View Poll Results: Vote! (Pick 3)
Voters
87. You may not vote on this poll
  • Reason’s '98 BD
    22 25.29%
  • chuckthefuk’s '97 BD9 GT
    5 5.75%
  • Huffer’s '98 BK GT
    11 12.64%
  • YamazakiSubaru’s ’02 S401
    19 21.84%
  • Wiscon_Mark’s '03 Forester
    5 5.75%
  • Airgne’s '01 LGT
    7 8.05%
  • amgarrety’s ’03 USDM B4
    18 20.69%
Results 1 to 27 of 27
Thread: 2014 May ROTM: STAFF ROUND!
    Super Moderator amgarrety's Avatar
    Aug 2011
    York, PA
    1,841
    14,477
    78
    Points: 14,477, Level: 78
    Level completed: 7%, Points required for next Level: 373
    Social10000 Experience PointsO.G.
    It’s May! Warm weather and car show season is upon us. You know what else is upon us? Another ROTM! This one is a bit different though. It’s time to give the SL-i staff some love. Here is how this works. This competition encompasses any current or past Subarus (even non-legacy!) owned by the staff, so even though some of these cars are long gone, they are still eligible (since Huffer doesn’t want to compete with the Odyssey ). You have a longer span of time to vote this month due to no need for a nomination week.
    So go ahead, pick your favorite staff ride!
    Reason’s '98 BD
    Link to MR1
    Drivetrain Performance:
    -High compression engine EJ22 Heads EJ25 Block
    -Cometic hybrid EJ22/EJ25 head gaskets
    -OBX CAI (wrapped) w/AEM Brute Force 9" air filter and hydro shield
    -OBX Dual port UEL header (wrapped)
    -Custom 2.5" stainless steel cat back (Made by Wicked Innovation)
    -Custom 2.5" "J" pipe cat section w/2 Magnaflow high flow cat's
    -Delta cam regrind
    -Megan N1 style muffler
    -NGK Iridium spark plugs
    -MSD ignition coil pack w/4Zero1Motorsports mounting plate
    -Magnecore spark plug wires
    -Deatch Werks 255LPH fuel pump
    -Subaru 500cc fuel injectors (clean and rebuilt)
    -Parallel fuel mod (in progress)
    -Koyo Radiator
    -GrimmSpeed 160 T stat
    -Mishimoto gauge radiator cap
    -OBX Silicone radiator hoses
    -STi engine mounts
    -STi tranny mount
    -TiC cross member bushings
    -TiC shifter pivot bushing
    -Kartboy front shifter bushings
    -Kartboy rear stay shifter bushing
    -Competition Clutch Stage 1 clutch kit
    -Perrin short shifter
    -GRIMMSPEED thermal coated PnP 2.5L throttle body
    -GRIMMSPEED thermal coated PnP 2.2L intake manifold
    -GRIMMSPEED Intake manifold phenolic thermal spacers
    -Throttle body coolant bypass
    -Group A throttle body spacer
    -Group A pitch stop
    -"Top secret " LWC pulley
    -Gates Racing micro V belt
    -Dimple magnetic drain plug
    -A/C delete
    Suspension/Handling:
    -JDM BG5 Bilstein struts
    -JDM BG5 STi pink springs
    -JDM Aluminum control arms (TBI)
    -Cusco Rear lower arm brace
    -Juron front strut brace
    -Whiteline steering rack bushings (TBI)
    -GroupA front end links
    -Outback 18mm Rear sway bar
    -GroupA rear diff locking bolts
    -Falken tires
    -Muteki lug nuts
    Brakes:
    -04 LGT Calipers
    -04 LGT DBA street series rotors
    -04 LGT Hawk HPS pads
    -04 LGT 4Zero1Motorsports ss brakelines
    Exterior:
    -JDM Front bumper
    -JDM HippoSleek side skirts (TBI)
    -JDM Clear side markers (TBI)
