Results 1 to 2 of 2
Thread: Sticky dash cover
    Sticky dash cover
    SOA will still help at least with the part. Labor from the dealer is just too much. Removal and install was reasonable except for the steering column top cover. That cover is trapped by design. I didnt try removing the steering wheel. Installed the wiring for my new gauges - much easier with no dash. Name:  IMG_00747.jpg
Size:  152.9 KBName:  IMG_0075.jpg
Size:  136.2 KBName:  IMG_0086.jpg
    2,792
    Since the dash pad seems to have insulation attached, I guess this is a 4th gen?
