Results 1 to 6 of 6
Thread: rear sub frame
    Oct 2012
    Annapolis, MD
    5
    3,138
    34
    Points: 3,138, Level: 34
    Level completed: 59%, Points required for next Level: 62
    rear sub frame
    Any body ever done a rear sub frame rebuild/swap on a BH?
    My car had an unfortunate encounter with a hill over the winter an one of the wheels is towed way in, think I bent what ever piece controls that. Anyway, my plan was to rip another sub frame out of a junkyard, rebuild it, and then swap it into the car all at once. Figure this is the best way to limit the time the car is on jack stands.
    I was wondering if anyone has done anything like this and had some advice on things like what brand bushings to get (I plan to replace literally all of them), and, well, any other advice you can think of.
    thanks .... to whoever reads this, I guess.
    "Proby"
    Mar 2012
    San Jose, CA
    235
    4,606
    43
    Points: 4,606, Level: 43
    Level completed: 28%, Points required for next Level: 144
    1000 Experience PointsO.G.
    I like Group N but most people like Whiteline polyurethane.
    03 350Z - 120K DD
    99 RS - Currently swapping JDM V9 207
    98 RS - 145K JDM 20K V4 WRX
    02 WRX - 150K DD
    95 Legacy Wagon - 200K Winter Tahoe tank
    SLi nOOb shoguy's Avatar
    Dec 2011
    York, PA
    104
    4,349
    41
    Points: 4,349, Level: 41
    1000 Experience PointsRecommendation Second ClassO.G.
    also would be a good time to check out if you have a limited slip rear differential. I believe the Limited trim had them, base model did not. Just make sure you get one from the same type of transmission to keep the correct gear ratio. This sounds like a good plan you have, would also give you a good opportunity to clean any rust and give the subframe a good coat of paint
    -Rick
    1998 Outback-Lift kit, plasti dip camo tan, 03 WRX calipers, slotted rotors, header, high flow cat, custom 2 1/4 catback, vibrant muffler, fresh rebuilt .020 over EJ25D w/ 251 block, strut tower bar, etc...
    04 35th anniversary H-6 Outback-Dynomax VT Muffler, power mode mod, not much else......yet!
    85 V65 Magna
    86 'Zuki Quadsport-fun machine
    May 2009
    MD, USA
    2,613
    17,786
    84
    Points: 17,786, Level: 84
    Community Award
    When I did the de-Outback-ification of my H6, I swapped in a new rear subframe (the old one was disintegrating into rust). I installed brand new bushings all-around (and new lateral links). I just ordered new OEM ones though. Nothing fancy. So now the rear end is relatively brand new and should last another 10~15 years.
    Past lineup:
    2,840
    @snail282, has your car been in Maryland all of its life? If so, good luck with the rear subframe bolts as they tend to rust and seize up. I was really lucky taking out the bolts on my car, but one on @Yamazaki's car ended up snapping on us and needed to be drilled out.
    If you do not HAVE to take the subframe itself out, then I recommend leaving it where it is. Most of the bushings are on the control arms and lateral links, all of which are (should be) removable.
    The rear diff carrier bushings are replaceable while still on the car. It is a little tricky to do, but dealers and repair shops do not pull the subframe to do them, so why should we?
    Oct 2012
    Annapolis, MD
    5
    3,138
    34
    I guess I don't have to take the subframe out but I don't actually have anyplace to work on the car and I never bothered to see what I bent/broke so I'm not sure what I have to replace. I figured if I went this rout I would only have to have the car up on jacks at my buddies house for an afternoon, as opposed to however long it will take me to diagnose and buy parts.
    One of my buddies brought op the idea of solid subframe bushings, either aluminium or delron and I was wondering what you guys thought of that? That got me thinking though, I have a lathe, and delrin isn't that expensive, so what would happen if I just made all the bushings out of delrin? I only use the car as a winter beater/race car so I'm not concerned about ride quality or anything, just wondering if anybody has experience with solid bushings?
    Also thanks for all the replies.
