Results 1 to 28 of 28
Thread: DIY: BE/BH Clear corners
    Eastern Canada
    1,350
    14,099
    77
    Points: 14,099, Level: 77
    Check out this very informative thread on Nasioc, written up by Fibuz. Ive copied it here for posterity.
    Also, look at the posts farther down the page for some helpful tips.
    https://sl-i.net/FORUM/viewtopic.php?t=2516
    http://forums.nasioc.com/forums/showthread.php?t=512193
    Quote Originally Posted by fibuz
    This has been discussed before, but I provide some pictures for MY2000+ headlight baking to get the orange reflector out. Don't bash my camera skills either, all these pics were taken with my cell phone.
    First off, clean the kitchen, grab a drink, head outside.
    Unbolt the three bolts holding the headlight in. There is another plastic clip deep inside, but I didn't have the patience to get off normal, so I just snapped it. Its low and near the back and its color is white. I think its worthless, but now that I've said that it probably has some bigger meaning.
    Unscrew the cap, take out all the lights, and gently remove each headlight casing.
    Next, head inside, grab a baking sheet, preheat your over to 250 degrees. Remember, don't touch any part of any lightbulb and don't touch anything you dont have to touch, namely inside plastics.
    Unscrew I think 5-6 silver looking screws holding the back of the casing together snuggly. Remove the last high-beam light if you want, I cooked with and without, didn't really make a difference. There is a huge screw sticking out 2-3 inches and a smaller screw behind some grey plastic. Don't worry about these, I think they have to do with headlight levelling, but do not hold the pieces together.
    Also, that white clip that you either broke or did not brake is held on by two screws. I dont think you HAVE to remove this piece, but I did.
    Once the over is preheated, stick the headlight casing on the baking sheet, put it in the over. I waited about 5 minutes before removing. I think it would go longer and make the glue more plyable if you left it in longer, but I was too anxious, and took it out after 5-7 minutes and pryed the casing open. A few more minutes wouldn't have hurt.
    Once you pry off the first layer, you'll naturally have two halves.
    Put the back side to the side, and concentrate on the front piece. There are now three black screws holding the silver relfective piece to the clear plastic. Remove the screws, pull the two pieces apart.
    Now insert a screw driver between the orange relfector and the clear plastic, pop, and its out.
    Retract your steps back to put it back together. Once everything was mostly put back together(minus the screws on the outside) I put it back in the oven to heat up the glue again. With the glue heated again, I made sure everything was snug, and rescrewed everything back in. At this point, you may or may not want to use a silicone based liquid to seal everything back up again. I didn't, but this I'm in Arizona, and it doesn't rain anyways.
    Check out the difference:
    After placing back on the car, checking all bulbs to make sure they work, I got these results:
    Not bad. There is still orange visable, but thats from the bulb. This orange will probably keep you from getting any tickets for 'clear corners' because technically this mod is 'illegal'.
    As you can tell, the difficulty of this isn't that bad, took under 2 hours start to finish. Good luck!
    You can get Silver coloured bulbs which light up orange.
    Philips Silvervision
    http://www.eur.lighting.philips.com/aut ... ision.html
    Silver coloured indicators
    • Directly interchangeable with existing amber bulbs
    • Enhances the styling look of transparent headlights
    Eastern Canada
    1,350
    14,099
    77
    Bump. Fibuz was nice enough to send me the pics and I was nice enough to host them!
    SLi Lurker OutbackGT's Avatar
    Nov 2006
    San Diego
    366
    7,819
    59
    Points: 7,819, Level: 59
    Level completed: 35%, Points required for next Level: 131
    Nice. I shoulda taken more pics when I did this mod a few weeks ago.
    SLi Lurker sansMYSTi's Avatar
    Mar 2006
    Fall River, Nova Scotia
    381
    7,959
    60
    Points: 7,959, Level: 60
    Level completed: 5%, Points required for next Level: 191
    Thanks Lee .
