Results 1 to 24 of 24
Thread: DIY: BE Cluster trunk ajar warning light mod
Threaded View
  1. #2
    SLi Lurker Sub-Goon's Avatar
    Feb 2013
    Oakland, CA
    431
    2,599
    Points: 2,599, Level: 30
    Old thread, I know...
    I just looked at doing this on my BE. I figured out a cleaner way to do it.
    Both plugs the yellow/blue doesnt have a wire coming out on the other side. So next time Im at the wreckers, I will pull a yellow/blue wire with male pin and a yellow/blue wire with female pin and I need 6-8" of wire between them. Splice them together with a bit of solder and shrinktube.
    I really hate vampire taps, can you tell?!
    Edit:
    My first inspection was wrong, only on the blue plug was there only 1 leg. The white plug had an in & out. I used a yellow/blue wire with female pin, inserted in the empty spot on the lower blue plug. Routed it over along the harness and then soldered the splice into the yellow/blue out of the lower white plug.
