So... as some of you have requested here is some info about the Subaru Diesel motor.
EE20 is the engine code.
2 types offered = Euro4 / Euro5
148 hp @ 3600 rpm | 258 lbf·ft @ 1800-2400 rpm
Turbo = variable geometry turbocharger (VGT)
ECU = Denso Euro4/5
Longblock = 2.0 liter DOHC / Timing Chain
Transmission = 6MT / 5MT (specific to EE20 configuration)
more info
http://subdiesel.wordpress.com/boxer-di ... gine-info/
More info @ http://boxeer.com/
Note: that boxeer.com is a vw bug/camper/bus/airplane swap shop and all of the "height/compact/clearance" parts they sell are for vw/airplanes only.. Subarus have more then enough room for this setup.
Boxeer.com also sells Bosch ECU for this swap.. is this needed.. depends on the source of your motor and if it comes with all the wiring/ecu/immobilizer/key/etc...
Let the posts begin.
Please ONLY EE20 DIESEL TALK!!
-Chuck