    Damon C
    December 2007 ROTM
    Titanium 2002 Legacy GT wagon
    - 17" gold Rota Tarmac II's
    - OEM wagon wing
    - SPT axel back
    - JDM cosmetics
    - Whiteline goodies
    - RalliTek tranny mount
    - Hella Supertones
    - JDM GT-B Bilstein suspension with H&R lowering springs and badging
    Atlantic Blue Pearl 2005 Outback 3.0R wagon
    Red 1978 Kawasaki KZ400
    t3h ub3r m3mber SilentRacer's Avatar
    Jul 2006
    Brooklyn, NYC
    1,196
    11,466
    70
    Points: 11,466, Level: 70
    Level completed: 54%, Points required for next Level: 184
    There is a common problem with doing this mod, my headlights are fogging up inside and i went over with silicon twice but it didn't help. I'm not the only person it happened to. Does anyone have the solution to that?
    The ohh shit effect, it's what makes a subaru a subaru.
    APRIL 2007 ROTM
    2006 Legacy GT Limited
    2003 Legacy L-SE - Sold to Belarus
    SLi Supporter blackgtbeauty's Avatar
    Southern Vermont
    1,305
    12,110
    72
    Points: 12,110, Level: 72
    Level completed: 15%, Points required for next Level: 340
    My best guess is to pull them apart and let them sit by some sort of heat source (woodstove, furnace...), seal them up after a while and let them sit there a little longer, maybe that would dry out any moisture on the inside.
    -Rob
    Jul 2006
    Brooklyn, NYC
    1,196
    11,466
    70
    and 3 months of driving with them wouldn't dry them out?
    APRIL 2007 ROTM
    Southern Vermont
    1,305
    12,110
    72
    Does your car not get wet? is there still moisture that can't get out because they're sealed? I've haven't done this so i'm just suggesting.
    -Rob
    Jul 2006
    Brooklyn, NYC
    1,196
    11,466
    70
    Quote Originally Posted by blackgtbeauty
    Yes it gets wet but not at the rate they fog up. So your saying that its the same water fogging up over and over because it can't get out.....something about that doesn't sound right to me.
    APRIL 2007 ROTM
    Southern Vermont
    1,305
    12,110
    72
    Either that or it's not sealing out moisture from getting in over and over
    -Rob
    Jul 2006
    Brooklyn, NYC
    1,196
    11,466
    70
    Thats my conclusion but i don't know how to figure out where its letting moisture in.
    APRIL 2007 ROTM
    Mar 2006
    381
    7,959
    60
    It is these moisture issues that make me weary about doing this mod.
    Damon C
    December 2007 ROTM
    - OEM wagon wing
    - SPT axel back
    - JDM cosmetics
    - Whiteline goodies
    - Hella Supertones
    Eastern Canada
    1,350
    14,099
    77
    Probably moister stuck inside. Ever see dual pane windows with moisture? Sometimes its there sometimes its not. Cold air on the front, hot engine in the back great for condensation
    Nov 2006
    San Diego
    366
    7,819
    59
    My clears:
    "Proby" LegacyRob's Avatar
    Feb 2007
    Fredericton, NB Canada
    216
    6,550
    52
    Points: 6,550, Level: 52
    Level completed: 50%, Points required for next Level: 200
    Maybe you have a bad seal on the backside where you put the bulbs in, I know that o-ring drives me just about nuts everytime i change a bulb.
    Silver 02 Legacy GT Sedan
    "Proby"
    Jan 2007
    Whitman, Mass
    237
    6,488
    52
    Points: 6,488, Level: 52
    Level completed: 69%, Points required for next Level: 62
    I had moisture problems with the headlights on my talon when I took out the yellow aswell. What I ended up doing was pulling them back apart, and laying down a bead of clear silicone in the groove and putting them back together. This pretty muched solved the problem for me.
