i finally got a camera to take some pics.
- MODS:
Engine:
Cobb CAI
Delta Cam 2000/1000grind cams
Group A Throttle Body Spacer
Group A Light weight pullies
NGK Power Cables
STI Group N engine mount
STI Group N Pitch Beam
Idle Air Control delete
Rubber washer under knock sensor(for overactive knock sensor that pulls timing when it shouldnt)
160 degree grimmspeed thermostat
Optima Redtop
Exhaust:
Wrapped and Silicone coated Borla Unequal length header
Custom 3 in pipe
Custom 2.5 IN ID Cat pipe delete
Vibrant Street Power muffler
Vibrant 18 in Res
Optional Apexi N1 turbo muffler
Running Gear:
05 Outback Transmission
05 Outback Rear Diff
Spec Stage 3 clutch, aluminum flywheel, and aluminum pressure plate
Steel braided clutch line
STI Group N Mount
Beatrush shifter bushing
Kartboy Transmisson bushings
Kartboy short shifter
SunPro Rear Diff Bushings
Suspension:
JIC coilovers
Rallitek 22mm F&R Sway bars
Kartboy F&R Sway bar endlinks
Brakes:
JDM 4 pot calipers
USDM 2 pot calipers
07 WRX EBC Slotted and Blind drilled rotors
94 Nissan 300ZX EBC Red Stuff pads
Exterior:
Bosh Rally horns
JDM HID Headlamp assy
JDM Zero Sports Headlamp Eyelids
JDM Kouki Tail lamps
JDM Kouki Rear Bumper/Spats
JDM RFRB Grill
JDM B4 Emblem
JDM Kouki Door Sills
Zenki OutBack Front Bumper
Rally Armor Universal Mudflaps
Primative Skidplate
Wheels:
Enkei RPF1's 17x8 +45ET 15.4lbs each
UK 17's
Dunlop Direzza DZ101 235/45/17
Interior:
ScanGauge II
STI Java Black plastic
DIY Clutchless start
DIY Daytime running lights delete
Alpine CDA 9886
Lighting:
PIAA 520 Crystal Ion Fog lights
PIAA 520 ATP Driving Lights
PIAA 6600K HID Bulbs(lowBeams)
PIAA Crystal Ion(highBeams)
Sylvania Silverstar Turn Signals
Coming Soon:
CF hood
