Results 151 to 180 of 271
Thread: TylerHartman's 1999 Legacy GT Wagon STI 6MT
Threaded View
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Points: 5,984, Level: 50
    TylerHartman's 1999 Legacy GT Wagon 5SPD
    Well on Tuesday, November 18th at 4 am I was on eBay and Came across a 99 Legacy GT Wagon with a Blown Engine over 2,100Miles away ending at 5:00 PM. Long story short I ended up winning the car...
    The Car: 1999 Legacy GT Wagon 5 Speed with Sunroof. Pretty Rare combo I've heard, It has a 137,000 Miles and Suffers from two dents from the pictures I can see and a Knocking engine, although the dents and engines are Aye-Okay in my book since I've been watching for a Rust Free, 5 Speed wagon here in Indiana/Ohio for a while and haven't found anything this clean or sweet.
    Body Work/General Completed
    -Respray Factory Color
    -DogLeg Trim Pieces Deleted
    -Antenna Deleted
    -Badges Holes Deleted
    -JDM AeroMajic Rear Skirt With Custom Mounts
    -Refinished Roof Rack
    Maintenance Work
    -Steering rack boots
    -Por15 Painted Front Swaybar, Rear hubs, knuckles, Front Sway bar brackets
    -Rear Wheel bearings,
    -Front Drivers Side Wheel Bearing
    Parts on the way or order soon:
    Outfront EJ25
    Chamber-matched T20 heads
    BC stage 2 cams
    ARP 625+ Studs
    BC valve springs
    Link G4X ECU
    Link Wiring adds
    Radium double pumper with x2 Walbro 450's
    IAG fuel rails
    Fuel labs FPR
    Killer B Holy header
    Killer B Oil pan
    Killer B High flow water neck
    Cobb 4 Bar map sensor
    ID1300X2 injectors
    FMIC kit
    OEM Head gaskets
    RCM cam gears exhaust
    HKS Timing belt
    -JDM BG5 Rainguards
    -eyelids
    -Chargespeed Yellow Glass
    -JDM Prova Grille
    -Esams Mirror covers
    -Prova Hood lip
    -SYMS S2 Front Bumper
    -SYMS Hood scoop
    -SYMS Blend Panel
    -Aeromagic Midwing
    Exterior:
    -Llumar 35% Carbon all the way around
    -HOOD STRUTS/DAMPERS Prova Carbon Fiber
    -Beatrush Belt Cover
    -JDM SYMS Brake Master cap
    -JDM SYMS Clutch Master Sock/Band
    -JDM ZERO SPORTS Cool Radiator Legacy Cover
    -JDM ARC Carbon Fiber Hood scoop Extension
    -JDM Greddy/Trust Lip (RIP)
    -JDM SYMS Grill
    -JDM Hipposleek Grille
    -JDM SYMS Skirts
    -JDM AeroMajic Rear Skirt/Lip
    -JDM Liberal 3 Part wing
    -JDM Silm Door Moldings
    -JDM Facelift Bumper + Bumper Beam
    -JDM Projector Fog lights
    -JDM Clear Side Markers
    -JDM Smoked “kouki” tail lights
    -JDM Projector Headlamps
    -Morette Lights with CB&D Brackets using G5-BRT Projectors-D2S
    -FX-R 3.0 3"
    -3Five Ballasts
    -D2S 5500K Bulbs
    -CB&D Mounts
    -JDM GTB L7 Red Badge Grill
    -JDM Power Folding Mirrors with 95 USDM Bases
    -Hella Supertone Horns
    -Honda Pilot Wiper
    -CDM Roof Rails
    Interior:
    -JDM BG5 GT/GT-B Camo-Stripe Interior (Front Seats, back seats with cup holder and slide up cargo net)
    -JDM BH5 Cargo mat
    -JDM Wood Center Vent
    -JDM BH5 S-Edition/S401 Black Visors
    -JDM BH5 Steering wheel with Black Momo Airbag
    -BG5 option CCFL high powered Dome light
    -BG5 Option neoprene mat
    -JDM Spring-loaded Ash tray
    -JDM Option Extended Armrest
    -OEM Puddle light kit
    -TopStitchTrim Shift boot
    -JDM BH5 Black Oh-Crap Handles
    -Dyed Black Mirror Visors clips
    -Noico 80 mil 36 sqft + 18 Sqft car Sound deadening
    -Outback Floor panels (Tie-down points)
    -USDM 98-02 Forester Option Leather E-Brake Handle
    -EDM/USDM (Rare) Door Grabs
    -OEM OB Limited Rear D Pillar Tweeters
    -JDM Aluminum Legacy Door Sills
    -JDM Center Console E-Brake Trim
    -JDM Auto-Shift bezel modded for the shift boot
    -Blacked out carpet
    -Blacked out Headliner with Fiber optic Starlights
    -Rare Dual socket Ashtray delete
    -LEDS
    -Red Sitch Leather Ebrake Handle
    -OEM 6MT Shift Knob
