I took the time to make up a nice neat list of all of the S401 exclusive parts, and parts from other models (such as STIs) that they put on the car. All prices are full retail prices, and are in yen.
Code:Part Name (S401 Exclusive Parts) Part Number Price (¥) Restricted? -------------------------------------------------------------------------------------- ECU 100106610 120,000 Yes Air Intake Duct ST218286600 38,000 No Electric Controlled Variable Muffler 4430066080 60,000 Yes Exhaust Pipe Front 4410266000 140,000 Yes Exhaust Midpipe 4420066000 66,000 Yes Engine Cover (No serial plate) ST1402566000 6,500 No Strut Tower Brace (Front) ST205006040 22,000 No Front Subframe Plate Left Upper (*1) ST2011766000 2,000 No Front Subframe Plate Lower (both sides) ST2011766010 2,000 No Parking Brake Lever (Right) 2670066000 2,500 Yes Parking Brake Lever (Left) 2670066010 2,500 Yes Backing Plate, Rear (Right) 2670466000 18,000 Yes Backing Plate, Rear (Left) 2670466010 18,000 Yes Stainless Brake Hoses (set) ST2655066050 36,000 No Parking Brake Cable (Right) ST2605166000 4,000 No Parking Brake Cable (Left) ST2605166010 4,000 No Aluminum Wheel (w/Cap and Valve) ST2810066000 88,000 No Wheel Center Cap ST2881166010 2,300 No Wheel Valvestem ST2810055280 800 No Coil Spring (Front) ST2033066050 8,000 No Coil Spring (Rear) ST2038066020 8,000 No Swaybar (Front) ST2041066010 25,000 No Swaybar (Rear) ST2041066000 20,000 No Swaybar Bushing (Front) 20414FE000 340 No Swaybar Bushing (Rear) 20464AE080 310 No Rear Suspension Link (set) ST2029066000 42,000 No Bumper Face (Front) (*2) 57720661xx 135,000 Yes Front Grille 9112166010 35,000 Yes Fog Lamp Cover (Right) ST5771066020 4,000 No Fog Lamp Cover (Left) ST5771066030 4,000 No Air Scoop (*2) 96070660x0 50,000 Yes Air Duct (outer) ST9081766010 16,000 No Air Duct (Inner) ST9081866010 15,000 No Side Skirt (Right) (*2) ST9603066xxx 30,000 No Side Skirt (Left) (*2) ST9603066xxx 30,000 No Side Skirt Clip Set ST9603066160 1,100 No Emblem, Subaru Front 91174SA070 3,150 No Emblem, S401 Front ST9105366000 2,500 No Emblem, S401 Rear ST9105366020 2,500 No Emblem, STI Rear ST9165366010 1,500 No Tire Pressure Label ST2819066020 100 No Hazard Switch 83037AE030 2,100 No Dash Trim (Center) 66060AE521 19,800 No Dash Trim (Left) 66050AE401 4,060 No Dash Trim (Gear Selector) 94110AE870 7,850 No Fender, Front (Right) 57120AE100 28,800 No Fender, Front (Left) 57120AE110 28,800 No *1 - Only left side has STI part, right side has normal FHI part. *2 - Item comes prepainted. Part number is different for each color, and is indicated by 'x'
Code:Part Name (Non-exclusive Parts) Part Number Price (¥) ------------------------------------------------------------------------ Shifter 35022FE010 5,000 Steering Wheel 24211FE040 45,700 Steering Wheel Airbag 98211AE130ML 79,000 Black Faced Meter (*3) ST8500066030 114,000 Headlamp, Complete (Right) 84001AE440 82,000 Headlamp, Complete (Left) 84001AE450 82,000 Headlamp, Lens and Body Only (Right) 84919AE080 33,000 Headlamp, Lens and Body Only (Left) 84919AE090 33,000 Steering Rack (15.0:1) 34110AE420 89,000 Transmission, Complete 32000AG390 620,000 Differential, 6MT (Front) 38410AA071 70,400 Differential, LSD (Rear) 27020AA050 74,700 Fender Turn Signal 84401SA000 1,250 Brake Caliper (Front Right) 26292FE022 100,900 Brake Caliper (Front Left) 26292FE032 100,900 Brake Caliper (Rear Right) 26692FE020 91,700 Brake Caliper (Rear Left) 26692FE012 91,700 Brake Disc (Front) 26300FE000 46,000 Brake Disc (Rear) 26700FE000 43,000 *3 - STI Catalog Version. Original S401 version is 85015AE240, but cannot be purchased.