    -JDM Folding power folding heated mirrors
    -JDM Tail lights
    -JDM mud spats (TBI)
    -JDM trunk lid (Red LED 3rd brake light)
    -JDM Projector foglights
    -JDM Projector headlights
    -JDM aftermarket grill (TBI)
    -Rear GT skirt
    Lighting:
    -6000k HID kit
    -White L.E.D. License plate lights
    -Amber L.E.D. directionals
    -White L.E.D. reverse lights
    Interior:
    -Sony GPS
    -MOMO STi v7 Steering wheel
    -STi eBrake handle (TBI)
    -Stainless steel gauge cluster bezel (TBI)
    -White LED doom light
    -White LED map lights
    -White LED glove box light
    -GT rear deck cover (3rd brake light delete)
    Random stuff done to it recently:
    -Lucus power steering fluid
    -Wrx fuel filter
    -Dual exhaust port 2.2 SOHC (Machine shop cleaned)
    -IDLER PULLEY (2)
    -ADJUSTER ASSEMBLY & BELT TENSIONER
    -REAR MAIN SEAL FOR 1990-2009
    -O RINGS
    -CAM SEALS
    -CRANK SEAL & LOWER SLING
    -TIMING BELT
    -GATES WATER PUMP ASSEMBLY & GASKET
    -COVER OIL SEPARATOR KIT with bolts
    -VALVE COVER GASKET KIT (both sides and six grommets)
    -Redline 10w-40 Oil and K&N oil filter
    -NEW FUEL SENDERS
    Link to MR1
    Engine: EJ25D Phase I
    -Group A Crank Pulley
    -Snorkus delete (kept the elbow)
    -Fender plug (PN46059FA000)
    -OEM STi rad cap 1.3bar
    -Borla Knockoff UEL headers
    -03' WRX cat-back 2.25"
    -OBX 2.25" catalytic converter
    -Universal C/F muffler (canister style)
    -STi exhaust hangers
    -A/C delete (lines + evap + condenser + compressor
    -Cruise Control delete (Stalk + vacuum lines)
    Maintenance items:
    -Alternator @ 145,000 km
    -Timing Belt @ 145,000 km
    -Accessory Belt @ 145,000 km
    -Cam Seals @ 145,000 km
    -Crank Seals @ 145,000 km
    -Water Pump @ 145,000 km
    -Thermostat @ 145,000 km
    -Front Axles @ 155,000 km
    -Head gasket @ 142,000 Km
    -Radiator @ 170,000 km
    Drivetrain: 5MT 4.11 - open differentials
    -GC v.5 STi 5MT shifter linkage
    -B&M Short throw shifter Picture
    -B&M front/rear shifter stay bushings
    -SS clutch line
    Chassis/Suspension: BD9
    -Megan 02-06 WRX / 04' STi Track-Spec Coilovers Part# MR-CDK-SI02TS Picture
    Front End:
    -Group N "STi" Engine Mounts
    -Group N "STi" 5MT Transmission Mount
    -GC FHi Carbon Fiber Titanium strut bar OEM Part# E4010FA100
    -Group A Pitch Stop
    -GC STi v.5 aluminum control arms
    -Noltec Front Gearbox Cross-member pads/bushings - Part # N92829
    -Group N STi Front Control Arm Front Bush - OEM Part# ST2021044040
    -Noltec 30mm Steering rack bushings - Part # N12247
    -Noltec Front End Links - Part # N22508
    -Noltec 20mm FSB bushings (shaved to 25mm) - Part # N22352
    -Tribeca B9 (FSB) 25mm rated @ 22.6mm (20401XA00A)
    -Noltec Front Camber Plates (Solid-clubsport) (Track) - Part # N44003S
    Differential Support:
    -Noltec Rear Diff Cradle Mount bushings - Part # N91380
    -Noltec Rear Diff Support Outriggers bushings - Part # N91379
    Rear End:
    -GD Cusco Rear Strut bar (modified = slotted)
    -Group A Rear Subframe Locking bolts Picture
    -GC v.5 STi Rear Trailing Arms
    -Noltec Rear Trailing Arm Bushings - Part # N61381
    -Noltec Rear Control Arm Assembly - Part # N62034 (Adjustable Lateral Links )
