Alright, Hear me out.
I am in the early stages of debating between "Project Big Turbskie" or "Project Sti". "Project STI" is a swap i would rather think about if "Project Big Turbskie" isn't possible....
So my current questions are; (1) will an EZ36D fit in a third generation Legacy, (2) can I use the, open source tunable, ECU from a 2009 Tribeca Ecu: DZ1E402B, (3) would you use push and pull fans for the radiator or just push fans? I know i will be upgrading the cooling system a lot but I'm not familiar with how tight everything will be. I want to make it look like it came that way from the factory if possible.
Also... "Project Big Turbskie" will be in several parts.. IE turbo will be later down the line when I can get different pistons and space the heads to get a lower CR within the cylinder walls. This will be my education project since I'm learning about engines and want to get into performance building! I have several professionals who are willing to help me achieve my goals so swapping won't be hard. Just making the wiring harness and engine fitment is what I think will be the hardest!