    -Beatrush blue reverse lockout
    -Cobb Short Throw Shifter
    -JDM Tommy M20TB Gauge Pod
    -Electronics/Audio
    -Defi ZD Club Sport (Water temp, Oil pressure, oil temp, Tacho, and Speedo)
    -Defi Advance CR 60mm Boost 2bar
    -Defi Advance CR 60mm Oil Temp
    -JDM OEM S401 BFM Gauge Cluster
    -Dakota Digital SGI-5E Speed convertor
    -Innovate ECF-1: (FUEL) Ethanol Content & Air/Fuel Ratio Gauge
    -JDM Panasonic ETC CY - ET906KD
    -Skar Audio TX65C COMPONENT SPEAKERS Front and rear with IA tuning adapters
    -Alpine CDA-7894
    -Alpine MDA-5051
    -Alpine PWE-S8 Under seat sub
    -I30 Auto-Dimming Rearview Mirror
    -Fiber Optic Starlights
    Engine & Drivetrain:
    -JDM EJ207 T20 Big Port heads
    -JDM EJ207 S20C (bored to 92.5mm)
    -JDM EJ207 Cross-drilled crank
    -BC Valve springs and retainers
    -Manley H-Beam Rods
    -Manley Platinum series pistons
    -ARP 2000 Head studs
    -Cometic Head gaskets
    -OEM 11mm STI oil pump
    -King racing Rod and crank bearings
    -STI 08-14 Top Mount Intercooler
    -Turbosmart 40MM EWG
    -ID1050X Injectors
    -Grimmspeed 3Port EBCS
    -APS S/R-40 (GT2876R)
    -APS 3" Hard inlet
    -APS 70mm Cold air with new K&N
    -Getadomtune Coolant reroute kit
    -Johnson tuning Speed density kit
    -Mamba GT28/GT30 Stainless Line kit
    -JDM EJ207 V8-V9 Long Runner Intake
    -Fluidamper Crank
    -HKS EL 2 Bolt header
    -HKS Hard Inlet pipe
    -HKS heatshield
    -Nightpager Catch can
    -Bachler Racing Coolant Lid
    -Custom DrivenFab MidPipe 3" to 2.5"
    -Apexi Megaphone Dunk Muffler
    -Kartboy 15mm Extended hangers
    -Killer B EJ25 Pickup
    -Killer B Windage Tray
    -06+ STI Oil Pan
    -Greddy/Trust Type S BOV with an adapter flange and TurboSmart plug
    -GrimmSpeed 38mm EWG Up pipe with Screamer pipe
    -Invidia Catless Downpipe
    -iWire merged with AVCS EJ205/EJ207 V7, With TGV Delete)
    -WALBRO 255LPH FUEL PUMP
    -Prova 1.3 Bar Cap
    -eBay Rad modded with steam port with OEM FXT rubber lines for over flow and extra 1/8 NPT for temp sender later
    -JDM Cool-Nuts Coolant hoses
    -JDM GC8 Ver1-3? Fender Coolant tank
    -JDM STI V7 6MT
    -JDM R180 3.9
    -Snorkus Delete
    -Goodridge Stainless Steel Clutch Line Kit Clear 04-05 Subaru Impreza WRX STI
    -Poly Front Shifter (stay) bushing
    -Kartboy Rear Shifter Bushing
    -TiC Ver7 Pivot Linkage Shifter Bushings
    -Kartboy Subframe bushings
    -Karboy Rear Outrigger Bushings
    -JDM Grounding kit (Zerosports or syms?)
    Suspension & Brakes:
    -Fortune Auto 500 Coilovers 8K Front - 6K Rear - Radial Bearings
    -JDM SUBARU LEGACY BG5 BD5 STI CARBON FRONT STRUT TOWER BAR
    -JDM Cusco Rear Sturt Tower Brace Carbon Fiber
    -JDM Cusco Rear Diff/Subframe Brace
    -JDM Mines Lower Arm Bar/Brace
    -JDM Garage Dog House Roof brace
    -JDM Do-Luck Back Seat Floor brace
    -JDM BG5 Cusco Rear sway bar
    -Group N Sti Pinch mount
    -Group N Sti Transmission mount
    -GrimmSpeed Master Cylinder Brace
    -Kartboy Front Endlinks
    -EBC Rotors (Rear)
    -StopTech Pads (Rear)
    -Goodridge G-Stop Stainless Steel Brake Line Kit 90-01 Subaru Impreza Legacy
    -225/45ZR-17 BFGoodrich g-Force Sport COMP-2
    -2004 STI BBS Wheels (Bronze)
    -Whiteline Front Lower Inner Rear Control Arm Bushing & Bracket Subaru (W53515)
    -BE5 STI Alloy Control arms
    -94 Turbo Legacy Cross Member
    -94 Turbo Legacy Steering Rack
    -94 Turbo Legacy Sway Bar 18mm (Repainted)
    -Whiteline KSR202 Steering Rack Bushings
    -Whiteline KBR HD Rear Sway Bar mounts with PROTHANE 19-1164 GREASABLE Bushings
    Pictures before I even bought it
    Here it is today
    Last edited by Tylerhartman; 11-03-2023 at 11:17 PM. Reason: Adding goodies to my Build
    1997 Legacy GT Wagon
    1998 Legacy L Wagon
    @TylerHartman on Instagram
    Thanks Tyler
Tags for this Thread