    ---Noltec Rear Control Arm Bushings - Part # N61382 (these come with #N62034)
    -Noltec 20mm RSB bushings - Part # N22352
    -Noltec Rear End Links - Part # N22507
    -Whiteline Swaybar lateral lock kit - Part# W0450-size (22mm) (Rear)
    -Whiteline RSB 22mm - Part # BSR19XXZ (lost by UPS... filling a claim)
    -Noltec Rear Camber Plates (Solid-clubsport) (Track) - Part # N44004S
    Interior:
    -JDM STi v.5 Driver Seat / v.6 Passenger Seat (Don't ask)
    -black wrapped door card inserts (I think I used Tweed)
    -00' RS Rear Seats (2dr)
    -GC JDM STi pedals w/ dead pedal
    -04' WRX e-brake assembly w/ chrome button (slotted to fit)
    -STi Titanium shift knob (Piston shape) (ST3500055010)
    -Airbag Delete (Driver)
    -Nardi 365mm Steering Wheel one piece integrated hub
    ---No clock spring / Modified steering column cover
    -Gut & Strip (40%)
    -Optima Red Top - relocated to trunk (2-Gauge)
    -GC a-pillar single pod voltmeter
    -GC a-pillar dual pod oil temp/pressure
    -OEM ignition cylinder (old one didn't go to the lock position sometimes)
    -USDM 140mph cluster w/ white needles
    -SS cluster bezel
    -JDM BD5 center console w/ 5MT badge, shifter boot, ashtray, raised arm rest
    -JDM BD5 dash brushed metallic console w/ pop-out ashtray
    -00' RS front/rear floor mats (Driver side mat has padding for clutch/brake pedal very comfortable)
    Exterior:
    -JDM Projectors + DTRL Delete w/ Silverstars
    -JDM Taillights
    -JDM Fiberglass Grille
    -JDM Front bumper w/ bumper beam
    -JDM Fog lights
    -Debadged 100% (trunk holes welded)
    -stock GT skirts
    -stock GT rear bumper w/ lip
    -Flat black paint.
    -Hood spacers
    -Power antenna delete (welded & shaved)
    -Clear Side Molding Lenses
    Wheels:
    -Sold 16" GT Snowflakes ($300)
    -Traded 04' 16" RS 5 spokes ($300)
    -Current 00' RS - 6 spokes (gloss black)
    -RE92's
    Brakes:
    -OEM 2-pot fronts
    -OEM 1-pot rears
    Audio:
    -Ej25D Boxer rumble... sounds very nice.
    -OEM 04' 6-disc
    -OEM 04' wrx speakers
    -OEM tweeters
    Huffer’s '98 BK GT
    Link to MR1
    Interior/Exterior:
    -Alpine CDA-9856 headunit
    -04 WRX Premium speakers
    -03 WRX Front seats - black/grey
    -JDM smoked taillights
    -Subaru Legacy L fog blanks
    -KARTBOY short shifter
    -03 Momo WRX steering wheel
    -07 WRX TR Shift knob & boot
    -JDM center console
    -USDM 16x6 WRX ET55 wheels (winters)
    -USDM 16x6.5 Baja ET55 wheels (summer)
    -Generic mudflaps for scraping the driveway
    -couple of decals (LERSOC, Golf Punk, Wagon Mafia, SL-i.net, Baby On Board)
    Suspension & Brakes:
    -Cusco adjustable 22mm rear sway bar
    -Noltec steering rack bushings
    -KYB GR2 struts, Group N strut tops, King Springs Low springs
    -rear strut brace from 02+ WRX wagon
    -front strut brace from GC Impreza
    -Tribeca FSB + Energy Suspension bushings
    -2004 Legacy GT front and rear brakes - calipers, pads "H6 rear brake upgrade"
    -Technafit stainless steel brake lines (1998 gt fitment)
    -Speed bleeder brake fluid valves
    Engine:
    -Fumoto oil drain valve
    -2.2L intake to ditch the massive airboxes (thanks AussieDan!)