    97 Legacy GT Red & Silver-------96 OBS Blue Green Black & Silver
    95 Talon TSI AWD Green 12.9@102-----91 Grand Wagoneer Grey & Woody
    "FNG" Supdood's Avatar
    May 2008
    Edmonds
    5,289
    46
    Points: 5,289, Level: 46
    Level completed: 70%, Points required for next Level: 61
    Do you think this mod can be done to the tails?
    so we can make our own Euro tails =]
    Jul 2006
    Brooklyn, NYC
    1,196
    11,466
    70
    Quote Originally Posted by Supdood
    No, the tailights don't have yellow reflectors in them.....the yellow is part of the glass.
    APRIL 2007 ROTM
    May 2008
    Edmonds
    5,289
    46
    I did this mod today and it turned out beautiful!
    I didn't wanna go out and buy the bulbs to make them look like true clears....so we had another idea for it.
    http://www.cardomain.com/ride/3082509
    On page 2 you'll find what it looks like.
    just an idea for all you other BE owners
    quick sample:
    Th3 Asshol3 Airgne's Avatar
    Mar 2008
    横須賀 さいたま 日本, Maryland
    2,959
    17,635
    Points: 17,635, Level: 84
    Level completed: 57%, Points required for next Level: 215
    hmmmmmmmmmmmmmm. sexy scooby!!!!!!!!!!!
    2013 VW GTI(Daily)
    2001 Legacy Gt Ltd(Sold)
    1992 Legacy SS(Sold)
    1991 Legacy L(Sold)
    SLi nOOb ConnertheCat's Avatar
    Mar 2008
    Rochester, NY
    5,363
    Points: 5,363, Level: 47
    Level completed: 7%, Points required for next Level: 187
    Did it yesterday myself:
    Very happy with how it turned out, though the part with the oven and splitting them apart was really a two person job.
    2000 LGT Limited
    Photos
    "FNG" Bianrox's Avatar
    May 2013
    New Hampshire
    25
    2,530
    30
    Points: 2,530, Level: 30
    Level completed: 54%, Points required for next Level: 70
    1000 Experience PointsTagger Second ClassVeteran
    Re: DIY: BE/BH Clear corners
    Jeepers!! Definitely good to have a heat gun hahaha
    First chair, last call
    t3h ub3r m3mber Grimmrican's Avatar
    Feb 2013
    plainfield, ct
    1,320
    9,357
    Points: 9,357, Level: 65
    Level completed: 3%, Points required for next Level: 293
    5000 Experience PointsVeteran
    It took u 2 ppl to split the lens?? I did that mod in like 30 min lol. But good job. Was fairly easy to do nonetheless
    Subaru Legacy L
    IG: grimmrican
    fb: epic benitez
    "Proby" teeceRS's Avatar
    Dec 2013
    North Carolina
    222
    1,739
    24
    Points: 1,739, Level: 24
    Level completed: 39%, Points required for next Level: 61
    has anyone ever warped their housings? I might do this at 200? just to be safe. I've done it time and time again on an Impreza, but the late model Impreza's had glass housings, where as here we have plastic. I tried to bake my girlfriend's Camry corners and they warped in the craziest way. lol
    Don’t tell me the sky is the limit. If there are footprints on the moon!
    '00 Impreza 2.5RS (Sold)
    Black Sheep | Legacy BH9 with a twist
    2,792
    I have not warped the housings, but I can say that 200?F at about 10 minutes was enough to get both sets of my JDM headlights open without damage. You really need to put them on a cookie sheet or half sheet pan just to prevent the oven rack bars from doing any damage to the housings. And be careful of anything metal still on them (such as angle adjusters), as they can leave nice scars..
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Points: 18,003, Level: 85
    Discussion Ender
    200* for around 10 mins worked on all 3 pairs of lights I've had to crack open... Remember to remove all bulbs, screws, etc that you can before putting it in the oven.
    2005 Outback XT
    GO > Show. Every time.
    Dec 2013
    North Carolina
    222
    1,739
    24
    this was stupid easy. haha idk what i was so worried about!
    Apr 2020
    Mt. Pleasant SC
    11
    Points: 1, Level: 1
    Anyone have this issue?Name:  20200508_140459.jpg
Size:  165.3 KBName:  20200508_140455.jpg
