
    When you cleaned these, did you re use the rubber gasket?
    Sent from my iFail using Tapatalk App
  12. #42
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Quote Originally Posted by Merc6 View Post
    Had to, Subaru doesn't sell parts for the AVCS gears just the entire gear.
    FINALLY
    the engine is together!
  13. #43
    Sep 2015
    85
    1,454
    21
    That's what it looks like I will be doing as well. I already replaced the exhaust cam gears trying to remove the bolts @ $75 each i'm not gonna replace those too.
    FINALLY
    Good stuff! I like seeing builds finish.
  14. #44
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Today's progress:
    Started removing the runner divider leftovers
    finished, even removed the little lip that the butterfly sits on
    Mock up of the TGV on the heads, the ports line up perfectly.
    Throw out bearing ready to go.
    Up pipe brackets installed
    Crank pulley installed
    The rest of the parts I'm waiting on are showing up on Monday, so the engine should be in the car Tuesday.
    Still have to replace the fuel filter, finish cleaning the TMIC and intake manifold, and complete the TGV delete.
  15. #45
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Last parts arrived today, and the TGV deletes are finished.
    the bolt was about .5mm short on one side of the TGV but it seals up nicely:
    the motor/sensor side it was about 3mm too long, and had to be cut down and smoothed
    Turbo mounted and installed
  16. #46
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    FINISHED!!!
    I'm not a fan of the charge hoses I bought, the clamp for the BPV was too small and I had to reuse the stock clamp, and the TMIC elbow was too long and had to be trimmed to not bind up when mounting the intercooler
    ready to drop in
    bolted in
    ready to run, tested the block heater
    the post install hiccup was a small coolant leak on the oil cooler due to reusing the spring clamps
    other than that its works great
    now 960 miles of break in left to go
  17. #47
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Engine is broken in and running wonderfully. Finally got around to installing a set of rear sub-frame locking bolts
    Due to the freakish warm weather we're having this winter, I was able to install a little sound deadening in the car. I followed the cover 25% of the panel and you're good rule.
    Basically tapped around and found where the panels resonated the most and put some deaden-er there.
    Trunk:
    Under the rear seat:
    Not pictured because I was too lazy to take pictures are the outer doors skins, and the C pillar
    The car got some Christmas presents
    a pair of reverse light LED's
    Before
    After
    a pair of Brake light LED's put in the outer sockets
    and
    a controller for the LED strip in the wing to pulse the light then go steady
  18. #48
    SLi Lurker foohfooh's Avatar
    Jan 2013
    Seattle/San Diego
    431
    5,362
    Points: 5,362, Level: 47
    Hey that's super cool.
  19. #49
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Brake light improvements don't help when the person that hits you comes from the side:
    Truck in the right lane, turned broadside into the left lane, I swerved into the oncoming lane and got tagged on the rear quarter.
    I'm not sure if he was trying to pull a U turn from the right lane to head South or if he was trying to get into the cemetery that's across the road.
    Now I get to deal with insurance BS while it gets fixed
  20. #50
    3,526
    That is lame. Hopefully it won't be too much a pain.
  21. #51
    SLi Resident fwa2500's Avatar
    Mar 2008
    KCVG -> NZPM
    561
    9,511
    Points: 9,511, Level: 65
    Level completed: 54%, Points required for next Level: 139
    I saw that on facebook, that freaking sucks! Do you run a dashcam by chance?
    '11 Lexus CT200h - Feb. 2024-Present
    '12 Toyota Aqua - AKA Prius C, JDM city runabout. Sold. Apr. 2023-Feb. 2024
    '09 Toyota Crown Hybrid - JDM executive missile. Sold. Oct. 2019-Feb. 2024
    '00 Toyota Vitz Clavia - Sold. Mar. 2018-Jun. 2021
    '11 BMW 328i Xdrive - Sold. Nov. 2016-Apr. 2018
    '08 Legacy 3.0R Limited - Sold. Mar. 2015-Aug. 2016
    '97 Legacy wagon (BK) TS-R wanna-be - Retired. Oct. 2007-Jan. 2015
  22. #52
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    ^ No, I have been wanting one... Going to do some serious shopping for one soon
    Pulled the fender back out so it's drive-able until the 22nd when the shop can get me in.