    -CAI pipe from foglight hole to stock airbox
    -installed 05 STi axleback w/ 2.25" custom midpipe (catback exhaust) (its tucked under the bumper so it's actually kinda stealth)
    -Borla header - genuine
    -GFB light weight crank pulley
    -Tranquil "TSK1" 5MT snout kit for quiet clutch engagement
    -Fidanza lightweight flywheel 11lbs
    -Redline Shockproof in tranny & rear diff
    -New clutch slave cylinder
    -New air filter
    -New oil change
    -New front and rear o2 sensors
    -New fuel filter
    -New PCV valve
    Link to MR1
    Quote Originally Posted by YamazakiSubaru
    Exterior:
    -Turn signal integrated side mirrors
    Interior:
    -Factory
    Audio/Video:
    -Removed Factory option voice activated/touchscreen DVD/Nav/TV.
    Engine:
    -Factory
    Suspension:
    -Cusco frame brace
    Brakes:
    -Factory
    Exhaust:
    -Unknown aftermarket
    Link to MR1
    Quote Originally Posted by Wiscon_Mark
    Mods/Projects already done:
    -LED interior lights
    -Leather Stitched shift knob
    -2003 WRX front seats
    -Replace trailer electrical harness
    -Polish driver's side headlight fogginess
    -Fixed Rusty rear hatch handle & rust on the hatch itself
    -Installed Cobb shifter stay bushings
    -New o2 sensor & new exhaust gaskets all around (fun job)
    -SMK Fabrications "Forester" Dead Pedal
    -Replaced rusty front subframe rails
    -Honda Pilot wiper arm for the rear & new wiper motor
    -Extra-S fluid in tranny & fresh fluid in the rear diff
    -New struts/springs/tops
    -Rallitek adjustable rear sway bar & Audi "C" style aluminum endlinks.
    -JVC stereo, Polk 6.5" speakers, 8" underseat sub
    -ScanguageE, 'permanently' plugged in
    Airgne’s '01 LGT
    Link to MR1
    Quote Originally Posted by Airgne
    Engine:
    -Cobb CAI
    -Delta Cam 2000/1000grind cams
    -Group A Throttle Body Spacer
    -Group A Light weight pullies
    -NGK Power Cables
    -STI Group N engine mount
    -STI Group N Pitch Beam
    -Idle Air Control delete
    -Rubber washer under knock sensor(for overactive knock sensor that pulls timing when it shouldnt)
    -160 degree grimmspeed thermostat
    -Optima Redtop
    Exhaust:
    -Wrapped and Silicone coated Borla Unequal length header
    -Custom 3 in pipe
    -Custom 2.5 IN ID Cat pipe delete
    -Vibrant Street Power muffler
    -Vibrant 18 in Res
    -Optional Apexi N1 turbo muffler
    Running Gear:
    -05 Outback Transmission
    -05 Outback Rear Diff
    -Spec Stage 3 clutch, aluminum flywheel, and aluminum pressure plate
    -Steel braided clutch line
    -STI Group N Mount
    -Beatrush shifter bushing
    -Kartboy Transmisson bushings
    -Kartboy short shifter
    -SunPro Rear Diff Bushings
    Suspension:
    -JIC coilovers
    -Rallitek 22mm F&R Sway bars
    -Kartboy F&R Sway bar endlinks
    Brakes:
    -JDM 4 pot calipers
    -USDM 2 pot calipers
    -07 WRX EBC Slotted and Blind drilled rotors
    -94 Nissan 300ZX EBC Red Stuff pads
    Exterior:
    -Bosh Rally horns
    -JDM HID Headlamp assy
    -JDM Zero Sports Headlamp Eyelids
    -JDM Kouki Tail lamps
    -JDM Kouki Rear Bumper/Spats
    -JDM RFRB Grill
    -JDM B4 Emblem
    -JDM Kouki Door Sills
    -Zenki OutBack Front Bumper
    -Rally Armor Universal Mudflaps
    -Primative Skidplate
    Wheels:
    -Enkei RPF1's 17x8 +45ET 15.4lbs each
    -UK 17's
    -Dunlop Direzza DZ101 235/45/17
    Interior:
    -ScanGauge II
    -STI Java Black plastic
    -DIY Clutchless start
    -DIY Daytime running lights delete
    -Alpine CDA 9886
    Lighting:
    -PIAA 520 Crystal Ion Fog lights
    -PIAA 520 ATP Driving Lights
    -PIAA 6600K HID Bulbs(lowBeams)
    -PIAA Crystal Ion(highBeams)
    -Sylvania Silverstar Turn Signals
    Link to MR1
    Quote Originally Posted by amgarrety
    Exterior:
    -D-Type Turbo Hood
    -D-Type Front Bumper
    -D-Type B4 Headlights (wired to work properly)
    -D-Type Stock Grille
    -D-Type B4 Grille (spare grille)
    -Side Skirts
    -JDM Tinted Tail Lights
    -Chrome Marker Bulbs
    -OEM Spoiler
    -Complete Japanese Stock Badging
    -High Mount LED 3rd Brake Light
    -Hella Horns (3 Horn Setup)
    Interior:
    -JDM B4 Tinted Gauge Cluster
    -JDM Momo Steering Wheel (D-type with black metal ring)
    -Momo Shift Knob
    -Gauge Lighting (Blue)
    -HVAC Lighting (Blue)
    -Interior Lighting (Purple)
    -Painted (Metallic Charcoal) Radio/Fog Switch Bezel w/ Cup Holder
    -Broadway Rear View Mirror
    -Redline Goods Custom Shift Boot
    -Custom B4 Dead Pedal
    -WRX Seats ('02)
    -S401 Hazard Switch
    -JDM single-din pocket/button combination
    Electrical:
    -DRLs Disabled
    -Independent Fog Lights
    -USDM to BFM adapter (made by rkrenicki) (Awaiting Installation)
    -D-type Headlight Leveling Switch
    -GT/Outback Windshield Wiper Stalk
    -GT Courtesy Door Lights
    -Scangauge II ECU Monitor
    -1-stage unlock
    -Automatic up/down driver and passenger windows
    Audio/Video:
    -Pioneer Touchscreen Bluetooth Radio
    -Polk Speakers
    -GT Tweeters
    Engine:
    -B4 Hood Dampers
    -Grounding Kit
    -Lightweight Flywheel (Awaiting Installation)
    -"H4" Intake (Awaiting Installation)
    -Green Air Filter
    Wheels
    -17" Prodrive P1 Rims with 215/45/17 Michelin Pilot Sport A/S Plus tires (Summer)
    -16" Stock Snowflakes with 205/55/16 Tiger Paw Touring tires (Winter)
    Suspension
    -Tokico HTS/D-Spec Adjustable Struts
    -H&R Wagon (Non-Outback) Springs
    Brakes
    -Ceramic Brake Pads
    -Wearever (Advance Autoparts Brand) Rotors
    Exhaust
    -Custom SR·S Catback Exhaust
    SLi Supporter Hinyo's Avatar
    Nov 2011
    Maryland
    483
    7,907
    59
    Points: 7,907, Level: 59
    Level completed: 79%, Points required for next Level: 43
    Tagger Second ClassSocial5000 Experience PointsO.G.
    Re: 2014 May ROTM: STAFF ROUND!
    Sorry but all praise to Yama!!!! (ill probably get the ban hammer for this) lol
    Subaru Ambassador geckoboy86's Avatar
    Cburg PA
    1,643
    13,797
    76
    Points: 13,797, Level: 76
    Level completed: 37%, Points required for next Level: 253
    Created Album picturesO.G.SocialCreated Blog entryOverdrive
    Calendar Award
    My god this is a tough one.
    2 of these rides I have seen and touched. Not sure where to put my vote.
    SLi Resident 1996Battlewagon's Avatar
    Aug 2007
    Rochester, NY
    944
    9,470
    Points: 9,470, Level: 65
    Level completed: 40%, Points required for next Level: 180
    Ha, a large number of these cars either don't run, are stuck in storage or don't exist anymore. You know who you are.
