Some photos of the progress today. I only have the B and C harnesses done, I will tackle the A harness after work tomorrow. In this process, I found an error on my PCB where I forgot to route a line for the second ignition pin on the B connector, however a quick jumper on the underside of the board fixed that for now. Oh well, if thats the only mistake on this board, I am happy with it. I believe on the 030, I do not even have that pin wired as it is, but I am running it for the sake of completion on this.
This is the C harness by itself.
This is the B and C harnesses connected to the adapter.
And this is the B and C harnesses connected to the adapter and the 090 cluster.
Oh well, in the end, we will get it working for you!