    Estimated damage = new wheel, door and quarter
    In the meantime, I DIY'd a set of hood struts:
  23. #53
    Feb 2016
    Portland, OR
    7
    75
    Points: 75, Level: 1
    Level completed: 50%, Points required for next Level: 25
    great looking Sti, and I like you keep it stock after rebuild. it'll hold more value later down the road.
  24. #54
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Finally got the car back, ended up getting a new quarter, door, rear bumper, and wheel. I'm extremely happy with the work, even though it got delayed a few times while parts were ordered and shipped.
    I was able to get both cars detailed inside and out yesterday, nothing better than clean cars after a days work:
  25. #55
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Finally got around to dealing with the serious amount of road rash the front of the car has.
    The fog light covers both had serious rash like this:
    The drivers side had issues from not having any mud flaps
    I got some touch up paint from drcolorchip.com and went to town
    The fog light cover came out ok, but where the clear coat is failing it is still noticeable up close
    The drivers side came out near perfect
    after touching up the aesthetics, I changed the transmission and rear diff oil finally with some Motul gear300. While I was under the car I installed a Group N transmission mount, Kartboy front and rear shifter stays, and a TiC piviot bushing. I attempted to change the shift linkage as well but the bushings were the wrong size.
  26. #56
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    More adventures with an old STi:
    Monday leaving work I hit a pot hole and it sounded like a sledge hammer hit the back of the car. and the ride through town was slightly bouncy. After a spine shattering ride home I found the rear passenger side wheel more extended than it should be:
    It would not compress at all, and after jacking the car up to inspect it the rear froze at full droop:
    after limping the car to the garage, with replacement struts in hand, I found that the shock had blow and filled the strut with oil, not allowing it to compress:
    The surprise came from the drivers side, the spring perch was sitting about a half inch lower than it should and had a non factory speed hole:
    I also replaced the front struts and put in some group n top hats to replace the cracked and bulging OEM's
    The ride is a million times better now the rears are not on the verge of death and the fronts are working correctly
  27. #57
    Mar 2008
    KCVG -> NZPM
    561
    9,511
    I'm glad I could help! I still can't believe how bad the old struts were, pretty scary, eh?
  28. #58
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Incredibly scary, and I had checked the drivers side about a month ago and it was still in the proper place and not that rusty.
  29. #59
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Finally fixing another old issue with the STi, the passenger side projector wasn't putting out the right amount of light:
    So I bought a wrecked headlight and stripped it for parts
    pulled my headlight and began to repair it
    notice the missing gasket around the high beam
    that made the interior of the housing get wet when driving through heavy rain
    then the low beam would short out because the ballast was getting wet
    the cause of the low beam beam problem was the reflector was burnt
    even the chrome head light insert had heat marks
    It's all back together and working perfectly.
  30. #60
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Attempted to resolve the hot air intake on the STi, the first idea was an "intake box"
    closed up the gap between the spt heat shield and the intake piping
    added brackets for the lid
    top of the box
    It didn't work very well while I wasn't seeing the 185 F intake temp while in traffic I was seeing 150+ F and it would take forever to cool down after the car got moving and would still be ~15-20 F above ambient temps when ever the temp did come down.
    I got to looking at true CAI's decided I could make the SPT into a true CAI
    Grabbed a 60° 2.75" silicone elbow and a 45° 2.75" piece of inter-cooler piping and done
    It works much better the temps do climb while sitting in traffic but the highest it's went has been 130, and it drops quickly once the car is moving. Cruising I'm seeing within 4-7 of ambient.
    Logged for closed loop MAF scaling and the max correction was 2.2% from the OEM scale. I'm waiting on a wide band to scale open loop.