    Oh and... VOTED!!!
    Current:
    2005 Legacy Outback H6 (Battlewagon 2.0)
    Former:
    1999 Legacy Outback 2.5 5sp
    2002 Legacy Outback H6
    1997 Legacy Outback 2.5 5sp (Battlewagon 1.0)
    1996 Legacy L Wagon
    Aug 2011
    York, PA
    1,841
    14,477
    78
    VOTING IS NOW PICK 3
    Jan 2007
    brooklyn ny
    1,348
    11,922
    Points: 11,922, Level: 71
    how does pick three work?
    voted for white, white aaaaand not white
    Aug 2011
    York, PA
    1,841
    14,477
    78
    It's just so you don't have to narrow it down to just one. The person with the most votes will still be the sole winner. You don't have to pick 3, but the option is there to pick up to 3.
    2,792
    Wow.. er. This one is going to be interesting!
    SLi Lurker foohfooh's Avatar
    Jan 2013
    Seattle/San Diego
    431
    5,362
    Points: 5,362, Level: 47
    Veteran5000 Experience Points
    Damn. Those mod lists are extensive and impressive
    9,857
    I would just like to say that I currently own mine and it runs
    And thank you to the kind soul who voted for me, I don't think I'm even going to be able to.
    MD, USA
    2,613
    17,786
    Points: 17,786, Level: 84
    Community Award
    That was me... for the very reason you pointed out.
    "FNG" TexasLegacy2.5GT's Avatar
    May 2011
    32
    2,834
    32
    Points: 2,834, Level: 32
    Level completed: 56%, Points required for next Level: 66
    Reason's BD is just so sick!!!
    2,792
    I voted for you too, Wiscon!
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,526
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    I couldn't vote for the S401. It has already won, granted that was a while ago. Plus Yama had the Imprezaab win recently. I voted for Reason, because his car is awesome. Even if it doesn't run right now. I also voted for Wiscon's Foz. He has cleaned it up real nice. Also voted for amgarrety's Type-D conversion. Its really clean in person.
    Cburg PA
    1,643
    13,797
    76
    Calendar Award
    The current poll results are about where I thought they would be.
    Reason BD up front.
    The S401 and amgarrety's BE D type in second.
    13,377
    To even be in a list, with these cars, is ridiculous.
    10,378
    57,313
    Points: 57,313, Level: 100
    Just for the record, I still own my Legacy and I start it up every few days lol, it just has 3 wheels on and no rear brake hard lines. That list is like 2-3 years old, I could probably add a few lines to it lol.
    That being said, I always like these staff battles. Not only do we have the best staff of any other Subaru forum, these guys cars are impressive. Chuck, Airgne, Amgar and yam a cars are sick and the mod lists and detail are impressive. Mark and Huffer cars may not have a lengthy mod list, but from their past cars and the love the put into them is impressive enough for me. To be honest, I thought I would be dead last!
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1998 BK L PARTED
    10,378
    57,313
    Quote Originally Posted by TexasLegacy2.5GT
    Bless your heart friend lol
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    Jan 2012
    central mass
    721
    5,463
    Points: 5,463, Level: 47
    Had to go with Huffer's wagon-wagons rock!
    13,377
    Quote Originally Posted by thenines'
    Hey that's right. Wagonlife! A vote for me is a vote for wagonmafia!
    VIVA LA FAMILIA!
    MD, USA
    2,613
    17,786
    Community Award
    Aww, the S401 went from 15 votes to 13....
    Did the S401 get less desirable? Who here wouldn't want one?
    Aug 2011
    York, PA
    1,841
    14,477
    78
    Still a few more days to get your votes in!
    5,050
    I think everyone is drinking too much un-purified water, myself.
    The S401 got my vote.
    2,792
    I can't speak for everyone else, but I can say for myself about the S401 is that I would not want one.
    I want two.
    13,377
    Vote it up guys!
    9,857
    That was pretty close in the top 3!
    13,377
    Congrats Reason... winning with a non-running car. Travesty.
