Results 1 to 12 of 12
Thread: BH tailgate lock rod.
    Feb 2014
    145
    3,038
    33
    Points: 3,038, Level: 33
    Level completed: 92%, Points required for next Level: 12
    the tailgate lock barrel in my 2004 legacy wagon is frozen up, and the lock rod has been missing since I got it this past January.
    6 weeks ago I grabbed a lock rod from an outback while at the salvage yard. I didn't get a look cylinder then because the donor vehicles were either missing the key or they were also frozen. So I figured I would get a rod then so I would then only need a cylinder.
    I picked up a lock barrel from a 2003 for my 2004. When I was installing the rod I noticed that the rod is too short.
    Is it possible that the rod is too short? I was sure it was definitely an OB from 00-04. Perhaps I was wrong.
    SLi O.G. Muse's Avatar
    Jul 2012
    Willimantic, CT
    2,371
    10,774
    Points: 10,774, Level: 68
    Re: BH tailgate lock rod.
    Might be the difference between power locks and manual...
    Feb 2014
    145
    3,038
    33
    Er? Manual locks were an option? Or do you mean keyless / no keyless. That however is a very interesting thought.
    Jul 2012
    Willimantic, CT
    2,371
    10,774
    *shrugs* I honestly have no idea, but that was the first thing that came to mind. Wouldn't be a pre/post facelift change, as both cars are post...
    2,792
    How short is too short? According to the parts list, it did not change between 2000-2004.
    Feb 2014
    145
    3,038
    33
    Here are some shots.
    Cylinder unlocked, latch unlocked.
    Cylinder neutral - latch locked.
    Lock cylinder and connecting rod
    Additionally, I turned the rod around. And it does make it slightly longer. But not enough.
    Feb 2014
    145
    3,038
    33
    Could it be the latch actuator is different on an early 2000-2004 outback? What I should do is compare a picture of my own legacy latch before I take the lock rod from the donor vehicle
    Jan 2012
    central mass
    721
    5,463
    Points: 5,463, Level: 47
    I have this problem with my '99 legacy (no remote option) I bought it brand new-so I know it's the right one-but, the gate was damaged by the previous owner so the bolt holes don't even line up! I can't even find the time to bring it to a body shop I think it needs so I can open it up from the outside again.
    Feb 2014
    145
    3,038
    33
    Could your 99 MY part be meant for a late build and yours is an early build?
    2,792
    Since this is not a DIY, I moved it to the body section.
    otherwise, have you tried turning the lock cylinder over?
    Feb 2014
    145
    3,038
    33
    I tried to but the slant on the cylinder and the tailgate only match in one position
    Feb 2014
    145
    3,038
    33
    Update: I got it working with a longer lock rod.
    I went to the yard and got another lock rod. This was from a 01 legacy. The other rod was from an outback I believe.
    All were post MY 2000.
    Here's a picture of the rods side by side.
    The top one was what fit.
    Here's a picture of it from the donor vehicle, and different one from the yard. Notice the latch hook orientation and the bends.
